Old 11-07-2012, 12:30 PM   #2143
jesperswe
Drives: GT86
Originally Posted by Curt Aigner View Post
4015 MILES = CEL = POO11 , WAITING FOR INSTRUCTIONS FROM TOYOTA
What does that code stand for? Not the usual CAM related codes.
jesperswe is offline   Reply With Quote
Old 11-07-2012, 12:42 PM   #2144
soconfoozed
Drives: 2013 BRZ Limited 6MT WR Blue Pearl
SoA customer service misspoke, ECU actually threw P0017. So, first issue was P0019, now P0017.
I have an '812 ECU and a new HPFP going in today or tomorrow.
FSE was much better this time about being clear that this is a process, not a silver billet. Happy SoA no longer seem to be misrepresenting their ability to resolve this...
soconfoozed is offline   Reply With Quote
Old 11-07-2012, 02:35 PM   #2145
EJ33177
EJ33177's Avatar
Drives: 2013 Scion FRS Ashpahlt AT
Picked up today. Dealership replaced the Engine Control Module and a basic 7500 mile service. Car is worse than ever. I have an AT, in "manual mode" car will not rev above 2300 RPM. Steering is absolutely terrible. Almost feels like there is no power steering fluid.
Dropped off just now. This will make trip number two.
UPDATE:
Just went with Tech on test drive. He said something about new computer may be iffy for awhile to "relearn," also could be gearing issue.
Steering probably due to them over inflating (50 psi) when they put nitrogen in my tires.
Last edited by EJ33177; 11-07-2012 at 03:10 PM. Reason: Test drive w/ service tech
EJ33177 is offline   Reply With Quote
The Following User Says Thank You to EJ33177 For This Useful Post:
eurospeed (11-07-2012)
Old 11-07-2012, 02:48 PM   #2146
mhigham
I wonder if they flashed the wrong cal into it. They are supposed to drive it after repair, FAIL...
mhigham is offline   Reply With Quote
The Following User Says Thank You to mhigham For This Useful Post:
EJ33177 (11-07-2012)
Old 11-07-2012, 05:46 PM   #2147
jesperswe
Drives: GT86
Seems like alot of the recent people gets a new ECU, is the reflashed fucked up? Or they have no clue how to apply it....
Old 11-07-2012, 07:45 PM   #2148
EJ33177
EJ33177's Avatar
So more to add. Dealer replaced ECU, left the dealer with unresponsive, sluggish steering, and a lot of acceleration hesitation. In "manual mode" sixth gear would absolutely no go above 2300 RPM and had ZERO acceleration.
Drive right back and took service tech on a ride. He experienced the same but said the sixth gear inability to accelerate was normal (WTF). Steering was due to dealership over inflating tires.
So after bleeding some air from the tires off I went. Noticed the rough idle issue was gone. Ten minutes later, CEL and slip light on again. Drove directly back.
Brand new ECU didn't fix issue for me. I did contact SOA and a case manager should be contacting me tomorrow. Not a happy camper.
UPDATE:
Service manager just called. After ECU replacement car showed code P0011. Toyota Service HQ (or whomever dealerships contact for service questions) advised new sensors should be installed. Estimated 5-7 days for parts to arrive and install.
Also, SOA case manager failed to contact me as promised.
As a note to others going through this I'm keeping detailed notes (who talked to me, when they called, ect) including requesting the diagnostic print outs. I can't help it, it's the cop in me. It helps a lot when dealing with people giving you the run around.
Hopefully, I'll update in about a week with good news.
Old 11-07-2012, 08:00 PM   #2149
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
P0016 Crankshaft Position Abnormality - P000A Slow Response - P0011 Target Error (Bank 1=Passenger Side, Sensor A=Intake Cam)
P0018 Crankshaft Position Abnormality - P000C Slow Response - P0021 Target Error (Bank 2=Drivers Side, Sensor A=Intake Cam)
P0017 Crankshaft Position Abnormality - P000B Slow Response - P0014 Target Error (Bank 1=Passenger Side, Sensor B=Exhaust Cam)
P0019 Crankshaft Position Abnormality - P000D Slow Response - P0024 Target Error (Bank 2=Drivers Side, Sensor B=Exhaust Cam)
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
The Following User Says Thank You to @Art_Mighty For This Useful Post:
ftc~brz (11-10-2012)
Old 11-07-2012, 08:25 PM   #2150
Rob_g
Drives: 2010 4Runner Trail
I think some of these cars are never going to run %100 even with an ECU replacement alone.
Rob
Rob_g is offline   Reply With Quote
Old 11-07-2012, 08:37 PM   #2151
einzlr
Drives: several
Originally Posted by BrewCity-FR-S View Post
Just got the car back today. Toyota refused to flash the ECU so they sent a new one and replaced the Cam Sprocket. As far as the rattling in the rear of the car they added foam/insulation, greased a few things here and there, and cleaned up some welds. Seems like the technician had some fun with the car...put 30 miles on it.
I'll give him the benefit of the doubt and assume he just wanted to make sure that the cel didn't light up as soon as the car left the dealer as happened to others on here.
Asphalt FR-S MT (future)
'05 Hyundai Accent; '01 BMW M Coupe; '01 BMW M Roadster (for sale); '99 BMW Z3 Coupe 2.8l (for sale)
"Simplicate and add lightness." - Gordon Hooton
einzlr is offline   Reply With Quote
Old 11-08-2012, 11:42 AM   #2152
jesperswe
Drives: GT86
That's not good to hear. I wonder what their next step is.
Old 11-08-2012, 12:57 PM   #2153
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
Originally Posted by crazyfrenchbiker View Post
Add me to the list.
2600 miles exactly I started to experience check engine light, traction control light and idle RPM at 400-600
My VIN ends in 7086XX
Omaha, NE
Got my second call from the dealership, the ECU will need to be reflashed by a travelling toyota specialist. They may just replace the ECU under recall if they cannot schedule a specialist fast enough.
They gave me an IQ as a loaner... But called me today to say they are having a recall on all IQ's and I need to bring it in ASAP to swap it out.
Good day!
crazyfrenchbiker is offline   Reply With Quote
Old 11-08-2012, 01:42 PM   #2154
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Oh Toyota & Subaru...
The more I read the more I cringe...
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 11-08-2012, 04:28 PM   #2155
crazyfrenchbiker
Hot Lava 6MT
Good day!
Looks like I am getting a new ECU.
I swapped my IQ for a 2005 Corolla, sweet!
The Following User Says Thank You to crazyfrenchbiker For This Useful Post:
eurospeed (11-09-2012)
Old 11-08-2012, 05:35 PM   #2156
WheelDude.com
Drives: 2013 FRS
Send a message via AIM to WheelDude.com
Mine is in for the same thing, I have about 2800 miles on it
Got a Sienna loaner vehicle LOL
They said a field rep is coming today to look at it, I haven't received a phone call yet so we'll see.
WheelDude.com is offline   Reply With Quote
The Following User Says Thank You to WheelDude.com For This Useful Post:
NW Owner List & Event Archive DarrenDriven Northwest 1643 08-05-2016 06:48 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
An unofficial message from TMCA Courtz1074 AUSTRALIA 25 05-17-2012 10:00 AM
