Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Wheels and Tires
Old 10-22-2012, 05:31 PM   #57
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
Originally Posted by sw20kosh View Post
Wow that looks amazing! Is that the flat black or the gunmetal rims? I was under the impression that these rims black on raven would just look aweful since the rims would just "dissappear in the blackness". Maybe the gunmetal ones would "pop" out more against the raven color.
Those are black. Keep in mind that lighting conditions will change the way it will look. Gunmetal will certainly give you a little more contrast.
As far as tire size... Are you implying that since the rears are close to rubbing at 255 that the fronts are even closer to rubbing with 255?
Both are pretty close.
What sorta camber settings are you seeing after dropping on your mach v springs?
Some decent camber (1.75 degrees) in the back, but only a smidge (0.2 degrees) up front without any other hardware. We got an extra degree from the Whiteline Com C mounts.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
Old 10-23-2012, 10:46 AM   #58
Mechazawa
Drives: FR-S, 6MT, White
Sorry for inundating you with questions Dan, but how is the clearance to the strut in front. Any crash bolts (since they would change strut clearance)? Also, is it the same tire size on the blue car?
Mechazawa is offline   Reply With Quote
Old 10-23-2012, 02:42 PM   #59
Mach V Dan
Yes, it has the bolts in front. It's tight clearance, but not touching anything.
The blue car has 245/40R17.
--Dan
Mach V
Old 10-23-2012, 07:22 PM   #60
sw20kosh
Drives: 2013 Black FR-S
Is the blue car dropped?
Old 10-23-2012, 11:08 PM   #61
Mach V Dan
Yes, on Mach V springs.
In general, if a FR-S or BRZ doesn't look like it's wearing high-water pants, it's dropped.
--Dan
Mach V
The Following User Says Thank You to Mach V Dan For This Useful Post:
M3power326 (11-25-2012)
Old 10-23-2012, 11:12 PM   #62
CBR600RR
Drives: Raven Black
Do you or will you ever make these in 17x8?
If so, PM me a price?
The Following User Says Thank You to CBR600RR For This Useful Post:
spdfreak (06-24-2014)
Old 10-24-2012, 12:53 AM   #63
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I see that the weight is 37.xx lbs for the combo you have, and I see that Tire rack has the weights for the P Zero @ 28lbs for that size... just wondering how there can be such a huge 8lb discrepancy in weight for that tire from Tire Rack?
These wheels in 17x8 with about a +42mm offset would be nice...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 10-24-2012, 12:55 AM   #64
CBR600RR
Drives: Raven Black
^ those are the exact dimensions i am looking for!
Old 10-24-2012, 12:43 PM   #65
sw20kosh
I actually haven't seen a single 255/40/17 tire on tire rack weigh less than 25 lbs.
This means that either they dont report the weights correctly or .... this rim weighs less than 17 lbs? Or the mach v scale is broken? I dunno
Old 10-24-2012, 01:16 PM   #66
Mach V Dan
That was a first-article wheel that was slightly lighter than the final production wheel, and a used tire, and the tire was old. I don't know if the tire was an older, lighter design, but it definitely was not at full tread depth. Our production wheels weigh 17.8 pounds.
Our scale is not broken. I got the same weights for the OEM parts (like the stock wheel/tire) as other people on here.
We might do this in the future, but it'll be at least a few months off.
--Dan
Mach V
Old 10-24-2012, 01:22 PM   #67
CBR600RR
Drives: Raven Black
--Dan
Mach V
Hurry !!!!!!:happy0180:
DAEMANO (07-19-2013)
Old 10-24-2012, 05:55 PM   #68
Mechazawa
Thanks again Dan. If possible I would like to see more pictures of the blue car, so I can see where the outside of the tires falls relative to the fenders, I would also like the know the camber and parts used on the blue car. Also, so on the White car, were the crash bolts used to make the camber more or less negative. Just trying to nail down the best possible wheel dimensions for 245-40-17 where handling is more important than looks. Seeing this I am thinking the 17x9 may be a hair too wide, maybe 17x8.5 with a 45mm offset would be perfect--if you are looking to make a new wheel .
P.S. Tire rack lists the P-zero rosso 255-40-17 as 22lb, so it's not that much of a discrepancy.
Old 10-24-2012, 08:41 PM   #69
Mach V Dan
Our Mach V lowering springs. No other parts, as far as I know. It belongs to Gillman Subaru of Texas.
More! Leaving the stock bolts in makes it less.
245 fits fine on a 9" wheel. It'll be slightly plump on an 8.5 -- stock WRX STI comes with 245 on an 8.5" wheel these days.
I doubt you'll find even a 17x8.5" wheel at this price that's under 18 pounds, though.
That's cool.
--Dan
Mach V
Old 10-24-2012, 11:59 PM   #70
Mechazawa
My thinking is that the crash bolts are just smaller bolts, so you should be able to use them to adjust the camber an equal amount + or - from whatever it happens to be without them. Was thinking with the com-c's you may have taken camber out with the bolts.
I may want to do just that, my car does enough highway that I really need to stay away from more than about .75 static neg in front. I was thinking about using the com-c's to add more nagative camber than I want, then use crash bolts to take some out, that way the wheel would be moved further away from the strut, letting me stay closer to the stock wheel offset, and helping to keep the tire inside the fender without using a lot of negative camber. I would still get the benefit of the castor from the com-s's.
Yup, 17x8.5 wheels are about as rare as hens teeth, but hopefully you understand my reasoning, they would pull the 245's in just enough to get them between the fender and the strut, while sticking with a reasonable wheel/tire match, i.e. much better than putting the 245's on an 8" wide wheel, might be OK with 17x9 anyway, just not confident of it yet.
Awesome freeway encounter last night staycrushing Southern California 6 06-08-2012 06:18 PM
Awesome FR-S Reveal Video ZetaVI FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 12-10-2011 12:54 PM
awesome renders of ft86 WITHOUT camouflage akkxn Scion FR-S / Toyota 86 GT86 General Forum 9 10-22-2011 10:41 AM
Hennessey VelociRaptor 500: Supercharged, off-road awesome vh_supra26 Other Vehicles & General Automotive Discussions 14 02-15-2010 11:40 AM
