Old 10-26-2012, 03:16 PM   #1
gmookher
Installed the Whiteline transmission bushing(no pics sorry)
[ame="http://www.youtube.com/watch?v=dLzMO6_ZNHk"]BRZ / 86 / FR-S Whiteline Positive Shift Kit - YouTube[/ame]
is it easy to install? yes very, but you need to ensure that you support the tranny
the included instructions are spot on, tho I took off the front bolts to my midpipe to gain access to the area where the bolts and the insert goes, made my life easier
about an hour using some power tools(recommended, them bolts tight)
used jack stands and ramps and a jack
it slips into the 'void' and reeally compliments the Perrin rear shifter bushing
its actually very small and makes a huge difference, props to whiteline
together these two make the tranny feel solid
thanks to both Vendors, money well spent
gmookher is offline   Reply With Quote
Old 10-26-2012, 03:27 PM   #2
fenton
Did you stall it with the white line at the start? that sounded awful
fenton is offline   Reply With Quote
Old 10-26-2012, 03:31 PM   #3
gmookher
its a video from whiteline, I am just reposting it
this is a positive upgrade and no brainer at its bargain cost and easy drive way install
not often I stall my car ........LOL
Old 10-26-2012, 05:04 PM   #4
Celica00
Celica00's Avatar
Drives: 86
would this mod void warranties?
Celica00 is offline   Reply With Quote
Old 10-26-2012, 05:14 PM   #5
Foobar
SLO NO MO
Foobar's Avatar
No, it's just a plastic rubber thingie that goes in that space to make the fit more snug.
I had mine put in while my catback was being installed. I regret not doing the Perrin Rear Shifter Bushing at the same time.
Old 10-26-2012, 05:22 PM   #6
Pete156
I like to eat!
Will the Perrin fit with this in place?
Pete156 is offline   Reply With Quote
Old 10-26-2012, 05:24 PM   #7
Foobar
SLO NO MO
Foobar's Avatar
Goes in a different place, but now I have to lift the car up and take everything apart to get to it if I want to install the Perrin now. I had the opportunity when the Catback was out, should've done it all then.
Old 01-13-2013, 01:18 PM   #8
whataboutbob
AutoX-10/10ths every run
I've noticed a bit more vibration in the cabin after the Whiteline tranny bushing install, especially at startup and idle. I suspect this is to be expected due to the bushing stiffening up the drivetrain. Anyone else notice this?
Build thread:Here
Old 01-13-2013, 02:05 PM   #9
Foobar
SLO NO MO
Foobar's Avatar
I have not noticed this with mine. Had it on for about 2000 miles now.
Old 06-27-2013, 02:30 AM   #10
empower-auto
Kouki-Monster
empower-auto's Avatar
I noticed it immediately. NVH goes up for sure.
However .. for how awesome the shifts feel now .. especially 1-2-3 ... who cares!
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Whiteline rear subframe bushing install... fl_speed001 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 07-11-2020 12:29 AM
Installed Perrin shifter bushing & Fumoto oil drain valve zooki Engine, Exhaust, Transmission 23 03-31-2013 05:18 PM
Whiteline Positive Shift Bushing? wootwoot Engine, Exhaust, Transmission 20 11-05-2012 07:45 PM
