Old 10-18-2012, 04:27 PM   #15
low trq
Drives: 2013 Honda Fit sport
Originally Posted by bcmakesiteasy View Post
yeah I would definitely want the two tips cause i like the look of it. What other companies could you recommend that have two tips? (with good sound)
I just saw this one earlier. I can't speak smart when it comes to sound on any of these though.
http://www.ft86club.com/forums/showthread.php?t=19953
low trq is offline   Reply With Quote
Old 10-18-2012, 04:34 PM   #16
2pt5RS
Berz
Originally Posted by ABQautoxer View Post
I think an axleback like the this one would probably suit you:
http://shop.namelessperformance.com/...-w-5-mufflers/
This.
2pt5RS is offline   Reply With Quote
Old 10-18-2012, 04:41 PM   #17
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
I had the muffler delete on the car for a month. In the end the gaping hole on the passenger side of the bumper bugged me so much I switched to a Perrin catback but it was a lot more money. On the cheap there are some muffler deletes out there now and some coming soon that can do both holes (giggity) but cost just $100-150 less because its the same thing minus the cost of the muffler/fab difference. I personally dislike invidia stuff so that was never in my decision tree.
TomR
ABQautoxer is offline   Reply With Quote
The Following User Says Thank You to ABQautoxer For This Useful Post:
2pt5RS (10-18-2012)
Old 10-18-2012, 04:48 PM   #18
fmsida
Drives: 2013 DGM BRZ
I have an idea. Look into the Flowmaster 80 series crossflow, (2.5" in / 2.5" out). You can get a stainless steel one for about $100 on amazon, or summitracing.com. Take it to a muffler shop and have them cut the inlet and outlet pipes off your stock muffler and weld them into the flowmaster muffler. That way you get the sound, a little bit of weight savings, and you save money by reusing the pipes that come with the stock muffler. In all, everything should come down to less than $300.
The type of muffler you should look into is a transverse muffler, with a inlet and outlet on one side, and a outlet on the other side.
fmsida is offline   Reply With Quote
Old 10-18-2012, 04:52 PM   #19
ABQautoxer
ABQautoxer's Avatar
If you go that route, look at "turbo" style mufflers. This car with the stock midpipe is pretty quiet, so much so the delete are a very nice option. So if you get a typical muffler, you may find you can't hear your engine at all.
TomR
Old 10-18-2012, 04:54 PM   #20
bcmakesiteasy
Drives: 2013 FRS Ultramarine
what about JUST the muffler + tips? would a set up liek that produce good sound and be less than 300 bucks?
bcmakesiteasy is offline   Reply With Quote
Old 10-18-2012, 04:59 PM   #21
low trq
Thats basically an axle back.
I think you need to find someone local that has a car with an axle back and one with a track pipe and listen to each.
Old 10-18-2012, 05:08 PM   #22
fmsida
Yes. You can find good tips, either weld on or clamp on, for about $30 each. A good muffler should be around $100 +/- $20, and labor should be around $120 or less. That's around $280, and that's just what I've seen here in Houston, TX. So it may vary where you live. If you go to a muffler shop, they may have mufflers at a discounted price compared to summitracing and amazon. The tips, you are better off getting them online since those tend to be cheaper online.
Go to youtube and search flowmaster 80 series muffler, and click on the videos that have the smaller engine vehicles. you can also search magnaflow, and turbo mufflers. Always click on the videos that have cars with 4 cylinders since that will be a similar sound, not the same... but "similar".
good luck
Old 10-18-2012, 05:10 PM   #23
ModBargains
ModBargains's Avatar
Drives: FRS, M3
A flowmaster on a Tacoma is going to sound a lot different on a FRS / BRZ. But if you want to just change the sound a bit, an axle back or customer muffler setup should do the trick. Try it and let us know how it sounds!
-Frank
ModBargains is offline   Reply With Quote
Old 10-18-2012, 05:15 PM   #24
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
LOL it's amazing no one suggested, just replace the tip. It's not like OP is looking for any gain of hp or tq. Just looking for cosmetic stuff. Exhaust tips will be much cheaper rout imo
Old 10-18-2012, 05:27 PM   #25
bcmakesiteasy
good luck
THANK you! this answered my question perfectly. So it essentially doesnt matter what muffler you get correct? It'll fit any make/model?
Old 10-18-2012, 05:32 PM   #26
low trq
from the OP's first post.
but I feel like the only reason Im getting the system is for the sound it produces.
Old 10-18-2012, 05:38 PM   #27
bcmakesiteasy
would it be possible to buy either the berk or nameless track pipe muffler delete, and have a guy at the shop make it so that it the track pipe connects to both tips?
Old 10-18-2012, 05:39 PM   #28
ichitaka05
Site Moderator
ichitaka05's Avatar
&...? Exhaust tips can change the sound (to certain point). I'm not talking about those fake exhaust tips to screw it on. I'm talking about exhaust tips that you WELD it on.
opinions on rims whitefrs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-08-2012 02:58 AM
Color Opinions chipz91 Scion FR-S / Toyota 86 GT86 General Forum 25 07-30-2012 06:27 PM
Hello need opinions ABacic90 Scion FR-S / Toyota 86 GT86 General Forum 4 06-21-2012 04:23 PM
Looking for opinions on what my dealer sent me on another BRZ order. joshua BRZ First-Gen (2012+) — General Topics 19 04-17-2012 03:07 PM
Need your opinions on a new look for the site FT-MH Scion FR-S / Toyota 86 GT86 General Forum 27 03-19-2011 04:47 PM
