Drives: Whiteout FR-S
Power Slot vs Stoptech drilled rotor
![]() ![]() I'm planning my brake upgrade to do this winter, I plan on using Ferodo D2500 pads front and rear, Goodridge or Speigler brake lines, and AP 5.1 or Motul brake fluid. I can both of these rotors for similar cost, I am leaning towards the Power Slots due to the increased surface area over the drilled rotors but I want to make sure the Power Slot is a decent quality rotor. Has anybody dealt with both brands and if so is there one you prefer? Edit: Changed the picture to the Centric blank, will be going with one of these two, no drilled Stoptechs. Last edited by JoeBoxer; 10-16-2012 at 02:13 PM. |
#2 |
Drives: 2021 Supra / 2022 Tundra
Why not OEM rotors? In my experience these types of rotors do nothing for braking. It would be worth it if they were lighter, but the slots/holes don't help and often eat pads faster.
TomR
#3 |
Site Moderator
Drives: Stuff
Centric blanks. Or the powerslots if you want something that's not a blank. I wouldn't bother with the swiss cheese junk.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#4 |
987 Motorsports
Drives: '13 WO FR-S
no drilled. not good.
slotted are good. but if you're not going crazy, just get some blanks...like dba, which are being produced...or centric.
#5 |
Kouki-Monster
drilled cracks.
get the slotted.
Rich Anderson
EMPOWER AUTO |
| The Following 3 Users Say Thank You to empower-auto For This Useful Post: |
#6 | |
Any input on pad choice? With the money saved on rotors the Ferodo's shouldn't be a problem but if there is something else i should be looking at too please let me know. I have used Hawk's in the past, not a fan of the HPS but actually liked the Performance Ceramic. |
#7 |
Kouki-Monster
Centric owns stoptech and powerslot. Just saying.
Rich Anderson
EMPOWER AUTO |
#8 |
Drives: really slow...
@JoeBoxer, any idea if there are weight savings between these brands? That would be something i'd consider as part of the decision process.
Let us know what you end up with. I believe Brembo makes blanks also but not sure on how competive they are, if even they have them for our cars yet. |
#9 |
Drives: Black 2013 FRS
Unless you have worn out the OEM rotors there is no reason to change them to either of these. You won't get more braking torque or better heat management. The only reason I can see is for bling which is fine. If that's the case go with the slotted like everyone else says. THey are less prone to cracking.
#10 |
Brembo has some drilled rotors also but they specify not for track use or with race pad compounds. I'm mainly doing the rotors for looks, the E-coating keeps them looking nicer so the centric will suffice for what i am looking for.
#11 |
I use centric premium blanks as a simple OEM replacement for my cars. Good quality rotor.
I use the stoptech street performance pads or ferodo 2500 for the street. The st pads do well and are cheap but I really like the ferodos. This is for street cars, though the ferodos can handle a light beating. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | JoeBoxer (10-16-2012) |
#12 | |
Site Moderator
Drives: Stuff
I'll be trying AP S100 street pads soon but otherwise I don't have much experience with alternate street pads. I think the ITR has some axxis somethings on it, they work fine on the street too but I'm not even sure what they are. They suck on the track tho :P
-Dave
| The Following User Says Thank You to Dave-ROR For This Useful Post: | JoeBoxer (10-16-2012) |
#13 |
Thanks guys i think you have saved me quite a bit of money, going to go with the Centric rotors front and rear mainly for looks, AP S100 pads up front, keep the oem pads on rear, and Goodridge brake lines. AP 5.1 or Motul fluid, haven't decided on that yet.
#14 |
Drives: FRS
Powerslot and Stoptech rotors are both created from the Centric Premium blank. Go with the Powerslot rotor if you want a performance rotor.
The setup you have listed above sounds great, should really improve the pedal feel |
| Son of a @#$*&!!! I found out my dealer drilled holes on the front bumper | RYU | Scion FR-S / Toyota 86 GT86 General Forum | 40 | 09-12-2012 07:23 AM |
| Front Rotor Specs - Yes i searched. | njccmd2002 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 09-03-2012 01:58 AM |
| ($10 Discount on 2nd slot) CDC Autox Sat Aug 11th Hylton HS Woodbirdge, Va | echan | Mid-Atlantic | 0 | 08-09-2012 10:57 PM |
| License Plate Holes pre-drilled straight from Japan? | Motopythons | CANADA | 3 | 07-05-2012 10:15 PM |
