| View the official forum sponsors list |
#57 | |||
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
![]() ![]() Quote:
--Dan Mach V |
#58 |
Drives: FR-S, 6MT, White
Sorry for inundating you with questions Dan, but how is the clearance to the strut in front. Any crash bolts (since they would change strut clearance)? Also, is it the same tire size on the blue car?
#59 | ||
--Dan Mach V |
#60 |
Drives: 2013 Black FR-S
Is the blue car dropped?
#61 |
#62 |
Drives: Raven Black
Do you or will you ever make these in 17x8?
If so, PM me a price? |
#63 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I see that the weight is 37.xx lbs for the combo you have, and I see that Tire rack has the weights for the P Zero @ 28lbs for that size... just wondering how there can be such a huge 8lb discrepancy in weight for that tire from Tire Rack?
These wheels in 17x8 with about a +42mm offset would be nice...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
#64 |
Drives: Raven Black
^ those are the exact dimensions i am looking for!
#65 | |
This means that either they dont report the weights correctly or .... this rim weighs less than 17 lbs? Or the mach v scale is broken? I dunno |
#66 | |||
Our scale is not broken. I got the same weights for the OEM parts (like the stock wheel/tire) as other people on here. Quote:
--Dan Mach V |
#67 |
Drives: Raven Black
#68 |
Thanks again Dan. If possible I would like to see more pictures of the blue car, so I can see where the outside of the tires falls relative to the fenders, I would also like the know the camber and parts used on the blue car. Also, so on the White car, were the crash bolts used to make the camber more or less negative. Just trying to nail down the best possible wheel dimensions for 245-40-17 where handling is more important than looks. Seeing this I am thinking the 17x9 may be a hair too wide, maybe 17x8.5 with a 45mm offset would be perfect--if you are looking to make a new wheel
.P.S. Tire rack lists the P-zero rosso 255-40-17 as 22lb, so it's not that much of a discrepancy. |
#69 | ||||
I doubt you'll find even a 17x8.5" wheel at this price that's under 18 pounds, though. Quote:
--Dan Mach V |
#70 |
My thinking is that the crash bolts are just smaller bolts, so you should be able to use them to adjust the camber an equal amount + or - from whatever it happens to be without them. Was thinking with the com-c's you may have taken camber out with the bolts.
I may want to do just that, my car does enough highway that I really need to stay away from more than about .75 static neg in front. I was thinking about using the com-c's to add more nagative camber than I want, then use crash bolts to take some out, that way the wheel would be moved further away from the strut, letting me stay closer to the stock wheel offset, and helping to keep the tire inside the fender without using a lot of negative camber. I would still get the benefit of the castor from the com-s's. Yup, 17x8.5 wheels are about as rare as hens teeth, but hopefully you understand my reasoning, they would pull the 245's in just enough to get them between the fender and the strut, while sticking with a reasonable wheel/tire match, i.e. much better than putting the 245's on an 8" wide wheel, might be OK with 17x9 anyway, just not confident of it yet. |
| Awesome freeway encounter last night | staycrushing | Southern California | 6 | 06-08-2012 06:18 PM |
| Awesome FR-S Reveal Video | ZetaVI | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 12-10-2011 12:54 PM |
| awesome renders of ft86 WITHOUT camouflage | akkxn | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 10-22-2011 10:41 AM |
| Hennessey VelociRaptor 500: Supercharged, off-road awesome | vh_supra26 | Other Vehicles & General Automotive Discussions | 14 | 02-15-2010 11:40 AM |
