Old 10-09-2012, 12:56 AM   #1
dietz
Drives: Raven / 6MT FR-S
MT shift pattern
So with the lack of low end torque, coupled with high elevation, >5,000 ft, I find that I need to be in 2nd to really enjoy most turns. Shifting from 3rd to 2nd smoothly is slow and more difficult than 4 to 3, which I almost never need to be quick, (the stock gas pedal doesn't help, a wider one is on order) and since I never go into 1 while moving (and don't drag race)... why not have 2 and 3 across from each other? Is there a way to modify the shift pattern with some sort of different linkage? Or is it inherent to the whole layout of the transmission and therefore a completely stupid question?
dietz is offline   Reply With Quote
Old 10-09-2012, 01:06 AM   #2
Squishy86
Squishy86's Avatar
Drives: Your Car
I forgot what car they mentioned this in Top Gear but its a great idea that needs to be brought to the attention of car manufacturers!
Squishy86 is offline   Reply With Quote
Old 10-09-2012, 01:08 AM   #3
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
I'll just leave this here:
http://en.wikipedia.org/wiki/Dog-leg_gearbox
As for putting one in the FR-S, I don't know enough about transmissions to say for sure, but I suspect it wouldn't be easy.
Old 10-09-2012, 01:10 AM   #4
fatoni
there more than likely is now way to change it. what you want is a dogleg tranny but they were never really popular and since its a 6 speed the use of second and third should be about equal on most roadcourses and even at an autox.
my advice would be to buy new tires so you can then take corners in third at higher rpm
Old 10-09-2012, 01:13 AM   #5
dietz
Wow there's a name for it! That's what I want.
Old 10-09-2012, 01:15 AM   #6
dietz
But that means I'm going around the corner faster... not necessarily something I want to do if I'm just looking for that feeling of having to modulate the throttle at a reasonable speed.
Old 10-09-2012, 01:31 AM   #7
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Practice some more. Rev matching your downshift will help slot the shifter into 2nd easily.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 10-09-2012, 01:53 AM   #8
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Mercedes 190E Cosworth....
That was the first id heard of it, I wish all cars were like that.
Flat Black VW is offline   Reply With Quote
Old 10-09-2012, 03:48 PM   #9
trackmagic
Drives: 1994 BMW 318i
I like it
trackmagic is offline   Reply With Quote
Old 10-09-2012, 03:55 PM   #10
DarkSunrise
DarkSunrise's Avatar
Agreed. I heel-toe into 2nd on a constant basis around town, so shifting into 2nd has become second nature to me. It's really just a matter of practice and repetition, and with a transmission as good as this one, it's fun to do.
On a related note, it makes such a large difference shifting into 2nd when the transmission is cold vs. hot.
Old 10-09-2012, 03:59 PM   #11
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Doglegs are interesting to say the least, but I don't think there is an easy way to change the layout of your gearbox. Considering the fact that most doglegs were 5speed with Reverse being in the number one spot, I'm not sure if you will find many resources for modifying a six speed Trans to achieve the same goals.
And like others have said, A good rev match and some good Trans fluid is really all you need to get great downshifts on any gearbox.
- The Ancient BRZ Sacrament
by Zaku
Old 10-09-2012, 04:18 PM   #12
QuikJ
Drives: '13 Subaru BRZ
Someone else always has it worse.
[ame="http://www.youtube.com/watch?v=6se7UKjARmY&feature=share"]353 EVO II / Rallye Wartburg 07 - YouTube[/ame]
QuikJ is offline   Reply With Quote
Old 10-09-2012, 06:37 PM   #13
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
What is this new shifter? It's like a high-tech paddle shift! Maybe we can get it on road cars one day! =D
I got a good laugh when he was held up by a new Beetle.
Old 10-09-2012, 06:43 PM   #14
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Wanna change shifting gears? Simple swap your gears around.
It only take... few days & several hundreds of dollars. That's all
What other vehicles use a 5x100mm bolt pattern? EsoBOFH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 09-13-2014 04:42 AM
Bolt Pattern Woes TSLRich Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 07-29-2012 11:30 PM
bolt pattern is 5x100? derka-derka Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-30-2012 02:58 AM
Bolt Pattern, Wheel Hubs and Studs Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 03-08-2012 02:49 AM
The wheel bolt pattern is... quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 193 02-29-2012 06:04 PM
