AVOturboworld
Old 11-01-2012, 12:06 AM   #1261
TemeCal
Drives: 86
Originally Posted by AVOturboworld View Post
Ross could probably do an install in 3-4 hours, because he knows where everything goes and how it got there. Somebody doing it for the first time with the instructions is probably going to be between 6-12 hours depending on preparation and mechanical skills.
Awesome - just what I wanted to hear. Sounds like I could knock it out over the weekend.
Thanks!
TemeCal is offline   Reply With Quote
Old 11-01-2012, 03:48 AM   #1262
alexm86
Drives: White GTS Manual
SpeedHunters on the AVO Turbo BRZ
http://www.speedhunters.com/2012/11/avo-brz/
alexm86 is offline   Reply With Quote
The Following User Says Thank You to alexm86 For This Useful Post:
Alienate (11-01-2012)
Old 11-01-2012, 09:44 AM   #1263
AllDayJonRay
Drives: 2013 Ultramarine FR-S
I see that the BOV is an option... What is included with the kit as standard?
AllDayJonRay is offline   Reply With Quote
Old 11-01-2012, 11:18 AM   #1264
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Looking good Paul and Ross
Cant wait to see these kits in person
Kirill
RallySportDirect.com
RallySport Direct is offline   Reply With Quote
Old 11-01-2012, 12:04 PM   #1265
jiaim
Drives: Enthusiast
i think the avo billet bov is an option, i'v seen pics with a bosh plastic bov which works very well. No need for fancy aluml on a near OEM turbo kit.
jiaim is offline   Reply With Quote
Old 11-01-2012, 12:08 PM   #1266
AllDayJonRay
Interesting. Since 'stealth' was one of the key elements AVO was striving for, will the standard BOV recirculate? I'm curious, as I'm part of a minority of turbo lovers who hate BOV noise.
The Following User Says Thank You to AllDayJonRay For This Useful Post:
Calum (11-01-2012)
Old 11-01-2012, 01:01 PM   #1267
jiaim
Drives: Enthusiast
found the pic
Old 11-01-2012, 01:02 PM   #1268
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
IMHO, as long as it doesn't break and is reliable its a good option. But remember, this will save your compressor from surge, so why "cheap" out on a part when you are spending already close to 4K?
There are pics of the AVO mounted, it is located in a place where its not visible with open hood so it is still stealth. About the noise, I think at 5 psi, the noise won't be much.
Old 11-01-2012, 01:03 PM   #1269
AVOturboworld
Ours does recirculate, either 100% or 50/50, depending if you leave the plate on the back on or not. We've left it on on our test car for now. All the OEM units will definitely be a recirculate type.
The Following User Says Thank You to AVOturboworld For This Useful Post:
Sportsguy83 (11-01-2012)
Old 11-01-2012, 01:19 PM   #1270
Sportsguy83
Drives: Limited BRZ
If I want an aftermarket one that does not recirculate, will it bolt on or will I need a bracket or something?
The Following User Says Thank You to Sportsguy83 For This Useful Post:
ngabdala (11-02-2012)
Old 11-01-2012, 01:27 PM   #1271
AVOturboworld
It's going to depend on the unit. A design like the bosch one pictured above would slot right in without any issues. Other flanged designs would need an adapter plate of some sort.
Old 11-01-2012, 03:14 PM   #1272
Asphaltfrs1
Asphaltfrs1's Avatar
Drives: 2013 asphalt fr-s
I'm a bit confused. So the kit already comes with the Bosch one, right?
Also, I've noticed that the AVO BRZ has an upgraded LSD. Will we need to upgrade that too, or will the stock one do the job?
Asphaltfrs1 is offline   Reply With Quote
Old 11-01-2012, 03:34 PM   #1273
Opposed
Drives: 2013 Asphalt FR-S
The stock one will be just fine.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 11-01-2012, 04:34 PM   #1274
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
now some videos on launching, driving, revving, and drive-bys and i will be 200% sold on this kit, already being at 100%
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
