Old 10-08-2012, 10:41 PM   #1
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
What happens on a Boxer engine when there's too much Oil?
(I'm a boxer noobie and there's a lot I don't understand about this motor so please bear with me.)
After my FR-S had a Cam Gear replaced to deal with the CEL triggered by a P0016 DTC on the dipstick I noticed I'm about half a quart over the "full" mark. What sorts of things can I expect when there's too much oil in this type of engine?
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 10-08-2012, 10:42 PM   #2
Xanatos
Xanatos's Avatar
Drives: @redline, '14 BRZ, '98 Forester
Drain some out so you dont have to find out :happy0180:
Xanatos is offline   Reply With Quote
Old 10-08-2012, 11:00 PM   #3
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
Let's just say there's a reason im asking...
I actually havent seen the back of my car in sunlight until this morning. I picked her up from the dealer on Sat afternoon when she was squeeky clean and overfilled.
Old 10-08-2012, 11:04 PM   #4
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Wow that's awful, i would have them come pick it up on a flatbed tow truck and fix it.
Old 10-08-2012, 11:09 PM   #5
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
Id definately call them and say, "hey, my car is covered in oil, yall need to fix this because it wasn't like this when i brought it in." Or something to that effect lol. That just looks horrible. Whats it look like underneath the car??
No replacement for Displacement??? Tell that to the people with a 2JZ.
usptwins is offline   Reply With Quote
Old 10-08-2012, 11:10 PM   #6
Xanatos
Xanatos's Avatar
Yeah you may have overflow oil in your cylinders. I see the bumper is spotty is that oily substance?
Old 10-08-2012, 11:14 PM   #7
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
So here's the funny part. I drove it over to the dealer and they said that the oil levels were fine even tho they were well above the top dot on the dip stick. Then I drove the car to a Subaru Dealer and a mechanic there said the same thing.
Just to get the inevitable question out of the way:
> I properly broke-in the engine
> I'm not normally seeing smoke while I'm driving.
I thought I caught the site of smoke while I was driving home from the dealer. I was up in the rev range playing with a 335 at the time. It was chilly out and thought that was steam
Old 10-08-2012, 11:16 PM   #8
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
We put it on a lift in the morning and it was as clean as a whistle.
The Following User Says Thank You to @Art_Mighty For This Useful Post:
usptwins (10-08-2012)
Old 10-08-2012, 11:19 PM   #9
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
It's more dusty then anything. A huge portion of Lake Shore Drive (10miles) has been recently repaved with asphalt and I drive on it twice a day at least. Is it that and I'm overacting?
Old 10-08-2012, 11:21 PM   #10
70NYD
70NYD's Avatar
Drives: RX8 S1
Check your air filter
You might find that the access oil has good all the way down there if it looks the bad on the back
Also your cat will be affected
70NYD is offline   Reply With Quote
Old 10-08-2012, 11:25 PM   #11
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
Good advice
(I am worried about the Cats as well but if they failed prematurely because of this i think they would be under the emissions warrantee)
Old 10-08-2012, 11:42 PM   #12
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Cat warranty is 8 years iirc.
Coheed is offline   Reply With Quote
Old 10-09-2012, 12:03 AM   #13
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Overfilling Oil can result in oil foaming up in the head and this can cause oil starvation issues...
Here's a quote from the Forester forums:
Damage from overfilling does not occur until the level of oil reaches the bottom of the spinning crankshaft webs, which would beat the oil. The air in the crankcase would become an oil mist, which would be blown out the crankcase vent system, and the oil would become aerated, which would not pump well. Even so, there would be no damage in moderate driving as enough oil would continue to be pumped and the excess would eventually be blown out over the engine. Most likely the driver would soon notice the smell and smoke of oil on the exhaust system, and raise the hood to find an oily mess.
- The Ancient BRZ Sacrament
by Zaku
Old 10-09-2012, 02:08 AM   #14
einzlr
Drives: several
Haha yeah that could do it and could be unrelated to the oil level. You said you noticed the oil level when you picked up your car, right? If they put in new oil and filter, they would have allowed for the filter to soak up some oil, hence filling past the "full" mark. Have you checked the level again after driving it for a while?
einzlr is offline   Reply With Quote
The Following User Says Thank You to einzlr For This Useful Post:
@Art_Mighty (10-09-2012)
BRZ / FR-S Boxer Engine Dyno Powerband revealed Levi Engine, Exhaust, Transmission 217 06-01-2012 12:20 AM
total noob with boxer engine NickDude84 Engine, Exhaust, Transmission 35 04-27-2012 08:51 PM
Next Gen Boxer Engine 4U-GSE WingsofWar Engine, Exhaust, Transmission 33 12-10-2011 12:04 AM
Could this be the base FT-86 boxer engine? iff2mastamatt Engine, Exhaust, Transmission 2 02-10-2011 10:55 PM
More proof of FT-86 Boxer engine appears in logo Hachiroku Engine, Exhaust, Transmission 33 01-03-2011 01:47 AM
