#29 |
Drives: RAVEN
Beg to differ on the double clutch method not being of any use. I find that it is one way to get past the 2nd gear "Klunk".
Of all the things that were done right on this car, the 2nd gear synchro was not one of them. I forecast that the synchro goes away completely sometime shortly after the warranty. |
#30 |
Drives: several
I've been teaching a friend to drive stick so I've become aware of the learning process lately. Upshifting quickly and smoothly is a matter of finding and maintaining the sweet spot as you roll back on the gas and off the clutch. Start by giving it more gas (ergo more rpms) than you need and coming off the clutch slowly so the car doesn't get away from you, then each time you do the 4-5 shift go easier on the revs and quicker with the clutch until you've honed it to perfection. There's no particular trick to it, it's really a matter of being tuned in to the car and that just takes practice.
#31 | |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
#32 | |
Drives: 2012 honda civic ex
truck driving days when "helical" gears,instead of "conical gears" were in vogue! double clutching WILL wear out the "throw-out" bearing faster over time,but it's a tough habit for me to break! just sayin' doesn't matter "two shits" about the revs as long as you are NOT lugging the engine in ANY gear! try NOT to "pop" the clutch! smooth engagement is the key! |
#33 |
Drives: Black BRZ Black STI
What gear/ rpm do most people cruise in at 30 mph? Following the shift indicator I'm in fifth around 2000 or if I got a bit faster sixth below 2000. I don't feel the engine lugging but everyone posting that they drive around at 4000 rpm makes me wonder
#34 |
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
At 30-40 mph I'll be in 4th gear. As a rule when I'm going relatively slow and not in a hurry I try to keep the rpm's above 25-2700.
#35 | |
Rugger Extraordinaire
Drives: 1997 Miata, R.I.P. 2013 Red FR-S
The danger comes in when people downshift without rev matching either out of laziness or trying to get as much engine braking as possible per downshift. this puts instantaneous excessive stress on the transmission by putting all the pressure of increasing the crank speed on the gears. this also changes which part of the gears are in contact. Think of it as running at someone full speed and having them slap you in the face as hard as they can as you run by. That's a lot of combined force. Conversely, rev matching is equivalent to them running to catch up to you, and gently putting their hand in front of your face . Also, when people downshift incorrectly, they usually attempt to ease into it by slowly releasing the clutch. This also puts an excessive amount of wear on the clutch as well. |
#36 |
Drives: 2013 Asphalt FR-S MT
maybe the whole break in period thing has me scared. I don't want to hurt my car, so I'm driving like a little old man I guess. I set the light at 4k as per advice in the owners manual and on this forum, and generally shift gears between 2k and 3k. about 40 mph I just shift from 4th to 6th and call it good.
#37 | |
#38 |
Drives: Toyota 86 M High - Dark Grey
after reading some comments here i tried today to drive in 6th at 40mph and to be honest, i imagine that is what it feels like suffocating a new born baby with a pillow.
The car and engine feel completely dead, it's just wrong people.... |
#39 | |
Drives: '13 BRZ Ltd WRB
If you have big feet, don't even try "heel-toe." Use the inside of your foot for the corner of the brake pedal and rotate your foot so the outside edge can blip the gas up to the right RPM/sound/whatever. I don't even think about it anymore, I'd have to TRY to downshift any other way. Whoever said don't ever try this on the street, calm down. Maybe practice somewhere nice and quiet, but it's very useful and can be made to be second nature.
I agree that the 4>5 upshift is a drag. It feels like 5th is two gates over from where it should be...the 1-4 gears are all so nice and tightly packed together. Quote:
#40 |
Señor Member
Drives: white BRZ 6MT
yeah you really ahve to be in 4th or 5th for 40 MPH. My CRZ had no problem doing it though.
IMO after you condition yourself to shift smoothly, I would jsut work on rev matching downshifts.
#41 | |
#42 |
Never on Time Always Late
Drives: #silenced crickets
This car has three "shift personalities"
Ok, so after shifting through a few cold mornings, canyon runs, and stop n goes, i've learned this car has unique shifting/throttle traits..
Morning shifts - Clunky and hard to keep smooth for at least a couple miles.. Slipping or long pauses seem like the only way to avoid jerky 1-2 shifts.. Warm n happy - Smooth shifts are easy to fly through.... I tend to not overshift up (6th at 35-40 yikes!). Downshift only when needed (freeway speed to offramp). Traffic lights coast to N or to 2nd if I know lights going to change. AC On - Yikes.. Off the line the throttle seems off and requires decent throttle increase to match AC off movement.. Once off the line, higher RPM's are needed to avoid bog 1-2-3... I'm sure this is common, but you would think the computer would adust to not make the driver feel the drag of the AC compressor so much. |
| Proper 2 bucket wash method | CU2MIKE | Southern California | 45 | 09-27-2012 07:15 PM |
| Is this a bad way to stop when driving manual? | artizhay | Engine, Exhaust, Transmission | 39 | 09-21-2012 04:32 AM |
| daily driving and heel-toe method | denverizzles | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 08-21-2012 03:51 PM |
| Best Manual transmission driving techniques? | rawbz | Other Vehicles & General Automotive Discussions | 24 | 05-23-2012 12:15 PM |
