Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 10-29-2012, 10:46 AM   #1
Xauterus
Drives: GTS 86 Galaxy Blue
My Work Wheels on Galaxy Blue , Now lowered
Hello Guys,
I thought I would post some pictures up on my gts with satin black Work wheels. I was inspired to get these wheels after seeing the original Work promotional car with the 18x9.5 wheels.
I just wanted a little bit more practical fitment so got a set through the group buy. It is still totally stock suspension wise, but i do have Tein Flex coil overs to put on with Cusco rear lower arms and bracing. I wanted to see how differnet it felt compred to the stock size/ rims.
I used 245/35 18 in Pirelli Corsa tyres all round. The rears are stretched and the fronts sit nice and square.
Xauterus is offline   Reply With Quote
The Following User Says Thank You to Xauterus For This Useful Post:
Surok (10-29-2012)
Old 10-29-2012, 06:10 PM   #2
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
So what size are these? Offset and width specs. The group buy stuff got deleted so I'm not sure what the specs were..
I like that it looks good at stock suspension too.. I'm scared of buying things that rely on alignment settings to even fit.. when you are paying 700 a wheel, I don't want to be defected for them haha
Surok is offline   Reply With Quote
Old 10-29-2012, 07:06 PM   #3
Z86
Drives: 86 GTS Auto in Pegasus White
Needs lowering imo
Z86 is offline   Reply With Quote
Old 10-29-2012, 07:07 PM   #4
Z86
If it was the group buy they were 18x8.5 +38 front and 18x9.5+ 38 back
Old 10-29-2012, 07:41 PM   #5
coyote
coyote's Avatar
Drives: Slowly
Are they Directionale front and rear, or did you find some Asymmetricos?
I'm thinking about trying Directionale on the rear despite Pirelli not recommending it.
Where did you get them?
coyote is offline   Reply With Quote
Old 10-29-2012, 07:53 PM   #6
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
its the car noticeably slower now? does it slow it down enough to become annoying?
Old 10-29-2012, 08:55 PM   #7
Nardi330
Nardi330's Avatar
Drives: 86
nice. how low are you planning to drop it with the teins?
Nardi330 is offline   Reply With Quote
Old 10-29-2012, 09:02 PM   #8
Xauterus
They are the directional tyres all round. I figure with the modest horse power and weight of the car they will be good.
How would this make the car slower? The feel pretty much the same weight as the original factory wheels and tyres. The diameter is within 4mm. If anything it makes it quicker in a straight line due to the grippier tyre. I fitted them last night so have not had a chance to try it out on a twisty road.
Remember toyota intentionally fitted a tyre with limited grip so customers could feel the limits much more easily. I am sure its not going to be as easy to drift.
Needs to be lowered? I am fitting tein coil overs. I want to develop this car in steps so I can understand what each change does to the cars handling. I will fit the coil overs then go back to the original tyres to see how it compares. I cant see me dropping it more than 25mm. It already has a long low nose that scrapes driveways stock.
Old 10-30-2012, 08:55 AM   #9
ZZT86
ZZT86's Avatar
Drives: BR86
Looks good although 8.5" all round would have suited better imo. Ride height looks OK, but for street cred it would need lowering about 20mm. They're a really good looking wheel the Kiwamis.
ZZT86 is offline   Reply With Quote
Old 10-30-2012, 08:10 PM   #10
Xauterus
I'm not completely sold on the rim edge poking out. A + 50 rim would have looked better on the rear I think.
If it makes it to the track I would get a set of enkei rpf1 in 17 x8
Old 10-30-2012, 09:47 PM   #11
Nardi330
Nardi330's Avatar
Drives: 86
probably +45 would what you are after.
but looking at WheeDude's thread he has been running many 9.5+38 wheels but they don't poke out much. i guess he runs a bit of negative camber and it will be better once lowered.
Old 10-30-2012, 10:17 PM   #12
Xauterus
Yes I'm hoping it will look better when lowered. I have the cusco lower arms to fit too.
Old 10-30-2012, 10:28 PM   #13
Nardi330
Nardi330's Avatar
Drives: 86
where are you getting your suspension parts installed and wheel alignment done?
thanks
Old 10-31-2012, 12:09 AM   #14
Xauterus
I will be installing them. I'm hoping a mate of mine at Leda suspension will have time to align it and corner weight it.
He is out at brendale.
Just running short of time before noosa hill climb
Nardi330 (10-31-2012)
GALAXY BLUE SILICA BRZ Compilation Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 595 12-08-2022 06:55 AM
Galaxy Blue - NZ diss7 AUSTRALIA 5 09-25-2012 07:51 AM
Sonic Blue 86, Galaxy Blue deleted? 450hp/tonne AUSTRALIA 14 09-01-2012 08:10 PM
Galaxy Blue VINs? dorkymork BRZ First-Gen (2012+) — General Topics 49 06-02-2012 10:55 PM
Are 17" wheels too big? Might work 16's work a little better? rogerdalien Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 46 05-10-2012 11:09 PM
