Old 10-06-2012, 06:50 PM   #15
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by ML View Post
Interesting. Keep me updated on thi. I or start a new thread
go down to home depot buy some washers that fit the bolts you may spend 2 bucks, its helped me a lot on deciding on what sound i want because i get to hear what the car sounds like at each rpm every day and it helps me figure out how i want to tweak it
but in the end i dont think i want to change it at all and just add an exit without a muffler, its to each's own, i like it, you may not
@lopro25 liked it and hes got an aftermarket exhaust
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 10-07-2012, 12:45 AM   #16
nab335
nab335's Avatar
Drives: e92 335i, FRS, Lexus ls400
all you guys need to do is hit up a muffler shop have them unbolt your muffler and create a turn down pipe slanting to the floor in an inconsipicuous angle and for like $30 bucks you got your self a clean ass muffler delete thats completely stealth since your mufflers are still there and imo sounds better than 70% of the exhausts out right now if your looking for a slight rumble.
IG: nabb335
nab335 is offline   Reply With Quote
The Following User Says Thank You to nab335 For This Useful Post:
ESC POD (10-07-2012)
Old 10-07-2012, 01:38 AM   #17
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by ST185RC View Post
It's 100-150 centigrade and mufflers can grill a steak after a 15 minute commute.
lol, try 300+ C
Old 10-07-2012, 08:25 AM   #18
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by carbonBLUE View Post
removed both bolts to the muffler, take out the gasket, put 5 washers between the muffler and catback, tighten down bolts
allows some air to escape the exhaust system, in reality its just a really big exhaust leak lol... im still up in the air on what exhaust i want but needed some exhaust sound in my life so that is my temp fix till i decide
personally i like the way it sounds, i may just buy the single exit w/ exhaust tip for $150, it does drone though because the noise comes out behind the bumper but its not as loud as my last car so i dont really mind
On the Legacy GT forums this is called a "Hogzaust".
Old 10-07-2012, 04:46 PM   #19
ML
ML's Avatar
Drives: 13 White MT FR-S
I tried the "hogzaust" today...I thought it sounded pretty good, bumper get didn't hot at all. I'm going to go to my buddies muffler shop this week and get a quote on a dual exit straight pipe though.
Old 10-08-2012, 10:57 PM   #20
carbonBLUE
Reverse Burnouts
thats cool, another thought poped up in my head, you know the guy that did the rear mount turbo, how come his bumper hasnt melted off? Turbos get really hot dont they?
(wont forget you)
2011 Infiniti G37x
Old 10-08-2012, 11:02 PM   #21
ML
ML's Avatar
Couldn't tell you, but I never messed with fi.
Old 10-08-2012, 11:09 PM   #22
carbonBLUE
Reverse Burnouts
i was using sarcasm lol, they do get really hot actually, i guess its mounted low enough for good airflow to carry away heat.. wierd
(wont forget you)
2011 Infiniti G37x
Old 11-22-2012, 11:10 AM   #23
RWD-boxer
RWD-boxer's Avatar
Drives: Black
Update muffler delete is the best way to make power and you remove the most weight
http://www.ft86club.com/forums/showpost.php?p=569033
http://dsportmag.com/browse/tech/scion-fr-s-2013-exhaust-showcase
RWD-boxer is offline   Reply With Quote
Muffler Delete SkitterSkotter Engine, Exhaust, Transmission 37 07-04-2017 01:44 AM
Berk Technology Muffler Delete jeebus Engine, Exhaust, Transmission 31 12-22-2014 04:34 PM
Dual exit muffler delete Hardrock4445 Engine, Exhaust, Transmission 22 02-13-2013 09:41 PM
Custom Muffler Delete w/ Videos! IceCreamMan Engine, Exhaust, Transmission 5 06-28-2012 08:12 PM
X-Pipe with Muffler delete dav0777x Engine, Exhaust, Transmission 3 06-21-2012 11:30 AM
