KR-S, MisterSheep, Tcoat
Old 10-11-2012, 04:33 PM   #15
jadewbj
jadewbj's Avatar
Originally Posted by JoeBoxer View Post
Is it a supply issue on E85 or you just don't want to use it? I like the fact i can have a pump gas map for daily driving to work and back and switch to E85 on weekends when i want to play and don't care about mpg. None of the bolt ons are going to give you the gains E85 will and the reflash for it is the same price as an intake which doesn't do much at all.
The availability is not great around me for one. There are only 3 stations and all are a 20 to 30 minute drive out of my way. Secondly I don't like that it wears down an engine faster. Lastly I don't wan't a gain that requires special fuel. I would find myself wanting that power all the time and it would be a PINTA. I want the car to be the same all the time.
jadewbj is offline
Old 10-11-2012, 04:35 PM   #16
2forme
My car recently did 180 on 93, and 199 on e85.
2forme is offline
Old 10-11-2012, 04:45 PM   #17
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I hear ya on the first part the only places close to me are about 25 miles away but happen to be in my home town i go back to regularly. What parts of the engine does E85 wear down faster than regular fuel? I don't want that either but since i won't be running it all the time i think it will be ok.
JoeBoxer is offline
Old 10-11-2012, 04:55 PM   #18
jadewbj
jadewbj's Avatar
Due to chemical differences between E85 and gasoline, fuel systems and engines not designed or modified to use E85 suffer increased wear and may fail prematurely. -From Wikipedia
It can wear down fuel lines, filters and Ethanol corrodes iron parts slightly. Plus the potential for water in it greater than pump from what I hear.
jadewbj is offline
Old 10-11-2012, 05:31 PM   #19
jesperswe
Drives: GT86
If you read the manual that came with the car, it states that using fuel with more than 10% E in will cause "wear" to the engine and fuel system. Not sure how true it is but the manual says so atleast.
But with a proper tune that might not be true.
jesperswe is offline
Old 10-11-2012, 05:38 PM   #20
serialk11r
Drives: '06 AM V8V Coupe
You can't gain 30hp across the powerband for the simple reason that 30hp at 1000rpm takes 7 times more torque than 30hp at 7000rpm.
serialk11r is offline
Old 10-11-2012, 05:44 PM   #21
jadewbj
jadewbj's Avatar
Exactly why I didn't ask it that way at first.
jadewbj is offline
Old 10-11-2012, 05:48 PM   #22
2forme
This can be shown...here:
2forme is offline
Old 10-12-2012, 12:12 AM   #23
TyperRspec789
Version 2 Coming Soon...
TyperRspec789's Avatar
Drives: Turbo Argento FRS, Asphalt FRS
What is your setup 2forme?
TyperRspec789 is offline
Old 10-12-2012, 12:18 AM   #24
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
We also have cams in development and im not sure about headwork gains. Also stroker kits will probably come to life sooner than later. I think if you did a complete engine build and a full exhaust, you'll see some pretty impressive numbers on either 93 or e85.
Tansey86 is offline
Old 10-12-2012, 12:19 AM   #25
2forme
Tune, AFE Intake, SRT HB Exhaust.
2forme is offline
Old 10-12-2012, 12:20 AM   #26
TyperRspec789
Hm... Wanna race?
Old 10-12-2012, 12:22 AM   #27
JoeBoxer
JoeBoxer's Avatar
Hm... Wanna race?
Would like to see 1/4 mile times for both cars myself.
JoeBoxer is offline
Old 10-12-2012, 12:39 AM   #28
2forme
LOL, I'm on stock tires. My 60's would be like 2.4 haha.
2forme is offline
Fuel pump and speed sensor Tt3Sheppard Issues | Warranty | Recalls / TSB 28 04-20-2017 02:54 PM
Which gas station(s) do you OR folks pump at? m.box.design Northwest 41 05-12-2013 02:01 AM
Dynosty Pushing the Limits... Fuel Pump and Clutch Dustin@Dynosty Engine, Exhaust, Transmission 29 08-15-2012 07:53 PM
Be careful at the pump with E15 Thunderchicken Scion FR-S / Toyota 86 GT86 General Forum 9 08-10-2012 11:33 PM
Legacy low-mounted turbo oil pump aspera Engine, Exhaust, Transmission 0 06-16-2010 04:41 PM
