Old 10-12-2012, 04:33 PM   #29
cruzinbill
Drives: Argento 6spd FR-S
Originally Posted by jarviz View Post
yup, such . any 3rd party coolants that can be used instead?
thats really not that much since it has an 11 year life.
cruzinbill is offline   Reply With Quote
The Following User Says Thank You to cruzinbill For This Useful Post:
Opie (10-07-2013)
Old 10-12-2012, 05:59 PM   #30
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Agreed why would you want to risk putting an inferior coolant in when it lasts basically the life of the vehicle, i love my car but doubt i have it in 11 years.
Old 10-13-2012, 09:04 PM   #31
FantomRider
White Fantom
FantomRider's Avatar
Send a message via Yahoo to FantomRider
Originally Posted by F1point4 View Post
Dealer wants 35 bucks for the jug
Yea too expensive. Mine coolant level is close to LOW. Is there any web selling OEM coolant blue?
Eibach Prokit Lower Springs
Injen Intake
Xenon 6000k HID
Beat-Sonic Shark Fin
Greddy Evo3 Catback
FantomRider is offline   Reply With Quote
Old 10-13-2012, 09:20 PM   #32
RWD-boxer
RWD-boxer's Avatar
Drives: Black
Honda blue is illegal on streets is that the same with this. Also on Hondas they use blue brake fluid
RWD-boxer is offline   Reply With Quote
Old 10-13-2012, 10:03 PM   #33
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Originally Posted by meltman View Post
That's total bologna. Subaru's magic blue coolant is just standard ethylene glycol based with a bit of diethylene glycol and some water (50%).
It's the same base composition as standard cheap green coolant but with blue dye instead of green and a higher price tag.
You can drain and go back and forth without issue.
This guy is exactly right. Your long life antifreezes have removed silicates from the system to make it better for long term use in aluminum radiators without ill effects.
There are some differences though, and that comes in the form of rust inhibitors. Different brands can use sodiums, or organic compounds to prevent rust. Mixing different rust inhibitors can shorten the life of the antifreeze.
Until SAE standardizes colors we are all going to be confused. But don't worry about it. Just keep in mind when you service to flush and run whatever color you want. I wouldn't recommend the conventional green though.
Coheed is offline   Reply With Quote
The Following User Says Thank You to Coheed For This Useful Post:
jcw99 (07-10-2014)
Old 10-13-2012, 10:07 PM   #34
Coheed
Coheed's Avatar
Blue brake fluid is silicon based. You won't find it in any factory cars... perhaps bikes, but not cars.
Silicon based fluids are DOT 5, but most race series won't allow the use of it in ABS equipped cars (some tracks won't allow it at all), because you cannot determine the age of the fluid by looking at it. They recommend DOT 5.1 instead. Same temp ratings but glycol based.
Old 10-14-2012, 04:34 AM   #35
gmookher
blue brake fluid is not automatically a dot 5
honda blue is illegal in street car class?
Old 10-14-2012, 04:50 AM   #36
Coheed
Coheed's Avatar
Correct, there are colored fluids that are still glycol based instead of silicone. But there are many tracks that won't pass the car for tech inspection if the fluid isn't clear. This helps them determine the age of the fluid. Street car class is more lenient, and not all tracks are nazis. :happy0180:
But typically silicone based fluids are colored blue or purple.
gmookher (10-14-2012)
Old 10-20-2012, 05:47 PM   #37
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
BMW has used Blue coolant and brake fluid for a lonnnnnnnggggg time.
the blue coolant in the BMWs well for older bmws is a must because head problems with green shit or any other color not approved. grab someone's old 94 325 pull the head off if they used green coolant you'll see some nasty corroded grossness its not nice looking ill tell you that. (worked at a BMW performance shop for a year or 2)
DanoFA20 is offline   Reply With Quote
The Following User Says Thank You to DanoFA20 For This Useful Post:
HRTROB (04-13-2014)
Old 10-05-2013, 09:57 PM   #38
psuoh
psuoh's Avatar
Drives: scion frs 2013
thanks. being searching for this info!
psuoh is offline   Reply With Quote
Old 10-06-2013, 04:58 AM   #39
tracerit
Drives: '13 SSM BRZ Limited 6MT
would i be able to top off with this Honda coolant?
tracerit is offline   Reply With Quote
Old 10-07-2013, 09:08 AM   #40
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by kickz View Post
does the subaru brz need the subaru coolant additive ?
Originally Posted by Thunderchicken View Post
The answer is yes, the chemicals in it help keep the head gaskets in good working order. If you mix and match the coolant then you have to put the conditioning stuff in your coolant every 30000 miles when you change coolant.
The answer is no. The new Subaru blue coolant pre mixed and not needing water to be added does not require the Subaru additive.
Old 10-14-2013, 04:16 PM   #41
lazyluka
Drives: GT86
I don't know about you guys in the US, but Toyota NZ here seems to use Toyota Blue Long Life Coolant on all their cars. It's JDM as well yo, I got 10L a few weeks ago. Will take some pictures if you wan.
lazyluka is offline   Reply With Quote
Old 10-14-2013, 07:02 PM   #42
SXE10
SXE10's Avatar
Drives: Altezza RS200-Z 6MT
They do?? In the dealership I work in we use pink in all the late model stuff & read in older models. Blue is specifically for the 86 only. JDM/NZ part number is 08889-01203. The service schedule says to replace it at 150,000 km or 10 years then every 75,000 km/5yrs after that. I doubt anyone has hit 150K yet?
SXE10 is offline   Reply With Quote
GALAXY BLUE SILICA BRZ Compilation Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 595 12-08-2022 06:55 AM
Galaxy Blue VINs? dorkymork BRZ First-Gen (2012+) — General Topics 49 06-02-2012 10:55 PM
Black, blue, or gray.. i may have a choice here Mykflo BRZ First-Gen (2012+) — General Topics 27 05-26-2012 12:26 PM
I want this edition... (blue modified 86 TRD) xantonin Scion FR-S / Toyota 86 GT86 General Forum 119 02-15-2012 02:02 AM
More pix of blue 86 w/aero+ rims Alfie FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 11-29-2011 09:17 PM
