#15 | |
Drives: Raven FRS/c5 Corvette
I would wait for winter to pass at the EARLIEST. |
#16 |
Drives: 2014 BRZ
You should do some research on suspension before doing any suspension mods... It's your first car... Enjoy it the way it's made in stock form. Then as you get better at driving and getting to know your car, you can make rational decisions on what you want your car to be. Just because the car is lower doesn't mean it will handle better. Just because you have negative camber doesn't mean it's bad. Drive drive drive. If anything, your first mod could be wheels, assuming they aren't to heavy and you have a decent set of tires.
| The Following 3 Users Say Thank You to speargunsandracecars For This Useful Post: |
#17 | |
Site Moderator
Drives: Stuff
Nice car for a 17 year old, take good care of it!
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#18 |
When you lower the car a lot you'll end up with too much rear negative camber. This means you'll likely wear your tires unevenly and handling will be compromised. That can be corrected with a rear camber bushing kit or rear lower control arms. There's nothing wrong with either one other than they aren't free.
The real problem with a big drop on springs is that your losing a lot of suspension travel and compromising the geometry of the suspension. You will be sacrificing ride quality, durability of the stock shocks, and likely handling too just for looks. If that's fine with you go for it but I'd suggest reading as much you can for now. Its easy to get things wrong and a lot of parts out there are not what I'd personally call improvements. Let me know if you'd like some reading material. ![]() Cheers, Andrew |
#19 | ||
| STI BRZ springs now available | ayau | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 12-02-2012 11:57 AM |
| OEM BRZ springs? | jm1681 | Brakes, Suspension, Chassis | 1 | 11-03-2012 08:14 AM |
| BEST SPRINGS? | whitefrs | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 10-10-2012 05:50 PM |
| trd springs or no? | FT86R | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 09-30-2012 03:52 PM |
| STi Springs | illmatic | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 08-14-2012 01:19 PM |
