#29 | |
Drives: 2013 SWP BRZ
The first one or two times I set mine up I didn't place the air line well enough and it rubbed, but since I was anal about the setup I caught it before anything could happen. Not going to lie, being able to lift the car all the way up to get the jack underneath it and to clean out the fender wells when washing it is reason enough to love an air setup
| The Following 3 Users Say Thank You to xxscaxx For This Useful Post: |
#30 | |
Drives: frs or brz
Spot on my friend. |
#31 |
Bags are just springs in the end. The parts I'm not a fan of are the added weight, complexity, and extra space taken up by the air setup.
People also have a decent amount of problems with air bag setups in cold weather. |
#32 |
Drives: NSX
I personally would never use air bags on the track, not sure if mentioned already but there are just way too many things that could go wrong with an air bag system if you are going 100+mpg into a turn:
1. Air bag possibly getting a hole 2. Air line kinking 3. Air compressor going out 4. Electrical system to the air going out All of these you can simply avoid by going with coilovers on the track, there is a reason why coilovers are used and not airbags. Air bags are VERY durable, but not something I would take the risk of using on the track no matter who is marketing it and cruising around on the track with them. ANOTHER option would be air cups, they still utilize your coilovers just with an air cup set up where the upper spring hat would be so you can raise and lower your vehicle. -Jade |
| The Following User Says Thank You to Ksport For This Useful Post: | Godzilla35 (11-10-2012) |
#33 | |
Drives: NSX
#34 | |
Drives: 2013 Whiteout FR-S
| The Following 3 Users Say Thank You to SalM For This Useful Post: |
#35 |
Drives: 2013 SWP BRZ Ltd.
Hatres gonna hate that's all there is to it. Call me an idiot but the two guys given me crap don't even have a car of this forum which makes it more hilarious. Roll hard in your Camry and keep dreaming of owning one of these nice cars you can eventually build to UR liking and not others!
I hope not to scrap up my car either underneath, that's really the whole reason to get a system so u don't. Otherwise Id just stick with coilovers. Unfortunately I don't live on a race track where the road are flat an even for lowered cars. So a air ride system would suit My needs for daily use. Generally I believe if more airride systems were cost efficient I believe there would be more people rockin them. Let's be honest. CanibeatNoel stated his ride quality did not diminish and his car looks sick so low. Just my thoughts tho... |
| The Following User Says Thank You to DatGoodBRZ For This Useful Post: | sweeney208 (02-14-2013) |
#36 |
Get the air ride Godzilla!!! U won't be upset when ur goin over speed bumps!
| The Following User Says Thank You to DatGoodBRZ For This Useful Post: | F-Bomb (11-12-2012) |
#37 | ||
air cups are an option but very expensive. You are talking about 1100 bucks a CUP. They only offer a 3" adjustment as well. I looked into those, hehe. |
| The Following 2 Users Say Thank You to xxscaxx For This Useful Post: | Godzilla35 (11-10-2012), sweeney208 (02-14-2013) |
#38 |
Yeah, people don't do that because they are lazy. Valves freeze up as well, moisture in the system which is inevitable causes problems. I know it's just normal maintenance but I've read numerous stories about issues both with OE systems and aftermarket ones.
#39 |
Bags have the stigma of being for appearance only. This may be true in the past, but there's no reason performance bags can't exist on the market. Coilovers are traditional, and they work, and there's little reason to fix what ain't broke unless you want to simply make progress and innovate.
An air bag is just an air spring. It's more difficult to "tune" the air spring because bladder diameter, plunger diameter, pressure, volume, etc all play a factor in how the the "spring" does it's thing. Secondly, a good coilover is only as good as it's damper. Right? This can be true for bags as well. The only difference is that the air is much more progressive as it's compressed, so the stroke is far from linear. Air springs are not new. They've typically been used for show and because quick customization can be a little more difficult, the performance market doesn't pay them much mind. There's no reason this can't change. I am not interested in purchasing bags and truly DGAF about "stance", but I can wholeheartedly appreciate technological innovation. |
| The Following 2 Users Say Thank You to wheelhaus For This Useful Post: | GaN-MaN (03-05-2013), Godzilla35 (11-10-2012) |
#40 | |||||
Drives: Nissan GT-R
First off, there are a lot of really valid points and I hope to get people with more first-hand knowledge, like Noel to chime in. Maybe I will direct the engineers of Airrex and Air Lift to this thread once I get some time.
Keep the discussion going! |
#41 |
Drives: anyone seen my steering wheel?
The main problem with bags is that they are mainly used for both spring rate and ride height. They should really be separate (for performance use). The other downside to them is that each change in air pressure really requires a different shock tuning for maximum performance (in reality each different road surface really requires a different shock tuning as well). This makes shock tuning for an air spring (partly due to it's progressive rate, and its ease of adjustibility) more complex.
| The Following User Says Thank You to DEnd For This Useful Post: | Godzilla35 (11-25-2012) |
#42 |
Drives: none yet
and all of this wouldn't have started if the other guy hadn't said hellaslammed like a good ricer.... get over it and don't post unless you wish to help the OP.
| The Following User Says Thank You to benster For This Useful Post: | Godzilla35 (11-25-2012) |
| Tags |
| air lift, air suspension, airbags, airrex |
| Counterfeit Chinese Airbags | @Art_Mighty | Other Vehicles & General Automotive Discussions | 11 | 11-03-2012 03:20 AM |
