Drives: JDM LN130 Toyota Hilux Surf
Perrin Transmission Support & Whiteline Gearbox Positive Shift Kit
So,
Perrin Transmission Support [PSPDRV160] http://www.perrinperformance.com/brz...mission-stiffy Whiteline Gearbox Positive Shift Kit Bushing [KDT926] http://www.whiteline.com.au/product_..._number=KDT926 1) Which is better? 2) Which would you do first? 3) Are they compatible? (would you do them both?) 4) Do they do the same thing in a different way? cheers, Jehu |
#2 |
i'm sorry, what?
Drives: Canada
i think both companies are lazy and i'm waiting for one that would just make a caged unit like the beatrush stuff for the subarus
#3 | |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
Disclaimer, these are my opinions 1) I haven't tried the Perrin (yet), but I do have the Whiteline. Looking at the design and imagining how they work, I think the Whiteline is better if you must choose between the two 2) Whiteline for sure. The Perrin alone appears* to replace the silver piece in the picture, which fills in the lateral space between the pointed parts of the Rear No.1 Engine Mounting Insulator. If the Whiteline (yellow) wasn't there, then to me, the Perrin looks reduces rotational flexing. The insulator itself is fairly soft materials so the Whiteline here reduces that rotational flexing and vertical compression by filling in all that empty space. Both do their part to add mass to dampen vibrations which I believe is their primary intent. The Perrin being made of aluminium may add more mass than the urethane in the Whiteline. 3) I think they are mechanically compatible. I will know by the end of the weekend as the part is coming in. Would I do them both? won't know until it happens 4) Yes. Stock Rear No 1 Engine Mounting Insulator. Whiteline fills in gap. Perrin replaces the metal piece and shank. The inward angle vertical walls are soft rubber ![]() 20121012-WhitelinePositiveShiftKit_DIY-01 by VictorN07, on Flickr ![]() 20121012-WhitelinePositiveShiftKit_DIY16 by VictorN07, on Flickr
| The Following 3 Users Say Thank You to F1point4 For This Useful Post: |
#4 |
Drives: FRS
Looks like they will work together. That would be a great combination if so. Bump for someone that knows more than me to confirm.
#5 |
SLO NO MO
Rather than get these two together, I'd get the Whiteline Positive Shift Kit (which I actually do have currently on my car) and get the Perrin Rear Shifter Bushing along with it: http://www.perrinperformance.com/p/2175
I think those two together would give you a better benefit than these two things which appear to do the same thing (if they can even work together at all, that is). |
| The Following User Says Thank You to Foobar For This Useful Post: | Superhatch (10-29-2012) |
#6 |
Drives: 86
perrin mentioned there is a possibility the urethane will squeak after a while. is that true? i know they make urethane parts so they could've made this part urethane as well but chose not to. could that be the reason?
#7 |
Photo Specialist
That's spot on. Any bushings, bearings, and inserts will squeak over time. This is why it is important to apply grease to the surface when installing them, and periodically checking and regreasing as required. Mind y'all that we are talking about a few years, not every few months. If the Perrin doesn't require greasing, then for the set and forget it lot, that would be the better option.
#8 |
Drives: 86
could they be used together for improved stability? or would it make it too stiff to be comfortable
#9 |
AIM4APX
Drives: 2013 WRB BRZ Limited
I went the route Foobar described above. I'm installing this weekend and I'll add my review here.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
#10 | |
Photo Specialist
#11 |
i'm sorry, what?
Drives: Canada
btw i wouldn't do this mod without engine mounts
you need to stiffen both, otherwise you're creating a hard point at the transmission while the engine remains soft, causing stress all over the place.
| The Following User Says Thank You to 7thgear For This Useful Post: | PoorMansRacing (12-16-2013) |
#12 | |
Drives: FRS
#13 |
#14 |
Drives: '95 Honda Civic HB/'13 Subaru BRZ
Cusco kinda went the middle route on theirs, didn't they? Big washer to stiffen the void.... Sleeve and metal bracket to stiffen that silver bolt/plate.
| Whiteline Positive Shift Kit DIY | F1point4 | DIY (Do-It-Yourself) Guides | 95 | 04-26-2021 01:05 PM |
| Installed the Whiteline transmission bushing(no pics sorry) | gmookher | Engine, Exhaust, Transmission | 9 | 06-27-2013 02:30 AM |
| Whiteline|Cusco|TEIN|Perrin|KW & More! All your suspension needs here @ CMS | Circuit Motorsports | Brakes, Suspension, Chassis | 64 | 12-18-2012 02:25 PM |
| Whiteline Positive Shift Bushing? | wootwoot | Engine, Exhaust, Transmission | 20 | 11-05-2012 07:45 PM |
| IN STOCK!!! Whiteline FR-S/BRZ Positive Traction and Shift Kits! | 10k Redline | Brakes, Suspension, Chassis | 6 | 10-16-2012 05:32 PM |
