CANADA Canada
Old 10-25-2012, 12:01 AM   #57
Enemies
Drives: '13 SWP Sport-Tech (Limited)
Originally Posted by RoryTate View Post
I picked up a set of 205/55R16 Michelin X-Ice Xi3 mounted and balanced on 16x7 Matte Graphite Silver Sparco Assetto Gara wheels (& lug nuts) from tirerack. Under $1600 to the door, ordered Thursday night, arrived Tuesday afternoon.
All fees, taxes, and brokerage included in the price.
Highly recommended for a hassle free transaction.
I looked into TireRack. Shipping was crazy though. If I had known I would've had them shipped to the States and pick them up tomorrow when I go. Oh well, gotta love 20/20 hindsight.
Probably going to trade work for a good discount on tires. Whatever they give me off tires they'll get in savings from me so it'll work out in the end.
Enemies is offline   Reply With Quote
Old 10-25-2012, 02:59 AM   #58
Enemies
Saw these at Wal-mart today... Black Steel Wheels
Size - 16 x 6.5
Mounting - 5-100
Center Bore - 57 mm
Offset - 42mm
Offset only 42 mm. Does that make these a bad choice for 205/55/16 tires?
Each wheel was $58 as well so maybe a little pricey...
I remember when deciding on a color for my car was hard... Damn decisions. :P
Old 10-27-2012, 03:55 AM   #59
Enemies
I guess $58 isn't really that pricy at all after shopping around. I guess I was thinking of something else.
No input on the 42mm offset? Thought I'd ask again because the wheels seem perfect otherwise other than the offset being less than the 45 that was recommended earlier. No clue what center bore means but I'm guessing that's fine.
Old 10-27-2012, 04:29 AM   #60
#87
I usually post drunk
#87's Avatar
offset has no effect on what size tire will fit on the rim. It only effects stance, and potentially clearance of suspension components. But the wheel is so narrow it won't be an issue.
#87 is offline   Reply With Quote
The Following User Says Thank You to #87 For This Useful Post:
Enemies (10-27-2012)
Old 10-27-2012, 12:54 PM   #61
Rossman
Rossman's Avatar
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
Originally Posted by Enemies View Post
Does that count the TPS or did you not bother? Shipping looks like it's going to be harsh. I'm going to be in the States on Thursday for the day but I doubt there's any chance I could get them shipped to a place in the States by then.
No TPMS, not worth $200+ for them!!
Rossman is offline   Reply With Quote
Old 10-27-2012, 06:17 PM   #62
roddy
roddy's Avatar
Drives: '13 Ultramarine
I installed my winter wheels/tires today. I went with a set of 16" steelies and Bridgestone Blizzak WS-60 tires (205/55/16) with some OEM Toyota TPMS. I originally wanted to go with the WS-70 tires, but got a good deal on some left over 60s. The intended fitment for the wheels was a Subaru Impreza. They fit perfectly.
Old 10-27-2012, 06:40 PM   #63
Cameronghanson
Drives: n/a
I live in detroit so we get some pretty bad winters and ive always used Continental extreme contact all seasons on my RWD cars and ive never had any issue.
Cameronghanson is offline   Reply With Quote
Old 10-27-2012, 06:44 PM   #64
wparsons
wparsons's Avatar
Another thing to consider with the TPMS is that you HAVE to have the dealer re-key the car/sensors every time you swap wheels, which can be upwards of $90 per time.
~$300 for sensors, plus at least another $100/year (assuming a deal of $50/time) is just a waste IMO.
flickr
Old 10-28-2012, 01:34 AM   #65
roddy
roddy's Avatar
It is too much money... I won't argue that, but to me the light on the dash would be more painful to look at than a bill for than less than $100 twice a year.
A friend owns a tire shop, and is sourcing tools to be able to reprogram. He also mentioned sensors coming than can mimic the code of the stock sensors. Next time I talk to him, I'll get more detail on that
Old 10-28-2012, 03:05 AM   #66
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
Size - 16 x 6.5
Mounting - 5-100
Center Bore - 57 mm
Offset - 42mm
Hub centre bore outside diameter actually measured at about 55.98mm, stock wheel inside bore diameter at 56.25mm. Tire rack suggests its 16 inch steel are 56 mm bore. Not sure whether 57mm is considered bore sloppy or not?
I don't think all steel wheels are created equal?
Another question to consider is how much change in the tread dimension from stock actually over stresses the wheel bearings?
smbrm is offline   Reply With Quote
Old 10-28-2012, 10:31 AM   #67
engsr
Drives: Subaru BRZ
Aftermarket steelies are not all the same. The set I bought from Walmart eons ago for my Integra were not hubcentric. If you get OEM steelies, they are more than likely to be hubcentric. Although I've never had any problems using non hubcentric wheels.
As far as wheel bearing stress goes, I would argue that this is negligible for normal driving circumstances. For motorsport applications, I've heard that wider wheels, stickier tires, etc. does add stress to the bearings (and other things) but at that point, you're changing those components more often because you don't want to experience any failures. But for normal street driving, I wouldn't even worry about it.
Funny, I picked up a set of older Legacy wheels yesterday and the guy's neighbour has an Ultramarine FRS.
Bryan.
engsr is offline   Reply With Quote
Old 10-29-2012, 01:00 PM   #68
grasbunkers
Drives: fr-s black
just received 4 federal himalayas from tire direct 215/45/17 91v xl ws2
for 553 all in with tax and shipping to mississuaga
seemed to have good reviews and only have a 3 yr lease on the car hopefully these will get me thru 3 winters?
grasbunkers is offline   Reply With Quote
Old 10-29-2012, 02:06 PM   #69
SPEEDGOD
I don't lie.
SPEEDGOD's Avatar
Drives: AE86 Successor
not bad, I'm planning to get Hankook, 215/55/16 for $760 what you guys think?
SPEEDGOD is offline   Reply With Quote
Old 10-29-2012, 02:17 PM   #70
dcfr
dcfr's Avatar
Drives: Ultramarine FR-S
Tires only? Before or after tax?
dcfr is offline   Reply With Quote
FS: 245/40/18 Michelin Pilot Alpin PA3 Snow Tires Chuynh207 Wheels and Tires 3 11-06-2012 01:19 PM
snow tires debs0712 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-18-2012 12:58 PM
what tires will you be using this winter for snow? denverizzles Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 08-01-2012 11:20 PM
How effective are snow tires? theredtape Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 06-18-2012 07:49 PM
Snow tires? smbrm CANADA 12 05-27-2012 01:20 AM
