Old 11-04-2012, 01:37 AM   #15
einzlr
Drives: several
Originally Posted by i_4got View Post
Noob question here!
There was a thread about snow tires where everyone was talking about TPMS and how expensive it is since something is needed to be done every time you swap tires. Some users were saying that they just weren't going to buy it.
Can someone enlighten me as to what TPMS is, why it's important, and whether I need to buy one before I put my snow tires on my FR-S?
TPMS stands for Tire Pressure Monitoring System. They're probably talking about recalibrating it for different tires. If you can point me to that thread I can probably decipher it for you
Asphalt FR-S MT (future)
'05 Hyundai Accent; '01 BMW M Coupe; '01 BMW M Roadster (for sale); '99 BMW Z3 Coupe 2.8l (for sale)
"Simplicate and add lightness." - Gordon Hooton
einzlr is offline   Reply With Quote
Old 11-04-2012, 01:47 AM   #16
einzlr
Drives: several
Originally Posted by JLMtm View Post
Your not supposed to warm up the engine then? or there's no harm in doing so?
Well, what you for sure don't want to do is rev it when the engine's still cold. What's ideal for the car is to drive off at low RPMs and generally drive moderately until the engine warms up. But if it's too miserable inside the cold car in winter, then it can be considered a reasonable trade-off to idle it until you start getting warm air coming out the ventilation ducts.
Old 11-04-2012, 01:52 AM   #17
Bluecille
Drives: Scion FR-S Ultramarine
Originally Posted by ashtray View Post
My wife used to think she had to warm up the engine by driving it harder when it was cold. *facepalm*. The things she misunderstands about cars makes noobs look like scholared experts. Needless to say, she doesn't get to drive my cars!
I would have seen if the dealer would have taken a trade-in for her. She works hard and bakes a mean casserole; mops floors too! I'm only kidding but I slapped my head when I read that.
Bluecille is offline   Reply With Quote
Old 11-04-2012, 03:30 AM   #18
Tigranakert
Tigranakert's Avatar
Drives: Hot Lava FRS 2013
Originally Posted by so_fr-sh View Post
A thread fit for a noob! Nice....
Now here's my noob question. It's pretty general and probably applies to most cars-
Some people say it's better to warm your car up in the winter by turning it on and letting it run for a few minutes. Some say that it is okay and even better to begin driving immediately upon cold start, as long as you drive it very lightly in low RPMs to start out with.
What do you think is the best way to warm up your car in the morning?
IDK if anyone else has noticed, but when I turn on my FRS, it starts at 2500 rpms then slowly works itself down to 1200. then it changes its noise to a lower one, goes up to 1500 and goes down to 800 rpms in a few seconds. That's when I know the car is warmed up. It takes about 30 seconds on daytime California and about a minute 30 during nighttime. If i keep it any longer the Idle Engine Noise comes on haha.
Tigranakert is offline   Reply With Quote
Old 11-04-2012, 10:15 AM   #19
i_4got
i_4got's Avatar
Drives: Whiteout FR-S
Thanks! The thread is here: http://www.ft86club.com/forums/showt...t=20301&page=6
The discussion about TPMS is only on the last 2 pages or so.
Originally Posted by JimmyMac View Post
It basically lets you know if your tire(s) is low on air. Without it, you will constantly have the TPMS light on in your dash. It's a small sensor that is attached to your valve stem and sits inside your wheel.
Soooo, my FR-S stock wheels already have this sensor? And I'm technically supposed to buy a new one to go with every set of wheels I buy?
i_4got is offline   Reply With Quote
Old 11-04-2012, 10:21 AM   #20
jmaryt
Drives: 2012 honda civic ex
Originally Posted by midnightfrolic View Post
it's a honda, that's why. heh
right!
+1 This is exactly what I've heard as well from everyone whose advice I respect. Implied in there "with moderate speed and acceleration" is keep the revs down until the engine is warmed up.
The deal with warming it up in winter is for the creature comforts of the human occupants, so yeah, it's a trade-off.
wait 10 seconds for "pressure in the boat" THEN drive off slowly keeping revs down until engine reaches operating temperature.
no idling! get "oil pressure" then drive off! your car will warm faster under load,as opposed to just sitting there idling.parts will wear more rapidly in a ''cold" engine at idle!
jmaryt is offline   Reply With Quote
Old 11-04-2012, 10:24 AM   #21
Xanatos
Xanatos's Avatar
Drives: @redline, '14 BRZ, '98 Forester
You can go without TPMS however your TPMS warning light will pop up without them. This can be fixed by going to the dealer and having them remove it from your computer. You don't have to buy a new set for every wheel you can remove the current set and move them to new wheels as well.
Engine wear during a "cold" start has two main components to it. First is the temperature. As the engine heats up different metals inside the engine expand at different rates causing wear. This includes compression rings, pistons, engine block, and valves. The second component is oil. As the engine sits the oil slides off the cylinder wall down into the block. This means that there is a thinner layer of oil on a "cold" start meaning more wear. This gets fixed when the piston dips itself more and more times into the motor oil. So the type of oil that you use can also be a big factor in engine wear. It's best to pick the stickiest type of oil you can find.
Xanatos is offline   Reply With Quote
Old 11-04-2012, 12:55 PM   #22
einzlr
Drives: several
Thanks for adding that! A good way to make it happen is to start the engine, *then* put on your seat belt, check mirror adjustment, adjust windows, select music etc, *then* drive off. I do it that way, but I had forgotten why
The Following User Says Thank You to einzlr For This Useful Post:
virobloc (11-04-2012)
Old 11-04-2012, 12:59 PM   #23
travace
travace's Avatar
Drives: Scion FR-S
for me its usually start car... wait for wife to actually get in car then go
travace is offline   Reply With Quote
Old 11-04-2012, 01:29 PM   #24
einzlr
Drives: several
Well that's what the guys in the "Snow Tires" thread are saying (actually it's one sensor for each wheel plus programming/calibrating by the dealer). But then we learn that:
This would be my personal preference - either skip it altogether or reuse the current ones. Either way I prefer to keep an eye on tire pressure myself instead of relying on sensors which can fail - but that might be because I go way back to before there were sensors for everything and early ones were often faulty :P
With the caveat that you don't want it so sticky that it turns to molasses in cold weather, making cold starts hard all over again.
Old 11-04-2012, 10:19 PM   #25
IloveBaldEagles
IloveBaldEagles's Avatar
Drives: Gray.
My Noob Question would be related to paint.
Is Opticoat the same as Xzillon?
I am very insecure. I have no friends. I want people to love me
Old 11-04-2012, 10:53 PM   #26
Synack
Boosted
Synack's Avatar
Drives: Sideways
What you guys don't all have turbos and floor it the second you turn your car on from a cold-start? Get with the times!
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 11-04-2012, 10:59 PM   #27
travace
travace's Avatar
Drives: Scion FR-S
how does one know what tire/rim sizes will fit their car and an explanation of what all the numbers and letters mean.
Old 11-04-2012, 11:15 PM   #28
whataboutbob
AutoX-10/10ths every run
Originally Posted by DaJoian View Post
Let it warm up for a minute or two, as soon as you see the idle RPM lowers to about 800, drive it but do not race the engine.
I usually let it warm up enough to see the temperature needle move up to the first bar before I slowly drive off.
+1.
I will wait until the temp gauge is not bottomed out and has risen to the first bar as well.
Build thread:Here
Noob to wheels! :( _F-R-S_ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 08-24-2012 08:17 PM
Noob to this. Style Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-09-2012 08:10 PM
Noob how often do you check you oil Fugazi Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 07-06-2012 05:58 PM
Noob question fitcious Cosmetic Modification (Interior/Exterior/Lighting) 2 05-02-2012 11:18 PM
Noob to the forum! Altezza_86 Off-Topic Lounge [WARNING: NO POLITICS] 14 12-19-2011 05:34 PM
