Old 10-15-2012, 02:18 PM   #15
gmookher
Love to throw it out there...
PENTOSIN +6MT= butter shifts
Old 10-15-2012, 03:14 PM   #16
xn7485
Drives: 1995 Acura Integra GS-R
Originally Posted by Grimlock View Post
What kind of bolts are the drain/fill plugs? I can't tell if they are squares, torx, or triple squares.
They're allen wrench type sockets, however I used a torx because I didn't have the right size allen wrench. Still worked perfectly fine.
xn7485 is offline   Reply With Quote
Old 10-15-2012, 05:29 PM   #17
wheelhaus
wheelhaus's Avatar
the tranny and differential fill and drain plugs are all 10mm socket-type bolts. You'll need at minimum a 10mm hex wrench, or better yet a 10mm hex socket bit (you know, for correct torques and whatnot).
edit- and the aero tray bolts are all normal 10mm bolts. A few along the forward edge are 12mm, but they do not need to be removed.
Old 10-15-2012, 08:18 PM   #18
roddy
roddy's Avatar
Drives: '13 Ultramarine
Originally Posted by Touge Factory View Post
You could try the MT-85 (75w85)
We had this in our Evo's in the winter, and honestly with chicago temps dropping below 0 at times - it's just in the matter of the fluids getting up to temp.
I thought about the MT-85. Honestly, I have no problem with the MT90 in there now. It just takes a little longer to get up to temp. I have a quart of MTL (75W80) here that I'm not doing anything with. I could try draining a quart and adding that when it gets colder out. If it makes a difference, I'll know it wants a thinner oil (at least for the winter).
Old 10-15-2012, 08:20 PM   #19
roddy
roddy's Avatar
I keep thinking about it...sooner or later, I'm gonna cave.
Old 10-16-2012, 11:33 AM   #20
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
You beat me to it!
Touge Factory is offline   Reply With Quote
Old 10-16-2012, 11:39 AM   #21
Touge Factory
Drives: ZN6
Originally Posted by einzlr View Post
People have been talking about significant brake fade; you didn't mention switching to performance brake fluid ???
We wanted to take the car in stock form to the track to get a feel for it.
The very first thing I noticed more then anything was the lack of grip on the factory tires. Will not be going to the track with them again...
Track was also wet, so I didn't get to push the brakes too hard.
We will change the fluids during our brake upgrade stage, for now we want to push the car in stock form.
The Following User Says Thank You to Touge Factory For This Useful Post:
einzlr (10-16-2012)
Old 10-16-2012, 12:08 PM   #22
einzlr
Drives: several
Gotcha, thanks. Everyone says that about the tires; a lot of people go with Star Specs. Apparently you can fit a full set of wheels/tires in the back and still have space for tools and gear
einzlr is offline   Reply With Quote
Old 10-16-2012, 03:20 PM   #23
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
We hit 500miles today, and decided to do a complete fluid change before we hit the track this weekend.
Some of the goods we used.
Removed the OEM oil filter with K&N high performance filter.
The filter is slightly taller by about 1/4"
The oil was fairly clean, with no unusual contaminants. The magnetic drain plug did a good job collecting small particulates.
We used exactly 5.5 quarts of Amsoil 0w20.
Remove the Undertray to access the transmission.
Remove drain and fill plugs:
Transmission had a good amount of particulates that came out...normal for a new tran. Oil was dark brown still translucent.
Helps if your trans is warm for the fluid to drain easily.
We used about 2.6 quarts of Redline MT90
Next is the rear diff.
Also helps here to warm up the fluid to drain more easily.
You can see how much small particulates collected on the magnetic drain plug.
We used about 1.25 quarts of the Motul Gear 300
.....ready for the track!
maybe a dumb question but how many magnetic drain plugs do you have on the car? one for the oil pan, tranny and rear diff?
FRS-HHH is offline   Reply With Quote
Old 10-16-2012, 07:11 PM   #24
Touge Factory
Drives: ZN6
FR-S comes with magnetic plugs... we didn't put any aftermarket ones.
Old 10-18-2012, 11:54 AM   #25
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
ahhh nice didnt know that
Old 10-23-2012, 11:16 PM   #26
Brzer
Drives: BRZ, 2011 Outback 3.6R
Motul for the manual tranny
Any reason you didn't use Motul Gear 300 in the manual transmission as well?
Brzer is offline   Reply With Quote
Old 10-24-2012, 02:02 PM   #27
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
+1 would like to know also
shu5892001 is offline   Reply With Quote
Old 10-24-2012, 08:06 PM   #28
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
I'm thinking its because Motul Gear 300 is GL-4 and GL-5. It contains higher amount of extreme pressure agents (EP) which contain sulfer-phosphorus compounds that is not good with yellow metals often found in synchronizers.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Motul Complete Fluid Changeover Sale! No Limit Motorsport Engine, Exhaust, Bolt-Ons 595 05-26-2017 12:11 PM
What Differential fluid is in your BRZ/FRS? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-12-2012 08:57 PM
$98 Brake Fluid Upgrade Texas BRZ Tracking / Autocross / HPDE / Drifting 15 10-22-2012 02:50 AM
Brake fluid volume celica73 Tracking / Autocross / HPDE / Drifting 1 08-20-2012 02:05 PM
