Old 10-07-2012, 11:22 PM   #15
Obja
Obja's Avatar
Drives: Raven FRS/c5 Corvette
Originally Posted by JoeBoxer View Post
I would drive it for a few months and then decide, I really would say the Pro-Kit would be better for a teenager or no lowering at all. Just be careful either way you go, watch for curbs and bumps and don't turn off the traction control!
Yeah i was just thinking of ideas and such, nothing immediate.
I would wait for winter to pass at the EARLIEST.
Obja is offline   Reply With Quote
Old 10-07-2012, 11:23 PM   #16
speargunsandracecars
Drives: 2014 BRZ
You should do some research on suspension before doing any suspension mods... It's your first car... Enjoy it the way it's made in stock form. Then as you get better at driving and getting to know your car, you can make rational decisions on what you want your car to be. Just because the car is lower doesn't mean it will handle better. Just because you have negative camber doesn't mean it's bad. Drive drive drive. If anything, your first mod could be wheels, assuming they aren't to heavy and you have a decent set of tires.
speargunsandracecars is offline   Reply With Quote
The Following 3 Users Say Thank You to speargunsandracecars For This Useful Post:
F1point4 (10-08-2012), Obja (10-08-2012), Racecomp Engineering (10-08-2012)
Old 10-08-2012, 10:38 AM   #17
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
First Mod should be high performance driver education, but otherwise I agree!
Nice car for a 17 year old, take good care of it!
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-08-2012, 12:10 PM   #18
When you lower the car a lot you'll end up with too much rear negative camber. This means you'll likely wear your tires unevenly and handling will be compromised. That can be corrected with a rear camber bushing kit or rear lower control arms. There's nothing wrong with either one other than they aren't free.
The real problem with a big drop on springs is that your losing a lot of suspension travel and compromising the geometry of the suspension. You will be sacrificing ride quality, durability of the stock shocks, and likely handling too just for looks. If that's fine with you go for it but I'd suggest reading as much you can for now. Its easy to get things wrong and a lot of parts out there are not what I'd personally call improvements. Let me know if you'd like some reading material.
Cheers,
Andrew
Old 10-08-2012, 02:12 PM   #19
Obja
Obja's Avatar
Thanks man and i will take care of it ;D
Cheers,
Andrew
Thanks man and yes, i would love some more reading material... thanks mate
STI BRZ springs now available ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 12-02-2012 11:57 AM
OEM BRZ springs? jm1681 Brakes, Suspension, Chassis 1 11-03-2012 08:14 AM
BEST SPRINGS? whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 10-10-2012 05:50 PM
trd springs or no? FT86R Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 09-30-2012 03:52 PM
STi Springs illmatic Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-14-2012 01:19 PM
