Old 10-24-2012, 03:57 PM   #15
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
I wonder if these would work
http://www.licmotorsports.com/produc...sti_lic-042012
No Limit Motorsport is offline   Reply With Quote
Old 10-24-2012, 04:16 PM   #16
jamal
jamal's Avatar
Drives: Legacy GT
No, and those are for people using sti bearings and uprights that want to keep 5x100. The front brz uprights are completely different and sti or tribeca hubs don't bolt in. The only way to do it would be to make a custom upright. The rear sti hub and bearing might work. Someone just has to go try it.
Doing it just for the bolt pattern is pointless. The reason to upgrade on a wrx is for the stronger bearings, and unless people start blowing them out after a couple track days no one's going to bother with a conversion.
jamal is offline   Reply With Quote
Old 10-24-2012, 04:18 PM   #17
Bomb3r
Bomb3r's Avatar
Drives: Australian GT86
Originally Posted by No Limit Motorsport View Post
Opposite to what every one wants arent they?!
bulletproofautomotive have the Kicks 100 - 114.3 spacers.
Bomb3r is offline   Reply With Quote
Old 10-24-2012, 04:23 PM   #18
No Limit Motorsport
Damn your right. I thought it was machined down 5x114 hubs to fit 5x100.
Every Mackin dealer has those spacers but as pointed out they ruin the ability to run decent offset wheels. A few months ago they talked about 10mm conversion spacers but they have not been released as of yet.
Old 10-24-2012, 04:50 PM   #19
Bomb3r
Bomb3r's Avatar
Nissan spec wheels won't work out, but might make use of toyota spec wheels, ie: anything +40ish would then become a fuller offset for the new 86..
I have some works VSKF in 114.3 I picked up for nix that are +38 and +42, so it might be ok...
Old 10-24-2012, 05:35 PM   #20
ebphoto
Drives: FR-S, NA8, S13
even running a 15mm conversion would leave you with almost 10mm of stock stud... most wheels, cheap wheels anyway, wont allow it without a back pad that has enough room recessed to allow that much stud sticking out.
just order correct sized 5x100 wheels.
ebphoto is offline   Reply With Quote
Old 10-24-2012, 05:48 PM   #21
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Originally Posted by ebphoto View Post
in all honesty, the cost to do a conversion and then buy 5x114 wheels would be close to, if not more than buying custom offset 5x100 wheels... just saying.
Some of us already have 5x114 wheels from other cars. Currently two of my cars use 5x114 bolt pattern, but I also have two with 5x100 and two with 4x100.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
The Following User Says Thank You to Miniata For This Useful Post:
dori. (10-25-2012)
Old 10-24-2012, 06:19 PM   #22
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
Dont forget about your brake rotors...or finding some that will work with the FRS/BRZ brakes and a 5x114.3 bolt pattern.
GTM_Challenge is offline   Reply With Quote
Old 10-24-2012, 07:36 PM   #23
jamal
jamal's Avatar
Drives: Legacy GT
That's not a problem. Front group n Subaru rotors and rears can just be re-drilled.
Old 10-24-2012, 07:42 PM   #24
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
5x114.3 conversions will continue to be an unrealistic dream for this car.
chulooz is offline   Reply With Quote
Old 10-24-2012, 07:43 PM   #25
xwd
Yeah, I'd just look at selling the wheels you have. And due to the popularity of the car there will be a gazillion 5x100 wheels out for the car in no time.
Custom uprights = $$$$
Old 10-25-2012, 08:09 AM   #26
jadewbj
jadewbj's Avatar
Yeah, I think you all would be better off selling your old rims and buying a set of the tons of 5x100 rims out and coming out.
Other than the bolt pattern there is no benefit to the hub switch so it is really only for people who have an old set of rims they are not willing to sell, not a large market.
jadewbj is offline   Reply With Quote
Old 10-25-2012, 10:10 AM   #27
GTM_Challenge
Drives: On track
It's a problem if you're at the track and crack a rotor and don't have a spare or access to a drill
Some news about the BRZ release in NZ - mispost, see front AU/NZ forums Metabrz Australia Classifieds 0 10-03-2012 01:44 AM
Chances of Someone Developing 5x114.3 HUBS (not spacers)? Entropy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-04-2012 03:35 PM
5x114.3 jdmboss86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 06-30-2012 03:12 AM
Bolt Pattern, Wheel Hubs and Studs Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 03-08-2012 02:49 AM
Replace stock hubs with different bolt patern ones? ahausheer Other Vehicles & General Automotive Discussions 10 02-07-2012 12:24 AM
