Old 11-05-2012, 05:14 PM   #2129
EJ33177
EJ33177's Avatar
Drives: 2013 Scion FRS Ashpahlt AT
Originally Posted by mhigham View Post
Those are not the usual codes I believe.
According to the vehicle diagnostic report the service guy gave me "P000A" is "Camshaft Position A - Timing Slow"
C1201 is under the ABS/VSC/TRAC system
B1410 is under Main Body
The other two trouble codes didn't have a description.
I did experience loss of power, very low idle, and slip and CEL indicators.
EJ33177 is offline   Reply With Quote
The Following 2 Users Say Thank You to EJ33177 For This Useful Post:
eurospeed (11-05-2012), ftc~brz (11-06-2012)
Old 11-05-2012, 07:35 PM   #2130
BrewCity-FR-S
Drives: 2013 Raven FR-S
Just got the car back today. Toyota refused to flash the ECU so they sent a new one and replaced the Cam Sprocket. As far as the rattling in the rear of the car they added foam/insulation, greased a few things here and there, and cleaned up some welds. Seems like the technician had some fun with the car...put 30 miles on it.
BrewCity-FR-S is offline   Reply With Quote
The Following User Says Thank You to BrewCity-FR-S For This Useful Post:
Old 11-06-2012, 10:43 AM   #2131
SpeedmasterBRZ
Drives: Pearl BRZ Limited
Originally Posted by dwx View Post
The 08-2012 WRX/STi still has the same issues today as they did back with the 08 model. Guys with 2011s are still breaking ringlands due to the crappy stock tune, especially the OL/CL delay and the fact the car runs lean with the factory tune and suffers detonation. It's especially prevalent with people who run 91 octane. Has nothing to do with the electronics and everything to do with the programming.
I'm not saying there can't be something in the ECU which is the issue but I find it fairly suspect you'd have a bad input or output on the ECU itself without there being other major issues.
I know I had an 09 Hatch and 11 Sedan and put an AP as soon as I got home from the dealership. Did not mean that the ecu was a problem. That when people started having issues with the 08 STi subaru played stupid for a year before they officially annouced a recall for a flash.
We might see the same or we might see more parts needed to fix the issue.
SpeedmasterBRZ is offline   Reply With Quote
Old 11-06-2012, 10:46 AM   #2132
nashsnazzy
Drives: 2013 Scion FR-S White Out
I'm hoping the gravel sound is the sound of the engine knocking because it wasn't running correctly. It only exhibited this around when idle.
nashsnazzy is offline   Reply With Quote
Old 11-06-2012, 04:09 PM   #2133
jesperswe
Drives: GT86
Dated 3 days ago posted on BRZ forum from a guy working at a Subaru dealer:
The crazy part is they released the VIN range for cars that would be affected by this reflash campaign, but no actual reflash software. Threw us for a loop. I even had a customer come in thinking that we were good to go only to find out when he's here that we didn't have the necessary software to reflash his BRZ. We have every software packet for this campaign except for the BRZ. Go figure...
jesperswe is offline   Reply With Quote
Old 11-06-2012, 05:25 PM   #2134
sajonf
Drives: 13 Scion FR-S, 12 Camaro ZL1
So you are saying there is actually a campaign and a VIN range? This is the first I have heard of that. I check this thread daily but maybe I missed it.
Edit - perhaps there is one in Europe but none in NA?
sajonf is offline   Reply With Quote
Old 11-06-2012, 05:48 PM   #2135
Space Boy Matt
Drives: 2013 Subaru BRZ
New ECU on the way!
Originally Posted by Space Boy Matt View Post
Update: 11/02/12 300pm
Yes! Got a call from the dealer asking me to bring my car in on Tuesday morning. A regional Subaru Field Engineer is coming to look at my car. Also Subaru HQ said to the dealer their local techs are not to touch the car. Crossing my fingers that the "healing" process is beginning.
Update: 11/06/12 230pm
Dropped of my car this morning at the dealership when it opened. Unfortunately the guy at the dealership had no idea when the Engineer would show up. And I couldn't sit around and wait (so I could ask the Engineer the many questions on my mind), I had to get to work. They gave me a Legacy as a free rental (better than a Yaris or Prius! Phew!).
Then got a call at 230pm from the dealership saying the Engineer recommends a new ECU. New ECU ETA is this Thursday. Dealership will call me on Thursday.
So i guess Subaru's repair path now is;
1st) New ECU
(then if CEL returns)
2nd) New Camgears???
Space Boy Matt is offline   Reply With Quote
The Following User Says Thank You to Space Boy Matt For This Useful Post:
eurospeed (11-06-2012)
Old 11-06-2012, 06:24 PM   #2136
Vicious LED
Drives: Scion FR-S Asphalt
Update on mine:
11/5/12, ECU was replaced.
Drove home, no idling issue, no CEL/SCL, and out of limp mode. Back to just like when I bought her :]
11/6/12: Put another 50 miles on, still running great. Seems to be fixed at this point! However, I think I hear my chirping coming back...and I've already had the fuel pump replaced.
Vicious LED is offline   Reply With Quote
The Following User Says Thank You to Vicious LED For This Useful Post:
Old 11-06-2012, 06:25 PM   #2137
EJ33177
EJ33177's Avatar
After just a day at shop received a call an hour ago telling me my car was ready. Service lady said my "computer was replaced." I asked if that meant ECU reflash or new one. She said it was replaced. Ill update tomorrow after I pick it up.
The Following User Says Thank You to EJ33177 For This Useful Post:
Old 11-06-2012, 09:52 PM   #2138
SpeedmasterBRZ
Update:
Dealership called today to let me know the Field Technician worked on it yesterday and today and they ordered an ECU. It will be here tomorrow but the Field technician would not be able to program it untill Friday.
Old 11-06-2012, 09:57 PM   #2139
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
Add me to the list.
2600 miles exactly I started to experience check engine light, traction control light and idle RPM at 400-600
My VIN ends in 7086XX
Omaha, NE
crazyfrenchbiker is offline   Reply With Quote
The Following User Says Thank You to crazyfrenchbiker For This Useful Post:
eurospeed (11-07-2012)
Old 11-07-2012, 10:15 AM   #2140
Curt Aigner
Master Parts Manager
Curt Aigner's Avatar
Drives: 13' FRS Firestorm
4015 MILES = CEL = POO11 , WAITING FOR INSTRUCTIONS FROM TOYOTA
Curt Aigner is offline   Reply With Quote
The Following User Says Thank You to Curt Aigner For This Useful Post:
Old 11-07-2012, 10:24 AM   #2141
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
@eurospeed
Update, got my car last Friday, 11/02 with 4033mi, ECM replaced total of 5 days in shop. So far so good.
raul is offline   Reply With Quote
The Following 2 Users Say Thank You to raul For This Useful Post:
eurospeed (11-07-2012), Sportsguy83 (11-07-2012)
Old 11-07-2012, 12:00 PM   #2142
soconfoozed
Drives: 2013 BRZ Limited 6MT WR Blue Pearl
At dealer. Visiting field service engineer again.
Edit: I should note the effing dealer didn't bother to call me yesterday to confirm the work was actually done.
soconfoozed is offline   Reply With Quote
The Following User Says Thank You to soconfoozed For This Useful Post:
NW Owner List & Event Archive DarrenDriven Northwest 1643 08-05-2016 06:48 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
An unofficial message from TMCA Courtz1074 AUSTRALIA 25 05-17-2012 10:00 AM
