Old 09-20-2012, 11:43 PM   #15
#87
I usually post drunk
#87's Avatar
Originally Posted by zex View Post
Was thinking the same way, did a quick search with those sizes and found this General Tire Altimax Arctic, it had good reviews on Canadian Tire and a quick google search.
Any opinions on this?
Don't expect do much of any spirited driving on those tires. They are Q rated (99 mph) and soft as marshmallows. They are great in snow though.
#87 is offline   Reply With Quote
Old 10-31-2012, 04:19 PM   #16
pastuch
pastuch's Avatar
Originally Posted by hyper4mance View Post
I went with 215/55 x-ice 3 for the stock rims but haven't mounted them on yet. 55's were a decent amount cheaper since I got them under $570 shipped. According to the tire calculator, the diameter increases 21mm but I think it should be fine. I'll let you know if I run into any issues.
Hyper have you mounted yet? How did it go?
pastuch is offline   Reply With Quote
Old 11-01-2012, 10:48 PM   #17
hyper4mance
hyper4mance's Avatar
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
not yet... sandy aftermaths still felt... just got power back after 3 days so im pretty happy just to have lights and heat
hyper4mance is offline   Reply With Quote
Old 11-01-2012, 11:16 PM   #18
RazorHawk
Drives: 2013 Scion FR-S 6AT Firestor
I just ordered X-Ice3 205/55R16 rims, tires, and tpms from a local shop who is on this forum, gave me what I think is a great deal. Once they get in, as long as everything goes well, I will be recomending this shop highly. They are getting the stuff in fast, they have been very good on the phone and through the pm system here, and the prices were good.
RazorHawk is offline   Reply With Quote
Old 11-01-2012, 11:51 PM   #19
dsgerbc
Drives: BRZ(sold), STI
I put my Xi3s (in 205/55/16) on today as a test-fit, and they are quite slippery on asphalt @48F. Could be the outer layer though, but my TCS/VSC had to work extra hard today, until I put'em in sport mode. The ABS also activates fairly soon. Hope it gets a bit better on dry. Don't remember Xi2s being that slippery, but I first mounted them when it was much colder.
Old 11-02-2012, 12:13 AM   #20
RazorHawk
Thanks for the heads up, its still getting up in that range in the afternoon around here, I will be careful until I learn the new tires!!!
Old 11-02-2012, 01:15 AM   #21
rawbz
Drives: 2013 Subaru BRZ
That's a shame, I have my Xice3s reserved to be put on tomorrow and was hoping to still maintain a touch of performance on them.
How is the handling otherwise? I presume the traction control comes on upon acceleration? Or are you sliding out on turns the primacy's could easily handle?
rawbz is offline   Reply With Quote
Old 11-02-2012, 09:24 AM   #22
dsgerbc
It's better today, so it could be just a slick outer layer.
Handling in city is okay, somewhat squishier but not bad. A bit more wandering on the hwy.
I got TSC activating on acceleration all the way through first/second gear yesterday and VSC (I presume) in some corners. In sport mode, however, it's fine. It doesn't slip enough for the nannies to kick in.
Old 11-02-2012, 09:34 AM   #23
#87
#87's Avatar
You are going to notice that on all snow tires. The better they are in the cold, snow, and ice the worse they are going to be in performance and handling departments.
Old 11-02-2012, 10:35 AM   #24
rawbz
apparently there is new tire break-in...
http://www.tirerack.com/tires/tirete...e.jsp?techid=5
some lubrication so it doesn't stick to the mold.. tirerack calls for 500 miles to peak performance.
Old 11-02-2012, 10:50 AM   #25
dsgerbc
Yeah, I was expecting that, just a little less of it. I normally don't put my winter sets on until there's snow or sub-freezing temps in the forecast, so the effect is usually smaller. On the other hand, 500 miles is ballpark for summer or A/S tires. Winter tires will scrub it off sooner in warm temps.
Wheel Directory: OZ Ultraleggera 17x8.0 +48 Mageep Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 104 04-11-2021 12:03 AM
Wheel Directory: BBS CH-R 18x8.0 +38 Racecomp Engineering Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 81 10-01-2014 02:12 AM
FS: 245/40/18 Michelin Pilot Alpin PA3 Snow Tires Chuynh207 Wheels and Tires 3 11-06-2012 01:19 PM
Michelin Pilot Super Sport 17 inch DieselBoXXer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 07-05-2012 10:17 PM
Why pay Michelin prices? $185 per tire? Try this OE alternative: ExtremeContact DW rogerdalien Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 05-17-2012 01:33 PM
