Old 11-03-2012, 09:55 AM   #15
TheSt|G
TheSt|G's Avatar
Drives: BRZ L 6MT, 128i 6MT, E39 M5, E36 M3
Originally Posted by TuxedoCartman View Post
One benefit of donwshifting as you're slowing down: should you need to execute any sort of emergency maneuvers, you will be in a proper gear already, and less likely to stall the vehicle. This is a vital technique in motorcycling that I feel still has merit in car driving.
Bingo.
Also, sitting at an intersection or in traffic while clutched in will fatigue your leg. Just learn to watch the lights or get a bit of distance and do the first gear crawl while the cars in front of you stop start.
3.2 911 5MT
BRZ Limited 6MT
BMW E82 128i 6MT
BMW E39 M5 6MT
BMW E36 M3 5MT
TheSt|G is offline   Reply With Quote
Old 11-03-2012, 02:53 PM   #16
sieglapj
sieglapj's Avatar
Drives: Toyota 86 Red
Also, don't half ride the clutch between gears. Take your foot of the clutch completely after every gear change. If u don't, u will shorten the clutch's lifespan.
sieglapj is offline   Reply With Quote
Old 11-03-2012, 05:12 PM   #17
JohnS_Rosamond
Drives: Mazda MX5
I thought that if you keep the clutch pressed down at a red light not only does it increase wear on the throw out bearing, but it's bad for the slave cylinder also (in the long run). You shouldn't really keep the clutch pedal depressed for long periods of time in a Hydaulic clutch.
JohnS_Rosamond is offline   Reply With Quote
Old 11-03-2012, 05:45 PM   #18
TOMIMOTO
TOMIMOTO's Avatar
Drives: MY00 Impreza 2.5RS
The car has brakes for a reason. There's no need for putting more stress on the drivetrain by downshifting through gears to stop.
If you have an exhaust you do look like a total badass rev matching down gears to a stop though.
TOMIMOTO is offline   Reply With Quote
Old 11-03-2012, 11:34 PM   #19
Rossman
Rossman's Avatar
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
Our 2007 Versa 6spd has over 100,000km's on it now, I downshift to stop most of the time, but sometimes I don't. I also leave the car in first at lights and just hold the clutch in (unless I just missed the light and I know it'll be awhile).
The clutch is still fine after all this time. I think these things last a really long time these days as long as you don't do anything crazy.
Rossman is offline   Reply With Quote
Old 11-04-2012, 12:19 AM   #20
TuxedoCartman
Drives: '13 86
No reason at all... except, you know, for proper street driving technique.
I have to wonder how some of you are driving, when you speak of "drivetrain stress" or "wearing out the clutch"... by simply changing gears or engine braking. There's a world of difference between use and abuse; and with this car's power, so long as you're not riding your clutch or doing 5000 rpm drops at every stoplight, the damn thing will likely outlast most other parts on your vehicle... even if you <gasp> use it!
TuxedoCartman is offline   Reply With Quote
Old 11-04-2012, 01:15 AM   #21
jflogerzi
jflogerzi's Avatar
I do this as well.
Old 11-04-2012, 05:01 AM   #22
jmaryt
Drives: 2012 honda civic ex
if the tranny is built ''right" with quality parts from the factory,
then generally one shouldn't have any issues with the clutch,or it's associated parts over time,(except,of course,overheating as a direct result of "partially" engaging the clutch, ie: holding on a hill,). ideally,one SHOULD downshift to properly slow the car,as this action keeps wear on the brake pads to a minimum. in "reality" your brake pads
WILL last longer over time.what you are doing is utilizing the engine's ''compression" as a brake and "tapping" the real brakes to come to a stop.
over time,the ''throw-out" bearing will need to be replaced,but only after a long,long time. as far as the ''downshifting" causing wear issues? well
that's purely speculative,as the tranny is designed,and engineered to withstand any "stress",and "downshifting" is part of the normal process of driving the car with a manual transmission.
jmaryt is offline   Reply With Quote
Bad Drivers jay4prez Off-Topic Lounge [WARNING: NO POLITICS] 7 10-27-2016 05:08 PM
New Manual transmission drivers Q&A garsh0p Engine, Exhaust, Transmission 136 10-30-2014 08:14 PM
Question for the experienced manual drivers.. enjoi23 Scion FR-S / Toyota 86 GT86 General Forum 54 10-18-2012 05:38 AM
TRADE: my Silver GT Manual (October Delivery) for Pegasus White GT Manual -AUSTRALIA ysagisan Cars for Sale/Trade 0 09-19-2012 12:24 PM
SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado huma BRZ First-Gen (2012+) — General Topics 15 06-14-2012 12:33 PM
