Old 10-03-2012, 01:11 PM   #57
Dezoris
Dezoris's Avatar
Leave the VSC on for street driving, VSC Sport at a minimum. Even a small incident will cost over 6k.
Learned this from experience this week.
The Following User Says Thank You to Dezoris For This Useful Post:
Demandred7 (05-26-2013)
Old 10-03-2012, 03:34 PM   #58
NOHOME
Drives: RAVEN
Full nanny mode does suck, a shopping trolley with 4 casters will get around a corner better. Plus it makes a racket as it goes about its business. And if you have not noticed this, you don't really need a car that handles as well as the FRS.
Sports mode is acceptable.
I have not yet found a safe place to experiment with the full handling envelope with the nanny turned off. Either I book a track day or hit a slalom just to find out.
I agree that the tires feel weakly bonded to the pavement. All my cars up to now have had either R compound rubber or Falken Azenis. They will be arriving.
For winder driving, I will have to do some experimenting to see what is safer: full nanny or sport mode. The video "slip and slide" posted on this site is pretty cool.
NOHOME is offline   Reply With Quote
Old 10-03-2012, 04:34 PM   #59
R_E_L
He's got this.
R_E_L's Avatar
Drives: 50th Anni BRZ
I think the biggest problem people are having is their inexperience with RWD, this car isn't really anymore dangerous than others. Both in my old explorer and in my current bimmer I have had the tail step out on me at even at low speeds, and I don't take of the ASC on my car.
If the road is anything but perfect and dry there is always a chance for your tail to dance at anything upsetting. Add rain and a turn and the odds just go up. Don't turn off the trac control in the rain, unless you are on a closed course it's an invitation for trouble.
Glad OP came out safe, sounds like he's learned his lesson.
Don't worry, I'm certified... promise.
R_E_L is offline   Reply With Quote
Old 10-03-2012, 07:09 PM   #60
DaveFTW
DaveFTW's Avatar
Drives: 2013 86
worth talking about good read.
I'd change the world if I could change my mind
DaveFTW is offline   Reply With Quote
Old 10-03-2012, 07:16 PM   #61
whateatsrabbits
whateatsrabbits's Avatar
Drives: 2013"Road scalpel"FR-S MT
Fuck traction control, I am a man and will drive my car. Not have some computer mess it all up. The only time I leave it on is a 6:30 in the AM while I'm driving to work still half asleep and its raining. Heres a few tips, don't speed in the rain, never get air(jump) in a rwd, learn your lessons, and don't shove your ideas down other people throats. Op glad your Ok, whats a chick doing driving a 3Z?
NEVER LIFT
Originally Posted by Grishbok View Post
The 86 is a precision car, it does not compensate for driver error, on the road or on the track. This is the kind of car thats created to be the surgeons scalpal of the mass-consumer car world, not a drag car.
whateatsrabbits is offline   Reply With Quote
The Following User Says Thank You to whateatsrabbits For This Useful Post:
SuperDave (05-26-2013)
Old 10-03-2012, 08:07 PM   #62
GNS
Drives: .
Originally Posted by ashtray View Post
"no reason to ever turn off traction control on the street"
Well, I've got one: there's a 50mph road I turn right onto every day. People are usually doing 50-60mph. Busy road. On one occasion I stepped out (turned) and this car started approaching REAL fast. (2 lanes each direction - he was in the left lane but must have pulled out into right lane at 70mph to pass). I saw this as I already started to turn and nailed the gas - only to get a SLOWER response and see that yellow light on my dash flashing. Ugh! Luckily still avoided an accident. Wouldn't have been as close had I put it in sport mode.
Yes, it's a 90 degree turn with my foot on the floor. Yes I've done this a million times in RWD vehicles without any nannies. I was fully prepared for the rear to step out a bit - it didn't. Since that day, when I make that turn, I put it in sport mode. There's some wheel slippage and the back rotates through the turn a little, but easily controlled and I can turn onto that busy street without getting hit.
For the average driver, yes, leave the nannies full on.
I've had this happen before. Now I always assess the situation (when confronted with a road like the above) and turn the stability/traction off when I know that I'll need sudden acceleration, and quick. If there are no oncoming cars for a good long distance, I don't touch the button.
GNS is offline   Reply With Quote
Old 10-04-2012, 02:49 AM   #63
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
Originally Posted by empower-auto View Post
I must be doing something wrong. Unless I am full lock turning in 1st or 2nd or clutch kicking I basically cannot lose grip. I feel ripped off - I want the squirrely version.
same here, it was wet out last night and I turned everything "off" and the traction light still came on the dash...
dori. is offline   Reply With Quote
Old 10-04-2012, 03:14 AM   #64
636
636's Avatar
Drives: '23 CWP BRZ
You didn't turn everything "off" then. Don't just press the TCS button, hold it. For 5 seconds.
Then you'll see the "Traction Off" light come on.
636 is offline   Reply With Quote
Old 10-04-2012, 04:15 AM   #65
zohare
zohare's Avatar
Drives: '13 Firestorm Base AT
I do that and even when stability and tc lights are on I still get interference during.. uh, extreme? Driving. Its not much but that dam light haunts me.maybe its abs or like a virtual diff control or something because its not while under braking. I also have an auto perhaps its a failsafe type deal
Sent from my SPH-D700 using Tapatalk 2
zohare is offline   Reply With Quote
Old 10-04-2012, 05:23 AM   #66
RedRocket
RedRocket's Avatar
Drives: Firestorm Red FR-S
I think it has something to do with how well it corners. People drive these cars aggressively and they stay grounded until well but when it breaks loose and ends up in a full on skid. Typically at higher speeds then most other cars.
RedRocket is offline   Reply With Quote
Old 10-04-2012, 12:43 PM   #67
dori.
Señor Member
dori.'s Avatar
umm... yes I did. I took an extreme u-turn in the wet and the traction control kicked in.
as a matter of fact, if you watch one of the BMI races where Orido drives the 86, he complains about the tc being intrusive even when he turned the TC "off".
What his team ended up doing was removing the fuse for the TCS (which also unfortunately disabled the ABS).
So my question still stands.
Old 10-04-2012, 01:04 PM   #68
636
636's Avatar
Drives: '23 CWP BRZ
Your car must be broken...or mine. I've done donuts/U-Turns in the rain, and NEVER had any traction control kick in to help me. When it says it's off...it's off for me.
Old 10-04-2012, 01:11 PM   #69
Linseal
Linseal's Avatar
Drives: Argento MT Scion FR-S
Yeah same. When the TC is completely off the dash will say trac off and have the car swerving off icon on and stay that way.
Linseal is offline   Reply With Quote
Old 10-04-2012, 01:40 PM   #70
636
636's Avatar
Drives: '23 CWP BRZ
Yeah, I'm almost positive you just "pressed" the button. HOLD IT, until two lights turn on, Traction OFF, and the slip icon will stay on.
If you don't hold it, traction control will AUTOMATICALLY turn back on at wheel speeds over 30mph, which is more than capable in a second in the wet while sliding.
I didn't like the AT and I'm trying to understand why fiveoneoh BRZ First-Gen (2012+) — General Topics 97 06-11-2013 01:34 PM
Crash Test Videos!! Finally.... track_warrior BRZ Photos, Videos, Wallpapers, Gallery Forum 23 09-11-2012 06:32 AM
What I just don't understand... Liquidcell Scion FR-S / Toyota 86 GT86 General Forum 35 08-30-2012 08:38 AM
First crash in spain KritiK Scion FR-S / Toyota 86 GT86 General Forum 3 08-24-2012 09:15 AM
first 86 crash just86 Scion FR-S / Toyota 86 GT86 General Forum 31 03-12-2012 01:23 PM
