Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 11-05-2012, 06:13 AM   #1
Xauterus
Drives: GTS 86 Galaxy Blue
Leaking front left shock
Tonight I was fitting my Tein Coilovers to the 86. Back end went in fine with Cusco lower arms and braces.
On the front the left side shock was leaking quite a lot. I have only done around 5000 km.
Its something that would be worth checking.
Pretty poor to have a leak after such low kilometres.
Cusco lower arms are a pain to tighten the adjuster nuts once in the car. I think they need to be unbolted to tighten the jam nuts properly.
Xauterus is offline   Reply With Quote
The Following User Says Thank You to Xauterus For This Useful Post:
Old 11-05-2012, 09:19 AM   #2
Paragon
Guest
Posts: n/a
Well that's pretty shit to hear about the Cusco arm design, putting mine in soon too so thanks for the heads up
Old 11-05-2012, 04:57 PM   #3
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
oh well thats what you have warranty for (the shocks i mean)
i would put it all back to stock and take it to toyota and get the shocks replaced before you modify it further
Surok is offline   Reply With Quote
Old 11-05-2012, 06:20 PM   #4
Justkiz
Drives: WRB BRZ
Did you have steering feel loosen recently? some are reporting significant loosen steering wheel feel which described as "floating".
The shocks bleeding you found might be the cause of loosen steering.
It is damn lame really, I am getting seriously angry over all these issues with 86/BRZ.
It is really the time to reconsider my order before mine delivered end of this month.
really really really disappointing.
Justkiz is offline   Reply With Quote
Old 11-05-2012, 06:42 PM   #5
ZZT86
ZZT86's Avatar
Drives: BR86
Can honestly say I've never seen that happen to any new Toyota I've had before 100k is up and these struts modded sti ! Possibly a dud shock !
ZZT86 is offline   Reply With Quote
The Following User Says Thank You to ZZT86 For This Useful Post:
Surok (11-05-2012)
Old 11-05-2012, 07:19 PM   #6
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
my WRX had a leaking front shock at similar K's, replaced under warranty no questions asked.
JP is offline   Reply With Quote
Old 11-05-2012, 07:37 PM   #7
Nardi330
Nardi330's Avatar
Drives: 86
guess this is a Subaru thing rather than Toyota?
Nardi330 is offline   Reply With Quote
Old 11-05-2012, 09:20 PM   #8
JP
Backyard Fabricator
not really, most people dont notice the leaks as they're covered by the dust boot.
I've seen plenty of Toyota shocks leaking while under warranty. I can't recall who the WRX shocks were made by but most of the Toyota OEM's I've seen have had KYB stamped on them somewhere.
The Following User Says Thank You to JP For This Useful Post:
Surok (11-06-2012)
Old 11-06-2012, 02:39 AM   #9
Xauterus
The 86 is fitted with showa ?? shocks. I cant be bothered putting it back to stock just to get a replacement shock.
They will only collect dust now anyway.
More something that 86 owners should keep an eye on.
Old 11-06-2012, 07:10 AM   #10
Nafe
Nafe's Avatar
Drives: Mt Fuji Red 86 GT
Angry about a leaking shock?? Wow, you guys to need to relax :s
You do realise they are mass produced parts right?? That means there will be the odd failure..... There is no point making a big deal about. ANY car will have some things go wrong, You have warranty, what's the big deal??
People really like to make mountains out of molehills :s
Nafe is offline   Reply With Quote
Old 11-06-2012, 04:15 PM   #11
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
Its upsetting nonetheless, but it would be resolved under warranty if the owner chose to do that.
I need a stock rear shock. PLEASE help me. mrha Southern California 5 10-10-2012 09:22 PM
Tires keep leaking EvoXDD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-29-2012 03:03 AM
Hood Shock Carbon Fiber Damper Set? Mo707 Cosmetic Modification (Interior/Exterior/Lighting) 24 08-10-2012 02:31 AM
Brake Light Leaking Covered in Condensation Smokinbuffalo BRZ First-Gen (2012+) — General Topics 9 06-12-2012 04:43 PM
