Old 10-12-2012, 12:48 AM   #1
636
636's Avatar
Drives: '23 CWP BRZ
TPMS?
Well, it starting to get into the 60's in Florida. Today after a car meet, hopped in the FRS, turned it on, and I had that little glowing exclamation point. Stayed on the whole drive home (40 minutes.) And as of last checking, it's still on.
So I searched, apparently my tire pressure is just low? Is there a way to disable this TPMS? I don't want to be alerted when my wheels drop like 1PSI under what they have it set at...seems like a hassle to me.
I'd rather just check on my own normally.
636 is offline   Reply With Quote
Old 10-12-2012, 12:50 AM   #2
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
No. Just fill them properly
chulooz is offline   Reply With Quote
Old 10-12-2012, 07:40 AM   #3
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Correct. I hate TPMS because of hassles it can cause. Especially because our cars can't store more than one set of TPMS codes.
But, if your TPMS light stayed on after 40 minutes of driving, at least one of your tires is more than one or two psi low. Driving heats up tires, and if the light stayed on even after the tires were heated up, then your pressure is lower than you thought.
Did you actually check your pressures when you got home? I can't tell by your post.
Grimlock is offline   Reply With Quote
Old 10-12-2012, 08:14 AM   #4
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
they usually only come on at about 25psi, so when they light up, it really is time to check your pressures... there has to be a way do get rid of the system, i just got a BRZ in the shop and it doesnt have TPMS
Silverdub is offline   Reply With Quote
Old 10-12-2012, 08:52 AM   #5
CaptainSlow
CaptainSlow's Avatar
You can probably take out the bulb in the dash light. I'd just deal with it, though - I doubt highly that it's sensitive to +/- 1psi....engineers are generally smart enough to know that tire pressures will fluctuate within a certain range during normal heat cycles, and I'm sure they did extensive testing during the development on all the various components that went into each system. It wouldn't make sense that they would keep in a system that was throwing codes during normal driving conditions. If the light goes off, just fill up your tires!
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 10-12-2012, 10:23 AM   #6
DjDATZ
EightSixClub Co-Founder
DjDATZ's Avatar
Drives: Selina (FR-S), Rondo EX V6 & fortwo
Not for me, mine came on about a week or two after owning it on a colder day. When I took it into the dealership to take a look at the CEL, I asked them to also check the tires. They said they were at 32 psi, so I asked them to bump it up to 35 psi as the door frame suggests.
Meet Selina, my Asphalt FR-S MT6.
Like EightSixClub on FB, and follow us on Twitter!
DjDATZ is offline   Reply With Quote
Old 10-12-2012, 01:59 PM   #7
636
636's Avatar
Drives: '23 CWP BRZ
Just turned off today after driving on the interstate for around 30 minutes. Seems like TPMS is too sensitive.
Old 10-22-2012, 08:59 AM   #8
MaXimus
Meh!
MaXimus's Avatar
Drives: Satin White, 86, Manual
Nitrogen?
MaXimus is offline   Reply With Quote
Old 10-22-2012, 10:08 AM   #9
dsgerbc
Drives: BRZ(sold), STI
Mine came on at around 30psi.
Old 10-22-2012, 10:40 AM   #10
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Did you actually checked the pressure? It will come on when it's "significantly" lower than what it should be.
Rayme is offline   Reply With Quote
Old 10-22-2012, 10:57 AM   #11
dsgerbc
^Me? I checked as soon as the light came on.
TPMS light michael317 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 08-05-2014 04:12 PM
TPMS Sensors.. Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 04-08-2014 01:22 PM
TPMS smbrm CANADA 2 09-21-2012 11:17 AM
Multi TPMS? Justin.b Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-11-2012 06:25 AM
so what is everyone doing about their tpms? Hachi6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 07-22-2012 05:04 AM
