Old 10-13-2012, 07:44 PM   #15
wparsons
wparsons's Avatar
Originally Posted by Miniata View Post
Not necessarily. There are plenty of lightweight 17x8 and 17x9 wheels available that are 4-5 lbs lighter than stock, allowing you to go with a heavier wider stickier tire and keep the wheel/tire weight very close to what the stock combo weighs. Even if you gain a couple of pounds per corner, it would be worth it IMHO if you're putting a lot more power down.
RFP1's in 17x8 are about 4lbs lighter per wheel than stock, and won't break the bank either.
flickr
Old 10-13-2012, 08:53 PM   #16
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Yeah, that was one of the wheels I had in mind when I wrote that post. I've had three sets of RPF1s on various cars over the years, and I'm thinking about picking up another set for my BRZ.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 10-14-2012, 05:24 AM   #17
Calum
That Guy
Drives: 2013 asphalt FRS MT
Springs & dampers, and bushings tuned to prevent wheel hop can have a large effect on how much power you can put down. Tire compound and construction will have more effect then size.
Old 10-14-2012, 07:59 AM   #18
wparsons
wparsons's Avatar
OZ Allegrita's are also very light, but they're about $500/set more and I don't like them *that* much more.
flickr
Old 10-14-2012, 08:20 AM   #19
TuxedoCartman
Drives: '13 86
Originally Posted by driver01 View Post
Now that our cars are increasing in power by all the engine bolt ons, turbo kits and superchargers. I was thinking what would be required to put this new found power to the ground and actually use it. what do you think will help? or what do you think should be done?
- Stickier tires
- wider tires
- stiffer rear subframe bushings
- stiffer differential bushings
- slight change in ride height to change weight distribution to rear
- increase squat under acceleration (maybe softer rear springs or stiffer front springs, or maybe not since understeer will increase)
- will sway bars have any effect on this?
- traction bars?
- alignment? maybe less camber on rear tires?(though it might loose some cornering speed)
- will stiffer engine mounts help?
- will stiffer transmisison mounts help?
One thing I noticed is missing from your list: big, goofy spoiler.
TuxedoCartman is offline   Reply With Quote
Old 10-14-2012, 08:57 AM   #20
low trq
Drives: 2013 Honda Fit sport
Originally Posted by Tansey86 View Post
450 wheel and traps 130...yeah defiantly flawed.
How fast would a formula 1 car trap? I'm sure you can figure out my point
low trq is offline   Reply With Quote
Old 10-14-2012, 02:54 PM   #21
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Alright man I understand your points, and they are completely valid. I also understand that people have different wants out their cars. The s2000 wasn't made for drag, but does amazing. This car will be used for mostly circuit, road course racing, not drag, but it cant be denied that its already proved to be a valid platform in that field.
We will all use this car for different reasons, and if it works it works If we all did the same thing with our cars, it would get boring real quick.
Tansey86 is offline   Reply With Quote
Old 10-14-2012, 03:35 PM   #22
Unleashed
Unleashed's Avatar
Drives: 13' WRX
Nitto NT555's are really sticky and should cost about 165 a piece, very affordable and will last a decent amount. I haven't broken mine loose yet and it corners even more amazingly. I've got way more cornering confidence, which you don't seem too worried about, but thought it was worth mentioning.
I've also got the Cusco powerbracing and that really stiffened the chassis up. Also look into whitelines bushings, specifically the tranny mount bushing. Takes some slop out of the tranny under acceleration which translates to better power delivery.
Unleashed is offline   Reply With Quote
Old 10-14-2012, 04:34 PM   #23
low trq
I completely agree and I will go to the drag strip at some point (just for fun). It's funny you mention S2000, because thats the car I just sold to get the FR-S
Old 10-14-2012, 05:10 PM   #24
Tansey86
Tansey86's Avatar
Haha nice, they are both great cars. Let us know how you do.
ITB, how much more power? 1660 Engine, Exhaust, Transmission 119 01-22-2014 05:38 AM
What is your prediction on FT86 power and Subaru 086a power? 86Fan Scion FR-S / Toyota 86 GT86 General Forum 88 08-26-2013 11:49 PM
engine power bill323 Scion FR-S / Toyota 86 GT86 General Forum 25 08-06-2012 02:39 PM
BRZ STI NA with more power Harinjo BRZ First-Gen (2012+) — General Topics 79 12-22-2011 04:24 PM
is your new M3 down on power? NESW20 Other Vehicles & General Automotive Discussions 6 12-27-2009 10:03 AM
