Old 10-15-2012, 12:44 AM   #1
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Rear diff service
How many miles are you guys doing your rear end services at? I am thinking of changing it out at my next oil change at 7500 miles. I will probably do it every 15k after that and will be switching to Motul gear oil.
The Following User Says Thank You to JoeBoxer For This Useful Post:
gmookher (10-15-2012)
Old 10-15-2012, 06:53 PM   #2
Hanakuso
I'm also interested in what people will be using to replace the factory fill. I'm thinking of going with Toyota or Subaru but Motul and others are being considered
Hanakuso is offline   Reply With Quote
Old 10-15-2012, 06:57 PM   #3
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
We changed mine with motul at like 1,700 miles. It was nasty.
post_break is offline   Reply With Quote
Old 10-15-2012, 06:57 PM   #4
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
i changed mine at 1100
Old 10-15-2012, 07:30 PM   #5
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
Just changed mine at 1800 with Motul.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 10-15-2012, 07:31 PM   #6
YourFearlessLeader
Team ScioNRG President
YourFearlessLeader's Avatar
Drives: 2017 WRB BRZ
Isnt the factory recommendation 30,000 miles?
2017 Subaru WRB Limited BRZ w/ PP
YourFearlessLeader is offline   Reply With Quote
Old 10-15-2012, 07:48 PM   #7
JoeBoxer
JoeBoxer's Avatar
Not sure but it's best to get any metal shavings out of the rear end from initial use. I'm surprised how soon everybody else is doing it but it's a cheap and easy service that adds peace of mind especially if you drive the car hard.
Old 10-15-2012, 07:55 PM   #8
GenkiElite
GenkiElite's Avatar
Drives: 91 Corolla (dd) S14 (daily drifter)
Nasty how exactly? Diff fluid is pretty nasty right out of the bottle. I change my KAAZ 2 way every 2000 miles or after every event because its a clutch type LSD but aren't these viscous? They typically dont need that much maintenance.
GenkiElite is offline   Reply With Quote
Old 10-15-2012, 08:21 PM   #9
so26
Drives: Raven FR-S 6MT
Anyone place a magnet in the old oil and find any metal filings?
so26 is offline   Reply With Quote
Old 10-15-2012, 08:24 PM   #10
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
i think the diff drain plug has a magnet on it.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 10-15-2012, 08:36 PM   #11
SXE10
SXE10's Avatar
Drives: Altezza RS200-Z 6MT
They're a TORSEN LSD & yes they're don't require much in the way of maintenance. Just change the oil every 30K miles & they're as happy as Larry.
Redline 75w-85 would be my choice if you want to keep with the OE spec, 75w-90 if you want a bit more bite in the lsd or 80w-140 of you're taking it on the track.
SXE10 is offline   Reply With Quote
The Following 2 Users Say Thank You to SXE10 For This Useful Post:
GenkiElite (10-15-2012), YourFearlessLeader (10-15-2012)
Old 10-15-2012, 11:12 PM   #12
roddy
roddy's Avatar
Drives: '13 Ultramarine
It does. I changed mine at around 1200 miles and the fluid looked good. The magnet on the drain plug was pretty grungy though.
I went with 75W85 as suggested in the owner's manual.
The Following User Says Thank You to roddy For This Useful Post:
so26 (10-15-2012)
Old 10-16-2012, 04:19 AM   #13
siXXtoes
Ohh Snap
siXXtoes's Avatar
Drives: Argento FR-S
ill do mine at 3000 miles with motul
siXXtoes is offline   Reply With Quote
Old 10-16-2012, 04:12 PM   #14
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
This:
Because "I drive flatout."
What oil to use in your Engine, Trans, Diff? ArKiTeCkT CANADA 31 03-10-2018 04:23 PM
T1R Rear Diff colars ! AJ PwR Engine, Exhaust, Transmission 0 10-09-2012 11:00 PM
Cusco Rear Diff Covers!!! Cusco LSD Units! vividracing Transmission and Driveline 0 06-18-2012 04:24 PM
Cusco Rear Diff. Jewelry Blaaaack-BRZ Engine, Exhaust, Transmission 24 05-12-2012 04:28 PM
