Old 10-10-2012, 04:02 PM   #15
nab335
nab335's Avatar
Drives: e92 335i, FRS, Lexus ls400
Originally Posted by hippari View Post
Nah, clearance should be fine with the prius rubber bands on em, but it's gonna look silly with all that stretch and the wheel gap of 17's.
How much tire are you tucking right now, Nab? It might look kinda funny when you throw those on if you don't go lower.
I realized this. Right now I am somewhat tucking tire but not really. I can always lower it a bit more. If this setup would work and not look awkward then I'd totally be for it but I want to confirm this with you guys that have more knowledge on the subject first. Right not it looks like majority of people are saying don't go for it
IG: nabb335
nab335 is offline   Reply With Quote
Old 10-10-2012, 04:17 PM   #16
nab335
nab335's Avatar
Originally Posted by ebphoto View Post
rear would require more work than the front.
i run 18x9.5 +25 225/40 all around.. with the rear you have the issue of the bumper mounting point... and in the front you have the bumper/corner light too worry about.
i rub on both. ( less so in the front... usually only on full lock under compression )
fronts can probably fit 5-10mm wider depending on how much negative camber you would like to run..
did you roll your fenders?
IG: nabb335
Old 10-10-2012, 04:24 PM   #17
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Originally Posted by nab335 View Post
lol woah that dudes fenders are screwed
I was hoping for a fitment like this:
this guy has the same setup with almost the same size tires accept 215/40 but obviously since he has a wrx so he can fit them. I guess Ill have to look into some smaller sizes then! Do you guys know if I can achieve this with 8.25 +25 wheels all around? Or I'm contemplating on doing 8.25s +25 in the front and 9.75s +20 in the rear if it wont look too crazy/awkward. Let me know what u guys think.
The rears are actually +25 also
Old 10-11-2012, 12:13 AM   #18
nab335
nab335's Avatar
ohh okay does that make a big difference? do you think i can run 9.75s in the rear? looks like you and darren are the go-to wheel fitment guys around here lol. lemme know what you think because I'm planning to hopefully place an order soon!
IG: nabb335
Old 10-11-2012, 12:26 AM   #19
JoeBoxer
JoeBoxer's Avatar
I'm no expert but have done a lot of research, you could get the 9.75's to fit but I still don't like that width on the stock tire at all. Pm me when u get ready to order and I'll double check everything.
The Following User Says Thank You to JoeBoxer For This Useful Post:
nab335 (10-11-2012)
Old 10-11-2012, 12:59 AM   #20
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
15 Years of working for Discount Tire Co. I used to use a Cheetah to mount 5.20 13 tires on 13x7 wheels. As a professional I say you're on crack or sniffing crack.
Even a 9 inch wheel is pushing safety boundaries, I'd do it with a +30et and this is why by the numbers.
Factory wheel is 7 inches wide with a +52et.
25.4 mm equal one inch, a +52 et means the factory wheel is Two inches toward the strut from the centerline of the wheel.
On a 7 inch wheel the center line is 3 inches. 3+2 = 5.
So we know that 5 inches of 9 inch wheel will fit toward the strut from the mounting surface.
That leaves 4 inches from the center line ie... the mounting surface toward the fender.
I have measured 6 1/2 inches with the wheel off from the mounting pad and a yard stick straight down from the inner lip of the front fender.
I have measured 8 1/4 inches in the rear same way, but for there is not as much room in the rear toward the strut.
So I take it you want a square set up for rotations.
So 9 is the biggest wheel I can recommend on the factory tire.
For every 1/2 you increase the width the tire shrinks in diameter 1/4 inch.
So your factory tire would go from 24.62 diameter to 23.42 on a 9 inch wheel @ 65 you would be going 61. You would be putting more mileage on your car than you were actually driving also.
I would do the 9 like Darren did with a +30et with a 3mm spacer. 30mm-3mm = +27et
Spartan65 is offline   Reply With Quote
The Following User Says Thank You to Spartan65 For This Useful Post:
DAEMANO (07-17-2013)
Old 10-11-2012, 01:08 AM   #21
nab335
nab335's Avatar
hmmm not really into smoking crack or sniffing hahaha just lacking knowledge on the subject but thanks for all that useful info! I had no idea about the whole mileage thing thats interesting!
IG: nabb335
The Following User Says Thank You to nab335 For This Useful Post:
Spartan65 (10-11-2012)
Old 10-11-2012, 01:17 AM   #22
JoeBoxer
JoeBoxer's Avatar
The factory wheel is +48 but i agree with everything else there. I think the 8.25's would be ok i didn't see the S2k or WRX pics earlier at work i didn't know you wanted it that aggressive though.
Old 10-11-2012, 01:39 AM   #23
ebphoto
Drives: FR-S, NA8, S13
yes... front pulled. rear rolled.
ebphoto is offline   Reply With Quote
Rota Wheel Fitment and Where to buy CharlieChaos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-21-2012 04:30 PM
Wheel fitment question thelegaCy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-05-2012 11:22 PM
BRZ/FR-S/86 Wheel Fitment Simulators JDMSushi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-05-2012 10:49 PM
Wheel size and fitment bsclywilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 03-27-2012 12:34 PM
Wheel fitment sfwg BRZ First-Gen (2012+) — General Topics 6 10-28-2011 06:33 PM
