Old 10-19-2012, 08:55 AM   #1
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
any way to change the gear ratios in manual?
i noticed that i have to hit 3k rpm in 6th gear to go 70 mph in my car, is there anyway to reduce the rpms? or gear's ratio? or does anyone have any idea how much it would cost?
SuperDave is offline   Reply With Quote
Old 10-19-2012, 09:04 AM   #2
xpicer
xpicer's Avatar
Drives: 2013 frs white out
thats weird when in 6th at 3k im going ^80s
" Knowledge is nothing with out execution"
xpicer is offline   Reply With Quote
Old 10-19-2012, 09:06 AM   #3
Opposed
Drives: 2013 Asphalt FR-S
do you have an auto? Mu manual is above 3k at 70.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 10-19-2012, 09:08 AM   #4
Opposed
Thr easiest way would be to install a taller final drive in the diff. But your car would suffer dramatically performance wise. What is so bad about being at 3k at 70 anyway? My s2k would sit about 4800 at 70. Are you concerned with noise, gas mileage?
Old 10-19-2012, 09:10 AM   #5
xwd
I haven't seen a taller final drive offered yet, only shorter final drives.
Old 10-19-2012, 09:10 AM   #6
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
you can put on larger diamater wheels and tires
and 3k at 70mph is nothing
my VW used to do 4k at that speed and still got better gas mileage.
Old 10-19-2012, 09:13 AM   #7
SuperDave
SuperDave's Avatar
yes gas mileage mainly. i love the sound/noise of the engine and it makes me feel like i have a powerful engine by revving it highly but since i've driven an auto, it would it 70mph at 2300rpm vs the manual at 3000 so....gas mileage suffers, usually 6th is cruising mode not revving mode.
Old 10-19-2012, 09:17 AM   #8
sierra
Drives: Skoda Yeti DSG diesel 4x4
A lexus 3.727 diff is available that will drop the rpm by about 10%
6th gear will still be lower than the AT.
http://www.ft86club.com/forums/showt...s+differential
sierra is offline   Reply With Quote
Old 10-19-2012, 09:34 AM   #9
Foobar
SLO NO MO
Foobar's Avatar
You won't necessarily get better MPG with a taller ratio. Our engines make power higher along in the RPM band, putting your gearing ratio so that you're cruising at 2K RPM would make sense on a different engine, but on ours, you'd be putting more stress on the engine.
The Subaru and Toyota guys have put considerable thought into the design of the engine and its gearing. Unless you change HP output, I wouldn't really mess with gearing.
The Following User Says Thank You to Foobar For This Useful Post:
SuperDave (10-19-2012)
Old 10-19-2012, 09:51 AM   #10
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Lol top gear at 80 my Rpms are sitting at a cool 5100rpms
TouchMyHonda is offline   Reply With Quote
Old 10-19-2012, 10:07 AM   #11
OrbitalEllipses
Drives: Attitude
My dads LS does 80MPH at ~2000RPM. It has the torque to back that up though; we don't.
Old 10-19-2012, 10:20 AM   #12
sierra
The auto uses significantly less fuel than the manual with its much higher top gear and the engine is quite happy at 2000rpm. I floored it at 2000rpm in top and it just quietly picked up with no complaints.
Having said that I was expecting the manual to feel undergeared but after breaking our 110kph max limit soon after changing into third and 3 gears still to go I changed my mind.
When I change the tyres I will likely stick with 17" and 45 profile for comfort but go to say 245. That will raise the gearing by 4.2% to make the speedo about spot on if it reads the same as most and knock the 110kph revs down from about 2950? to 2826.
Edit- Of course it will still read 2950rpm or whatever it is at 110kph but the car will still be going 4.6kph faster than it was.
This site says those tyres will fit on the original 7" rims but 235 might be safer?
http://www.rimsntires.com/specs.jsp
Old 10-19-2012, 07:06 PM   #13
TouchMyHonda
Vtec Jesus
What?
Old 10-19-2012, 07:59 PM   #14
OrbitalEllipses
Drives: Attitude
What?
My dad's LS460, equipped with an 8 speed automatic, spins at 2000RPM at 80mph. 4.6L V8 engine IIRC.
Change gear ratio? Afdad120108 Engine, Exhaust, Transmission 61 08-17-2016 10:44 AM
Manual Downshifting to 1st Gear Kundiethala Scion FR-S / Toyota 86 GT86 General Forum 45 08-31-2013 07:08 PM
Guesses about Gear Ratios and Wheel Torque Deslock Engine, Exhaust, Transmission 63 08-27-2013 01:42 AM
FT86 GT manual gear indicator KamalT Engine, Exhaust, Transmission 3 10-04-2012 09:43 PM
Guesses about Gear Ratios and Wheel Torque Deslock BRZ First-Gen (2012+) — General Topics 4 12-01-2011 06:15 AM
