Old 10-09-2012, 07:44 PM   #15
Brett
First 86
Brett's Avatar
Drives: Whiteout MT FR-S
Originally Posted by Flat Black VW View Post
Mercedes 190E Cosworth....
That was the first id heard of it, I wish all cars were like that.
I wonder how many times I'd go backwards at a light like they did before I got used to it...
Don't shop, adopt!
Brett is offline   Reply With Quote
Old 10-09-2012, 08:06 PM   #16
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
I have no trouble with the shift pattern. I do think the car would be better served by a 5 speed manual instead of a 6. As it is now, 1st is very short.
whaap is offline   Reply With Quote
Old 10-09-2012, 10:38 PM   #17
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
That has nothing to do with it being a 6 speed and everything to do with the ratios they chose. They could have easily made all 6 taller or shorter or change any of the singular ratios around if they had wanted to all while keeping it a 6 speed.
I would have loved to have 1-5 approximately the same as the close ratio works well with the powerband of the car but fitted it with a highway cruising centered 6th gear to get higher MPG's. How often are you going to use 6th on most road courses with 200hp?
Nathan
SubieNate is offline   Reply With Quote
Old 10-09-2012, 10:42 PM   #18
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Originally Posted by sabSquishy View Post
I forgot what car they mentioned this in Top Gear but its a great idea that needs to be brought to the attention of car manufacturers!
Like this?
Snoopyalien24 is offline   Reply With Quote
Old 10-09-2012, 11:34 PM   #19
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Thats why I wish all cars were that way, thenpeople would be confused driving what we consider normal
Flat Black VW is offline   Reply With Quote
Old 10-09-2012, 11:46 PM   #20
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by QuikJ View Post
Someone else always has it worse.
That was painful to watch
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 10-10-2012, 12:15 AM   #21
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
It was painful, but also looked awfully fun.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 10-12-2012, 01:26 AM   #22
dietz
Drives: Raven / 6MT FR-S
Thanks for everyone's input, I've had some laughs at that video too . I definitely agree more practice is in order, but still struggling with the heel toe vs my old car. My wider pedal gets here Tuesday, hopefully that will help.
dietz is offline   Reply With Quote
What other vehicles use a 5x100mm bolt pattern? EsoBOFH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 09-13-2014 05:42 AM
Bolt Pattern Woes TSLRich Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 07-30-2012 12:30 AM
bolt pattern is 5x100? derka-derka Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-30-2012 03:58 AM
Bolt Pattern, Wheel Hubs and Studs Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 03-08-2012 03:49 AM
The wheel bolt pattern is... quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 193 02-29-2012 07:04 PM
