AVOturboworld
Old 10-12-2012, 01:50 PM   #897
xwd
Most likely, most Subaru heads/blocks are interchangeable as long as the coolant passages line up. The passages on the FB25 motor are really small.
The FA20 uses a unique piston design due to the DI system, so something would have to be made to drop into the FA25.
The bigger issue may be the bellhousing on the transmission is the wrong shape, the FB25 is only used in AWD applications and is meant to mate to a Subaru transmission. However, you can get a new bellhousing casted fairly easily with enough money, there is a guy on NASIOC that does them.
Here is another thread on the topic:
http://www.ft86club.com/forums/showthread.php?t=2158
Old 10-12-2012, 02:07 PM   #898
Genomaxter
Drives: 2013 firestorm FRS
Originally Posted by subatoy View Post
they can easily get more power out of that engine but that causes more strain and since it's meant to go on a non-sporty car, there is no need for the expensive parts. it'sall about business not capability.
I wish they had made the FA20 a 2.5 by boring out the cylinders instead of trying to squeeze 200 hp out of the 2.0 by using a high compression ratio and sacrificing all the torque.
2.5 engine with 200 hp and 190 tq would make me very happy!
Can hardly say they "sacrificed" torque to get 200hp when the FA20 has the most torque... of any na 2.0L. And larger bores = less efficient combustion so less hp per liter as you try to scale it up. Best hp per liter is found at 0.5L or less per cylinder.
You want more liters while keeping 100hp per liter, you need more cylinders. And this deals purely for NA.
Genomaxter is offline   Reply With Quote
Old 10-12-2012, 03:08 PM   #899
Opposed
Drives: 2013 Asphalt FR-S
Except for the F20...but close enough.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 10-12-2012, 03:18 PM   #900
Genomaxter
F20 makes 140, but not until around 6500. It's terrible down low. But a very fun car. My friend has one. Like it better than the F22.
Edit
F20c was rated at 152 tq. Tho that was before the new standard. But I accept it.
Old 10-12-2012, 04:14 PM   #901
Opposed
Edit
I had an 02 S2K before this, and it was a dog down low compared to my FRS.
Old 10-12-2012, 04:33 PM   #902
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
AVO, (really sorry if I missed it) is the Turbo ball bearing on the Stg 1 Kit?
Old 10-12-2012, 05:15 PM   #903
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Im pretty sure I read that theyre using a ball bearing turbo.
Parting out HERE
civicdrivr is offline   Reply With Quote
The Following User Says Thank You to civicdrivr For This Useful Post:
Sportsguy83 (10-12-2012)
Old 10-12-2012, 09:04 PM   #904
AVOturboworld
OK guys,
Time to be official about this - we will release final details, shipping dates, availability, and power figures in America on American pump gas (91, 92, 93) at SEMA.
While we'll certainly do race gas/e85 dyno testing at some point, we fully realize that the majority of customers will be running this as a daily driver on pump gas. So power figures will be based on that. All kits will have full install instructions, and one of the reasons I'll be personally installing the kit on my own car, so we can handle tech support - like we have for the last 10 years on the Impreza and Legacy turbo kits.
The Following 20 Users Say Thank You to AVOturboworld For This Useful Post:
Alienate (10-12-2012), Apex Chase (10-12-2012), Asphaltfrs1 (10-12-2012), boucher (10-13-2012), Calum (10-12-2012), Celica00 (10-13-2012), civicdrivr (10-14-2012), djdnz (10-13-2012), DriftEightSix (10-13-2012), drifter (10-13-2012), driver01 (10-12-2012), industrial (10-12-2012), Jeff86 (10-13-2012), JoeBoxer (10-12-2012), Klar (10-12-2012), Lawnik (10-14-2012), Nardi330 (10-13-2012), OjiGeorge (10-13-2012), Ravenlokk (10-13-2012), Sportsguy83 (10-12-2012)
Old 10-12-2012, 09:21 PM   #905
Apex Chase
El Presidente
Apex Chase's Avatar
Drives: it like I stole it!
I don't see you guys on the SEMA show directory. What is your booth number?
Apex Chase is offline   Reply With Quote
Old 10-12-2012, 09:30 PM   #906
driver01
Drives: brz 13
OK guys,
Awesome news! Can't wait
driver01 is offline   Reply With Quote
Old 10-12-2012, 09:34 PM   #907
AVOturboworld
We are going to be in with DBA, we don't have our own booth up this year.
Old 10-13-2012, 12:13 AM   #908
Gen
Drives: Scion FR-S
Will this kit include everything needed (aside from fine tuning obviously an the license) to run this kit relatively reliably? In other threads I've been seeing talk about clutch slippage approaching the power levels you are at.
Gen is offline   Reply With Quote
Old 10-13-2012, 01:01 AM   #909
GC GTS Aero Kit
Australian and Proud !!!!
GC GTS Aero Kit's Avatar
Drives: 2012 Toyota 86 GTS Aero Kit
When will we know about Australian details?
BONKRS for life
GC GTS Aero Kit is offline   Reply With Quote
The Following 3 Users Say Thank You to GC GTS Aero Kit For This Useful Post:
DriftEightSix (10-13-2012), KamalT (10-13-2012), Nitesh31 (10-13-2012)
Old 10-13-2012, 01:05 AM   #910
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
clutch slips at 300hp, and iv never seen a turbo kit come with a clutch.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
The Following User Says Thank You to WolfsFang For This Useful Post:
JoeBoxer (10-13-2012)
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
