Old 10-13-2012, 09:07 AM   #57
2forme
Originally Posted by wparsons View Post
Why did it start so much earlier as well? Plus, the shape of the graph looks like it was shifted, not just where it cuts off. Even the torque dip looks shifted to the left.
lol, because Visconti tuned a bit of the torque dip out?
The lower run is just with an exhaust. The 200whp run, is I/E/Tune.
All I did was load the run files into WinPEP and screenshot it.
2forme is offline
Old 10-13-2012, 07:32 PM   #58
wparsons
wparsons's Avatar
I'm not going to keep arguing this with you... but this is what I mean. The new green lines are a trace of the blue run, shifted over to start at the same RPM as the red run. That plot looks much more like I would've expected, especially the torque curve around the dip. It starts later than stock and ends earlier and doesn't dip as much.
flickr
wparsons is offline
Old 10-13-2012, 07:47 PM   #59
2forme
I'll make this easy for you.
Here are the dyno files.
2forme is offline
Old 10-13-2012, 09:50 PM   #60
xwd
It depends on where the guy floors the car when its on the dyno. Shifting it over like that is incorrect. You can look at other plots and the torque dip never really has a later onset, it has an earlier finish after tuning. Also after shifting over the chart peak torque hits around 5000 RPM, which I've never seen on another dyno chart, it always hits right at 4700 or so RPM. So shifting it over you've made the chart look like something I would not expect given the other charts which are out there. The car makes about the same power at 2500 RPM as it does around 3000 RPM.
xwd is offline
Old 10-14-2012, 01:44 AM   #61
OrbitalEllipses
Drives: Attitude
Originally Posted by Turbowned View Post
So as of now we have 2forme's 180whp on 93 octane with SRT header-back exhaust, AFE intake, and tune, on a Dynojet. Baseline was 174whp with just exhaust? Did you take a stock baseline?
I base lined at 172whp with just an axleback at a few hundred above sea level.
OrbitalEllipses is offline
Old 10-14-2012, 08:22 AM   #62
2forme
No, I didn't bring the stock exhaust with me.
For what it's worth, I did follow the manufacturers break-in to a T and changed my oil at 1000 miles.
Unfortunately, until one of these shops actually steps up and releases a good header... I think this is the max we are going to see NA, without cracking the motor open.
It's amusing. A couple shops immediately came out with "ohh we made like 187whp on a header" and then never released them. Kinda lame if you ask me.
2forme is offline
Old 10-14-2012, 12:16 PM   #63
Turbowned
Turbowned's Avatar
A few hundred above sea level? Where were you? I thought most of Mass is at sea level...
With regards to the header, it's tough because of the cat in the factory header. If you remove that, you're gonna have some emissions problems. I know some people go cat-less and can find ways to fool the emissions tester into thinking there's no CEL, but I'm not about to do that; too much of a closet tree-hugger. I really hope someone steps up to the plate and offers a quality catted header that's 50-state friendly.
Turbowned is offline
Old 10-14-2012, 12:51 PM   #64
OrbitalEllipses
Drives: Attitude
I don't know about Mass, but in MD I'm from just above sea level to about 300 depending what part of the state I'm in.
You're not going to get a 50-state header; California just makes it too hard. Just keep a high flow cat downstream of the header.
Old 10-14-2012, 12:57 PM   #65
2forme
Not an option. I have a header back exhaust.
2forme is offline
Old 10-14-2012, 01:12 PM   #66
OrbitalEllipses
Drives: Attitude
Not an option FOR YOU. I knew I'd want a header without a cat so I opted for a high flow cat in the front pipe I purchased (it's in the garage, not on the car). Anyone who does research should come to a similar conclusion; header is worst placement of the cat, front pipe is better. Buying a front pipe without a cat is just a poor decision IMO. I wouldn't run catless, but I opt to have the cat in the less intrusive place.
Old 10-20-2012, 10:21 PM   #67
Opposed
Here's my numbers on Visconti's stg1 93 tune and aFe intake.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline
Old 10-21-2012, 11:06 AM   #68
OrbitalEllipses
Drives: Attitude
Got a winpep file for that?
Old 10-21-2012, 11:20 AM   #69
Opposed
Im sorry, I do not. This was a dyno day with over 30 cars, they just gave me a print out. I may be able to have them email me a winpep file.
Opposed is offline
Old 10-21-2012, 11:26 AM   #70
OrbitalEllipses
Drives: Attitude
Yeah see if they have the run saved. Download winpep from dynojet's site and play around with it once you receive the run file.
Fuel pump and speed sensor Tt3Sheppard Issues | Warranty | Recalls / TSB 28 04-20-2017 01:54 PM
Which gas station(s) do you OR folks pump at? m.box.design Northwest 41 05-12-2013 01:01 AM
Dynosty Pushing the Limits... Fuel Pump and Clutch Dustin@Dynosty Engine, Exhaust, Transmission 29 08-15-2012 06:53 PM
Be careful at the pump with E15 Thunderchicken Scion FR-S / Toyota 86 GT86 General Forum 9 08-10-2012 10:33 PM
Legacy low-mounted turbo oil pump aspera Engine, Exhaust, Transmission 0 06-16-2010 03:41 PM
