Old 10-29-2012, 10:15 AM   #1
jehu
Drives: JDM LN130 Toyota Hilux Surf
Perrin Transmission Support & Whiteline Gearbox Positive Shift Kit
So,
Perrin Transmission Support [PSPDRV160]
http://www.perrinperformance.com/brz...mission-stiffy
Whiteline Gearbox Positive Shift Kit Bushing [KDT926]
http://www.whiteline.com.au/product_..._number=KDT926
1) Which is better?
2) Which would you do first?
3) Are they compatible? (would you do them both?)
4) Do they do the same thing in a different way?
cheers,
Jehu
jehu is offline   Reply With Quote
Old 10-29-2012, 10:21 AM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
i think both companies are lazy and i'm waiting for one that would just make a caged unit like the beatrush stuff for the subarus
Old 10-29-2012, 10:37 AM   #3
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Originally Posted by jehu View Post
1) Which is better?
cheers,
Jehu
Disclaimer, these are my opinions
1) I haven't tried the Perrin (yet), but I do have the Whiteline. Looking at the design and imagining how they work, I think the Whiteline is better if you must choose between the two
2) Whiteline for sure. The Perrin alone appears* to replace the silver piece in the picture, which fills in the lateral space between the pointed parts of the Rear No.1 Engine Mounting Insulator. If the Whiteline (yellow) wasn't there, then to me, the Perrin looks reduces rotational flexing. The insulator itself is fairly soft materials so the Whiteline here reduces that rotational flexing and vertical compression by filling in all that empty space. Both do their part to add mass to dampen vibrations which I believe is their primary intent. The Perrin being made of aluminium may add more mass than the urethane in the Whiteline.
3) I think they are mechanically compatible. I will know by the end of the weekend as the part is coming in. Would I do them both? won't know until it happens
4) Yes.
Stock Rear No 1 Engine Mounting Insulator. Whiteline fills in gap. Perrin replaces the metal piece and shank. The inward angle vertical walls are soft rubber
20121012-WhitelinePositiveShiftKit_DIY-01 by VictorN07, on Flickr
20121012-WhitelinePositiveShiftKit_DIY16 by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
The Following 3 Users Say Thank You to F1point4 For This Useful Post:
20valvewynn83 (11-02-2012), JPxM0Dz (10-29-2012), Tristor (03-25-2019)
Old 10-29-2012, 04:41 PM   #4
wootwoot
Drives: FRS
Looks like they will work together. That would be a great combination if so. Bump for someone that knows more than me to confirm.
Old 10-29-2012, 04:55 PM   #5
Foobar
SLO NO MO
Foobar's Avatar
Rather than get these two together, I'd get the Whiteline Positive Shift Kit (which I actually do have currently on my car) and get the Perrin Rear Shifter Bushing along with it: http://www.perrinperformance.com/p/2175
I think those two together would give you a better benefit than these two things which appear to do the same thing (if they can even work together at all, that is).
The Following User Says Thank You to Foobar For This Useful Post:
Superhatch (10-29-2012)
Old 10-29-2012, 05:02 PM   #6
Celica00
Celica00's Avatar
Drives: 86
perrin mentioned there is a possibility the urethane will squeak after a while. is that true? i know they make urethane parts so they could've made this part urethane as well but chose not to. could that be the reason?
Celica00 is offline   Reply With Quote
Old 10-29-2012, 05:09 PM   #7
F1point4
Photo Specialist
F1point4's Avatar
That's spot on. Any bushings, bearings, and inserts will squeak over time. This is why it is important to apply grease to the surface when installing them, and periodically checking and regreasing as required. Mind y'all that we are talking about a few years, not every few months. If the Perrin doesn't require greasing, then for the set and forget it lot, that would be the better option.
Old 10-29-2012, 05:28 PM   #8
Celica00
Celica00's Avatar
Drives: 86
could they be used together for improved stability? or would it make it too stiff to be comfortable
Old 10-29-2012, 05:40 PM   #9
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
I went the route Foobar described above. I'm installing this weekend and I'll add my review here.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 10-29-2012, 05:48 PM   #10
F1point4
Photo Specialist
F1point4's Avatar
Agree both of those is a very good route. Sharpens things up a bit in the gearbox but I just found there is still room for improvement.
Old 10-29-2012, 05:49 PM   #11
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
btw i wouldn't do this mod without engine mounts
you need to stiffen both, otherwise you're creating a hard point at the transmission while the engine remains soft, causing stress all over the place.
The Following User Says Thank You to 7thgear For This Useful Post:
PoorMansRacing (12-16-2013)
Old 10-29-2012, 06:26 PM   #12
wootwoot
Drives: FRS
Yup. I was going to get the perrin engine mounts as well and put them all in at once. Laying the foundation for some more power once the warranty expires.
Old 10-29-2012, 06:44 PM   #13
jehu
Thanks for all your answers.
Wootwoot, I didn't think Perrin had released engine mounts yet for the FA20?
Old 11-01-2012, 11:49 PM   #14
sbxjap
sbxjap's Avatar
Drives: '95 Honda Civic HB/'13 Subaru BRZ
Cusco kinda went the middle route on theirs, didn't they? Big washer to stiffen the void.... Sleeve and metal bracket to stiffen that silver bolt/plate.
sbxjap is offline   Reply With Quote
Whiteline Positive Shift Kit DIY F1point4 DIY (Do-It-Yourself) Guides 95 04-26-2021 02:05 PM
Installed the Whiteline transmission bushing(no pics sorry) gmookher Engine, Exhaust, Transmission 9 06-27-2013 03:30 AM
Whiteline|Cusco|TEIN|Perrin|KW & More! All your suspension needs here @ CMS Circuit Motorsports Brakes, Suspension, Chassis 64 12-18-2012 03:25 PM
Whiteline Positive Shift Bushing? wootwoot Engine, Exhaust, Transmission 20 11-05-2012 08:45 PM
IN STOCK!!! Whiteline FR-S/BRZ Positive Traction and Shift Kits! 10k Redline Brakes, Suspension, Chassis 6 10-16-2012 06:32 PM
