Cusco Auto Levelizer
Just want to let you guys know cusco has a new item available for the BRZ and FR-S.
The item is simple, it automatically adjusts the headlight beams for cars (with projector lights) that are lowered. The CUSCO Short Auto Levelizer Adjuster Rod is a Short Auto Levelizer Adjuster Rod from suspension parts specialist, Cusco. Newer model cars today come equipped with headlight level adjusting systems which automatically adjust the position of the headlights based on the position of the car. With the inclusion of this system, the headlights of a car will come out of position when the car is lowered, pointing towards the street rather than straight ahead when the system senses the rear of the car being lower than standard height. Cusco's Auto Levelizer Adjuster Rod fixes this problem, putting the headlights in a fixed position regardless of vehicle position.
#2 |
Kouki-Monster
doubles as an endlink for the ghetto fab!
Rich Anderson
EMPOWER AUTO |
#3 |
Praise Helix!
Please correct me if I'm wrong, but I thought the BRZ is manual adjustment while the 86 with HID does auto leveling. Doesn't that mean that, at least in North America, there isn't really a need for this? That is, unless someone goes with a full blown auto leveling conversion.
| The Following User Says Thank You to n2oinferno For This Useful Post: | raz0rbladez909 (10-18-2012) |
#4 |
According to cusco, its used on the premium models with the HIDs. Its supposed to correct the headlight direction when you drop your car.
#5 | |
| CuscO Sway Bar | _F-R-S_ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 10-18-2012 04:35 PM |
| Fortune Auto 500/cusco lca | yomny | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 09-09-2012 12:14 PM |
| Cusco Zero 3s on the car | Spaztastik | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 08-02-2012 02:12 AM |
| Cusco Rear Diff Covers!!! Cusco LSD Units! | vividracing | Transmission and Driveline | 0 | 06-18-2012 03:24 PM |
