CANADA Canada
Old 10-29-2012, 02:23 PM   #71
dcfr
dcfr's Avatar
Drives: Ultramarine FR-S
Originally Posted by SPEEDGOD View Post
not bad, I'm planning to get Hankook, 215/55/16 for $760 what you guys think?
Speedometer & diameter change are about 2.8% change. It's not ideal in my POV. But still okay if no other possible choice.
dcfr is offline   Reply With Quote
Old 10-29-2012, 03:53 PM   #72
SPEEDGOD
I don't lie.
SPEEDGOD's Avatar
Drives: AE86 Successor
Originally Posted by dcfr View Post
Tires only? Before or after tax?
for everything including steeles, including tax
What are my options? Hopefuly it doesn't snow but I doubt it
SPEEDGOD is offline   Reply With Quote
Old 10-29-2012, 04:13 PM   #73
engsr
Drives: Subaru BRZ
205/55 R16 is closer to the stock size, based on the numbers. However not all tires with the same specs are the same size (ie. they differ between manufacturers) so YMMV.
Bryan.
engsr is offline   Reply With Quote
Old 10-29-2012, 04:33 PM   #74
dcfr
dcfr's Avatar
Good deal on that. But probably not on that size.
Yes. 205/55/16 is a better candidate. And it depends on which brand too. Some brand name offered great specs.
Old 10-29-2012, 08:53 PM   #75
captslow
Anyone know where I can get center caps (not hub caps) for steel wheels? JDM BRZs come with them standard. http://www.subaru.jp/brz/brz/img/ph14.jpg
captslow is offline   Reply With Quote
Old 10-29-2012, 11:30 PM   #76
SPEEDGOD
I don't lie.
SPEEDGOD's Avatar
sweet idea! I tried ebaying it, can't find any
Old 10-29-2012, 11:59 PM   #77
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Try Kijiji for some used tires.
Last week I sold my virtually brand-new set of 18" tires from my previous Genesis within days, and also managed to find a set of very slightly used Michelin Primacy Alpins in our OEM 215/45R17 size including steelies for $200!
Slick is offline   Reply With Quote
Old 10-30-2012, 12:32 AM   #78
SPEEDGOD
I don't lie.
SPEEDGOD's Avatar
Nice can we find me a set? Thanks!
Old 10-30-2012, 12:55 AM   #79
Aznek
Drives: 2013 White Scion FRS
Unless my dad can get rid of one of his vehicles, I think I may be in need of some steelies as well.
I did a little bit of research but I still don't think I know what I am doing. Costco is having a sale on steelies right now. According to their sizing guide http://www.costco.ca/wcsstore/Costco.../100018256.pdf there isn't a recommended wheel out for the FRS or the BRZ currently. I have however, heard of people just swapping other Subaru wheels for use on the FRS/BRZ so it should be the same no? The only difference I see is the hex and the bolt diameter?
Anyways, they recommend the X40867T as 16" for all the Subaru vehicles and as per their online store, http://www.costco.ca/Steel-Wheels.pr...100018256.html these things are $18.99 a piece!
In addition to that, Canadian Tire's got the Michelin Xice Xi2s on sale at around ~$130 a tire.
What do you guys think?
Aznek is offline   Reply With Quote
Old 10-30-2012, 03:02 AM   #80
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
I have seen x40867 listed with both 57.1 mm bore and 56.1 mm bore? FRS/BRZ measures out about 55.98 so a 56.1 wheel bore would be more hub-centric than 57.1?
X40867 SUBARU SILVER WHEEL 16x6.5, 5x100, B57.1
X40867T FORESTER WHEEL 16x6.5, 5x100, B57.1
http://winter-tires.pmctire.com/enw/...1-2-5-100.tire shows 56.1 bore and 45mm offset.
I also found a reference to an x66008 steel wheel that appears to be listed with 56.1 bore? It also appears to have a 50mm offset. There appears to also be a x6608-1 which is the same but with a 42mm offset.
There also appears to be a 17" steel wheel x99150N which should fit but may be rather heavy compared to a 16" steel wheel.
I haven't been able to find anything that talks about how loose is too loose to be considered a proper hubcentric fit.
smbrm is offline   Reply With Quote
Old 10-30-2012, 07:35 AM   #81
Enemies
Drives: '13 SWP Sport-Tech (Limited)
I am interested in this as well. I looked into the X40867T and they are $23.99 each for me but hell, I'm not going to bicker over $5/wheel. I was expecting to have to pay much more than that.
Nothing is listed for the BRZ but it looks like that fits all the Subaru's so it should be fine for the BRZ as well, right?
Nice find on the $130 tires as well.
Depending on what you guys say I may very well be ordering me some wheels this morning. Hope somebody in the know replies!
Enemies is offline   Reply With Quote
Old 10-30-2012, 08:41 AM   #82
Aznek
Damn, it was 18.99 last night. It must have gone up since.
Anyway's I'm waiting to jump as well, as soon as an expert gives their advice.
Old 10-30-2012, 09:29 AM   #83
engsr
Drives: Subaru BRZ
The rims don't have to be hubcentric - all that does is allow an easier alignment to the hub studs/wheel holes. So as long as you align the lugs/studs/wheel holes before torquing the lug nuts you won't have any issue.
Bryan.
Old 10-30-2012, 11:09 AM   #84
captslow
Both X40867T and X40867 are gray wheels though
FS: 245/40/18 Michelin Pilot Alpin PA3 Snow Tires Chuynh207 Wheels and Tires 3 11-06-2012 01:19 PM
snow tires debs0712 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-18-2012 12:58 PM
what tires will you be using this winter for snow? denverizzles Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 08-01-2012 11:20 PM
How effective are snow tires? theredtape Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 06-18-2012 07:49 PM
Snow tires? smbrm CANADA 12 05-27-2012 01:20 AM
