AVOturboworld
Old 10-18-2012, 11:56 AM   #1051
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Originally Posted by AVOturboworld View Post
The secondary cat (front pipe) was left stock. So it retains one cat in the system post turbo. From the mid-pipe back is a resonated AVO exhaust system. We've not yet announced it officially - though the muffler is done - because we are still experimenting with best sizing for N/A and Turbo setups. Right now, we are seeing better hp numbers for N/A vehicles with a smaller diameter mid-pipe setup, and better hp numbers for the turbo vehicle with a larger diameter mid-pipe setup.
Paul, thanks for replying, now it's clear
So that means upgrading the front pipe to a larger dia and free-flow catted one would gain extra power with a turbo-kit, even sticking with a stock 5psi MAP sensor.
Sounds nice & promising
Good luck at SEMA!
MSTiFK8R is offline   Reply With Quote
Old 10-18-2012, 12:08 PM   #1052
MattF
MattF's Avatar
Drives: s13<EP3<s14<RSX TYPE-S<WRX<GTI<FR-S
That is correct, that picture is of an oil reservoir tank.
The oil pump is mechanical, fully. And that's the final detail we will unveil when we are at SEMA. It's the most unique feature of the kit, and one of the reasons it's going to be so reliable.
Thank you for the update and confirming that I am not lossing my mind. The scavenger pumps are what turn me off of the low mount turbo kits but with it being mechanical that changes the story completely.
Sent from my Galaxy Nexus using Tapatalk 2
MattF is offline   Reply With Quote
Old 10-18-2012, 01:54 PM   #1053
wcbjr
Drives: 2006 Subaru LGT
Where did the AC compressor run off to? Say it ain't so.
wcbjr is offline   Reply With Quote
Old 10-18-2012, 02:25 PM   #1054
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Appears to be right where it should be.
cobrabyte is offline   Reply With Quote
Old 10-18-2012, 02:33 PM   #1055
wcbjr
Seems to be missing the ac lines and the pulley is not stock.
http://rumors.automobilemag.com/file...A20-engine.jpg
The Following 2 Users Say Thank You to wcbjr For This Useful Post:
cobrabyte (10-18-2012), czar07 (10-19-2012)
Old 10-18-2012, 02:58 PM   #1056
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I hope you understand that pic is not the final version of the kit installed and that they could have removed the lines while fitting/designing the kit, and nothing else. Tell you more, I BET you money the A/C is going nowhere.
Old 10-18-2012, 03:01 PM   #1057
wcbjr
The entire compressor is missing, and another pulley is in its place.
But you are correct, it isn't final.
Old 10-18-2012, 03:15 PM   #1058
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
I dared to overlay AVO Stage_1 digits with Crawford build motor & turbo kit
Just to show how straight the power "curve" is and how flat the torque "curve" is with AVO Stage_1 ))
No direct comparison - two different world of approach, not even talking money wise
I hope someone finds this of use
Old 10-18-2012, 03:19 PM   #1059
AVOturboworld
The AVO Japan BRZ never had an air conditioner - seriously. It's buried way back in facebook somewhere, but it's a special model sold only in Japan - shipped with steel wheels, no air conditioning.
The Following User Says Thank You to AVOturboworld For This Useful Post:
Sportsguy83 (10-19-2012)
Old 10-18-2012, 03:20 PM   #1060
AVOturboworld
Something to keep in mind about those figures, ours are in whp, and if the chart I saw posted in facebook from Crawford is correct, theirs is in crank horsepower.
Old 10-18-2012, 03:30 PM   #1061
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
I don't think it's a crank... cuz stock isn't even making no where near 200hp in the graph.
Old 10-18-2012, 03:36 PM   #1062
Opposed
Drives: 2013 Asphalt FR-S
No, that has to be crank. Torque starts at 150 which is right in line with a stock numbers. Most stock FRS/BRZ's are putting down about 130-140 wtq stock. And even though it dosn't hit its claimed 200 hp, its still north of 175-180 hp which would be pretty high for a stock one.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 10-18-2012, 03:36 PM   #1063
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Paul, sorry for maybe being too fast on deciding, I've deleted my previous graph comparison until further clarification
I was using your graph and it is telling FLYWHEEL figures as far as I can read
I need a word from you on that to redo the graph overlay
Old 10-18-2012, 03:44 PM   #1064
ichitaka05
Site Moderator
ichitaka05's Avatar
Well, I think post after your comment pretty much answered it for us :happy0180:
Opposed (10-18-2012)
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
