Old 10-03-2012, 10:17 AM   #15
df.dima
Drives: FR-S and Mazda 3 Sky
Originally Posted by encity5 View Post
I've also tried using my hand twisted so the back of my hand would be facing me and I would just push up to the right, this ways goes pretty smooth and fast for me but gotta get use to the hand position.
I had this same issue first. This is exactly how I do it and by now I'm almost always on point. Its a kind of move like you'd put your palm to someones face and push them away . Just doing it in diagonal direction away from you with the shifter.
On the other hand 5-6 gives me way too much time while dropping in rpms...
df.dima is offline   Reply With Quote
Old 10-03-2012, 10:19 AM   #16
Razor
Razor's Avatar
Drives: FR-S in Raven 6MT
For shifting from 4th to 5th I have found that the hand position ( the back of it facing me ) simplifies things tremendoulsly. I keep the same hand position from 5th to 6th and when upshifting. The sweet spot in this car is between 3500 and 5000 RPM , so I only down shift to 4th when I am at cruising speed.
Razor is offline   Reply With Quote
Old 10-03-2012, 10:19 AM   #17
Vladror
Vladror's Avatar
Drives: Toyota 86 M High - Dark Grey
Originally Posted by enjoi23 View Post
obviously you have more experience with the manual transmission than me, but I was always taught that switching from 6 to 3rd is dangerous, well that switching gears in general was dangerous. Does it damage the transmission at all or..?
why would shifting gears be dangerous?
Shifting down is maybe dangerous if you don't take your foot off the gas cause the car will lunge forward if you don't.
Shifting gears can be dangerous if you do it at speed in corners, b/c while you press the clutch you take the power of the wheels which can make the car behave unpredictably. as a rule of thumb, ALWAYS have the car in the appropriate gear BEFORE you hit the corner. don't shift when you're hitting maximum Gs at the apex of the corner.
when going downhill, shifting into lower gear is a good way to slow the car down without having to break all the time. it prevents your brakes from overheating and it also assures that you have power on the wheels at all time to control the car better.
from the comments here so far, i feel i also need to point out that heel and toe driving is NOT right for day to day driving, it's a trick that racing drivers use but especially if you come from an automatic car, don't even try it and keep your right foot EITHER on the gas or on the brake, not on both at the same time. your left foot is only used on the clutch...
Vladror is offline   Reply With Quote
The Following User Says Thank You to Vladror For This Useful Post:
enjoi23 (10-03-2012)
Old 10-03-2012, 10:27 AM   #18
enjoi23
12% Done with the car.
enjoi23's Avatar
Drives: FRS
well the person who taught me says it grind the gears too hard and after awile it could really take a toll on the car. also when I drove standard when learning, I accidentally went from 6 to 4th before and the car tremendously slowed down and I know that's a given because I downshifted but it didnt feel too healthy on the cars part
HOUSTON TEXAS FR-S/BRZ OWNERS - https://www.facebook.com/groups/houston86/
enjoi23 is offline   Reply With Quote
Old 10-03-2012, 10:34 AM   #19
fiveoneoh
Drives: none
I think he's asking how to not take so long, and we aren't always racing so there are times you'd want to shift in lower rpms, the economy shift light comes on at around 2k anyway when in 4th
dude,what? there is a light that tells you when to shift? I don't recall seeing it when I test drove a MT. how annoying,it's like a saturn! please clarify!
fiveoneoh is offline   Reply With Quote
Old 10-03-2012, 10:51 AM   #20
Vladror
Vladror's Avatar
well yes if you skip gears, you need to compensate with the throttle or brakes to reduce the difference in RPMs, you shouldn't go from 7000 RPM to 2000 (or vice versa) without easing the transition but if you don't skip gears ever, you will find yourself in situations where you're unable to respond to what's happening on the road.
for instance, you're cruising in 6th at 2000 RPMs and something happens in front of you that requires you to get the hell out of the way. If you just slam the brakes, the car will stall eventually. if you brake and clutch without shifting gear the car won't move when you put you'r foot back on the gas (or might even stall). If you brake, clutch and shift down a few gears all at the same time, you'll have the car at the right RPM to move out of the way.
Old 10-03-2012, 10:53 AM   #21
Realm
Drives: Scion FR-S
First thing I did was turn my gear indicator/shifting light on... I can't remember exactly how, but you hold the "odo" button down (make sure you leave the engine OFF, just activate your senors).
Edit: here is how I figured it out by another poster: "To get the G-Off/On, you have to hit the ODO button when the car is off but the key is in the ACC position."
Also, am I the only person who does not down shift? I like to keep strain off the transmission and just take it out of gear before a stop. Breaks are cheaper than transmission parts
Realm is offline   Reply With Quote
Old 10-03-2012, 11:01 AM   #22
Mochikomi
Mochikomi's Avatar
Drives: 2013 WRB BRZ Premium 6MT
The danger in large downshifts is manually over-revving the engine. That *is* dangerous. If you shift down to a gear that is past redline for the speed you are travelling, the rev limiter can do nothing to prevent severe engine damage.
On double-clutching: If you're doing a skip shift in either direction, double clutching is useful to make the shift easier and have less wear on the synchros. It's not necessary, but it has it's place.
Mochikomi is offline   Reply With Quote
Old 10-03-2012, 11:04 AM   #23
enjoi23
enjoi23's Avatar
Drives: FRS
ah, I understand your meaning now. Thanks!
Old 10-03-2012, 11:20 AM   #24
ToxicSneakers
Deleted
ToxicSneakers's Avatar
Hmmm... I learned to crash-box (non-synchro) shift (without use of the clutch at all) road racing (track). I now have the AT with auto-rev matching and it's like old times - but much more quiet. Anyone driving the MT clutchless?
ToxicSneakers is offline   Reply With Quote
Old 10-03-2012, 11:33 AM   #25
Vladror
Vladror's Avatar
spoken like a true AT driver
seriously though, ideally you keep the car in a state that enables it to respond to the throttle if necessary. that means at whatever speed you're going, your gear should correspond with the situation (speed/context) you're in. So even if you're braking and keeping your foot on the clutch, shift down through the gears as you decelerate. It doesn't put any strain on the transmission whatsoever but it does mean if something unexpected happens you have power at your disposal immediately without having to shift into the right gear first.
ZakD (10-23-2012)
Old 10-03-2012, 12:09 PM   #26
ST185RC
Drives: White Out FR-S
There are tutorials on youtube that shows you how you can set the shift light and beeps at an RPM of your choosing.
You have to scroll through the dash options with the display button below the odo button on your dash. change it to REV and press the display button to choose to set it. Hold down on the first digit to scroll through how many RPMs you want before the shift light and beep comes on. You can also turn off the beep and only have the shift light.
The coold thing is that when you turn on the car, the tach sweeps to the preset RPM warning.
ST185RC is offline   Reply With Quote
Old 10-03-2012, 12:26 PM   #27
Realm
Drives: Scion FR-S
"AT driver"? Automatic Transmission? I've never owned one before... are you saying you're supposed to downshift in a manual transmission to decelerate? If so, I guess I have been driving wrong for the past 19 years I always thought it would ease unecessary strain on the gears. Same as how I always engage the clutch even to take the vehicle out of gear... I dunno
Old 10-03-2012, 02:26 PM   #28
encity5
encity5's Avatar
There's a programmable shift light and an economy shift light/arrow next to the gear indicator
encity5 is offline   Reply With Quote
Proper 2 bucket wash method CU2MIKE Southern California 45 09-27-2012 07:15 PM
Is this a bad way to stop when driving manual? artizhay Engine, Exhaust, Transmission 39 09-21-2012 04:32 AM
daily driving and heel-toe method denverizzles Scion FR-S / Toyota 86 GT86 General Forum 13 08-21-2012 03:51 PM
Best Manual transmission driving techniques? rawbz Other Vehicles & General Automotive Discussions 24 05-23-2012 12:15 PM
