Old 10-31-2012, 04:06 PM   #15
xwd
Originally Posted by pcasso87 View Post
I had originally gone with omp sliders + planted seat bases + status side mounts and status seats. The seats them selves are light weight but the sliders and bases were really heavy, the combo weighed more than the stock seat. So i decided to have a fabricator mount these to the floor and now they weigh close to nothing. BTW dont get reclining seats if you plan to track your car.
Here is my setup:
Yeah people forget how heavy sliders and bases are and how much expense they add. They can also end up raising the seat higher than you want unless you get a lower profile base like the Nagisa ones. I used fixed ones in my other car that I didn't daily drive but I couldn't imagine not using sliders in a car I drive more often.
Old 11-02-2012, 03:56 AM   #16
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
That Takata seat looks like an exact copy of Cobra's Misano seat.
http://www.cobraseats.com/Misano
Old 11-03-2012, 05:11 PM   #17
xwd
They are the same seats. But with a Takata logo and green stitching! Definitely worth the extra $500.
Old 11-06-2012, 05:50 PM   #18
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Exactly... To get an articulating seat w/ silders may end up weighing almost as much as the OEM seats.
Expense > benefit, in above scenario, it seems?
GTB/ZR-1 is offline   Reply With Quote
Old 11-06-2012, 06:02 PM   #19
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
i have a 6kg cobra suzuka ready to go in just need to get brackets for it
Surok is offline   Reply With Quote
Old 11-06-2012, 09:29 PM   #20
Captain Snooze
Drives: Red Herring
You realise that won't be legal?
Old 11-06-2012, 09:33 PM   #21
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
i have more experience than most in the area of what is legal and not legal or can be made legal in this country.
Old 11-06-2012, 09:35 PM   #22
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
If articulating is a requirement then yes.
I'm looking at doing all the other major weight reduction before seats. I like the stock seats quite a bit, so much so I don't even use a CG Lock like I normally would and have sitting in the garage.
TomR
ABQautoxer is offline   Reply With Quote
Old 11-06-2012, 09:44 PM   #23
Captain Snooze
Drives: Red Herring
Could you elaborate on how to legally get an aftermarket seat into the 86/BRZ? I thought it was not legal to remove any airbags. I have a Cobra Suzuka in my existing car and is the only thing I will miss.
Old 11-06-2012, 11:15 PM   #24
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
oh well you will need to buy an airbag equipped seat if you want to register it on the roads.
I plan to just put my seat in for the racetrack as i do not want to cause unnecessary wear to the seat due to regular use.
after having this seat in my cars for about 3 years and then going to recaros, i prefer the recaros 90% of the time. easier to live with.
just get a nagisa low rail like i am going to do and then run the cobra at trackdays.
Light weight flywheel and crank pulley? wootwoot Engine, Exhaust, Transmission 133 06-23-2015 01:04 PM
Light weight and high winds in a Subaru alluringreality BRZ First-Gen (2012+) — General Topics 49 03-01-2014 06:04 PM
Light Weight Fly Wheel denverizzles Engine, Exhaust, Transmission 13 12-03-2012 02:28 PM
