| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 | |
Drives: Nevermorange FRS
#16 | ||
Drives: 2004 Subaru Forester 2.5XT
-Dennis Last edited by bluesubie; 11-07-2012 at 10:08 PM. |
| The Following User Says Thank You to bluesubie For This Useful Post: | AZP Installs (11-25-2012) |
#17 | |
Drives: Asphalt FR-S
10/01/2012 FR-S down for P0019 code. Received vehicle back from dealership with a new ECU 10/30/2012
#18 |
Potato Farmer
Drives: #SLOBRZ
Preventative care is the best kind
I will be changing mine often.. Anyway, its simple, leave the car to cool down, most of the oil will drain out, if you have a stock filter it will have an anti drain back valve. With the new one, pour a bit of oil in to it, till it fills about half way and just wait, it will soak into the filter. Then rub a thin film onto the rubber, put it on and tighten it by hand, not too tight though. And you are done
Something something butter..
www.vic86brzclub.com |
| The Following User Says Thank You to fuddbutter For This Useful Post: | GMT (11-25-2012) |
#19 |
Drives: White Out FR-S
Spend money on a filter magnet, it will pay for itself over time relative to changing your filter between oil changes.
#20 |
Drives: 2013 Scion FR-S 6MT Asphalt
Where can I get a filter magnet?
I've never used one so this is new to me. Thanks.
- and yet, it moves! ... Galileo
#21 |
Drives: Ultramarine FR-S 6MT
Alternatively, 15 bucks worth of neodymium magnets will do the same work without so much cost.
#22 | |
Drives: FR-S ultramarine
I run my car hard every weekend for fun for couple hour rides 5-7k rev almost always and that is running hard for this car. Does not matter what the HP is. The key here is recommend oil change at whatever, and is set for the average daily driver. This does not mean you can not do it sooner. The best way to keep your oil filter working properly, or any filter for that matter, is to make sure it is clean and not clogged. Spending a few bucks and minutes is good time spent with your pride and joy.
| The Following User Says Thank You to Splat For This Useful Post: | GMT (12-19-2012) |
#23 |
Drives: 12,000 miles per year
Just for the record, there will be oil in the oil filter when you remove it from the engine. The oil filter has an anti-drain valve that keeps oil in the filter when the engine is shut off. The idea behind the anti-drain valve is to keep oil in the filter, which helps the engine build oil pressure as quickly as possible upon engine start-up. Anyone who has removed an oil filter should know that it has oil in it just by the weight of the thing alone!
BTW, an old mechanic's trick is to fill a new oil filter with clean engine oil before installing it. You can fill it up and turn it upside down and the oil will stay in there without leaking out. I do it all the time on my 4Runner, which has an upside down filter mounted out in front, just like the FR-S/BRZ. |
| The Following User Says Thank You to White Shadow For This Useful Post: | GMT (12-19-2012) |
#24 |
I never tried a filter magnet but will now...which one are you all getting?
#25 |
Drives: 2013 Firestorm FRS, 97 BMW M3
Some other members have already purchased filtermags and I believe the recommendation was the filtermag ss300 if you are using the #130 subaru oil filter. It depends on the filter dimension of the filter you are running. For instance I'm trying to decide which oil filter to go with tonight and have been doing quite a bit of research.
Mobil 1 oil filter at autozone (M1-104) has an outside diameter of 3.62 K&N HP-1004 oil filter has an outside diameter of 3.156 For the K&N you would want the SS300 filtermag per the diameter specifications on the filtermag website and Jegs. http://www.jegs.com/p/FilterMAG/Filt...13786/10002/-1
Willow Springs |
| Oil filter part number change, both #s deconstructed. | Calum | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 30 | 03-05-2023 01:02 PM |
| Oil Filter | Hayashi | Hawaii | 2 | 02-20-2013 12:07 AM |
| WTB: TRD oil filter | 86_ZN6 | Engine, Exhaust, Bolt-Ons | 0 | 08-26-2012 12:50 AM |
| Drop In filter test! Stock, Apexi, No filter | RallySport Direct | Engine, Exhaust, Transmission | 14 | 06-25-2012 02:40 PM |
| air filter | andy19804 | Engine, Exhaust, Transmission | 9 | 04-28-2012 03:35 PM |
