Old 10-03-2012, 08:08 AM   #15
CBR600RR
Drives: Raven Black
Originally Posted by Sony View Post
Normal, my Perrin exhaust smelled and smoked something awful for the first 100 miles. I know for a fact that I did not leave any packing materials inside it ether. There is a lot of machining oils and residue left over inside a new exhaust from the manufacturing process, it's normal. The first 100 miles will consist of burning off and removing all those contaminants using the heat of the exhaust, it is a perfectly normal occurrence. It will also smell terrible for those first 100 miles too.
When I mentioned packing material inside the exhaust i did not mean 'packaging' material. I meant the fiberglass packing that is often used in the muffler as a noise reduction material.
The only way to remove the packing material inside a muffler is to cut it open. this fiber glass packing is very common in motorcycle exhausts.
The Following 2 Users Say Thank You to CBR600RR For This Useful Post:
Spaceywilly (10-03-2012), travace (10-03-2012)
Old 10-03-2012, 08:23 AM   #16
travace
travace's Avatar
Drives: Scion FR-S
never knew they packed auto mufflers the same way. must be different in some ways cause motorcycle packing is made to be replaced
travace is offline   Reply With Quote
Old 10-03-2012, 09:23 AM   #17
CBR600RR
Drives: Raven Black
^ it depends on the muffler and the packing inside the auto exhausts is generally made of a different material. As far as I know all OEM auto exhausts have no packing.
usually it is only the straight through auto mufflers that have packing. (hard to call these types a muffler)
now that I think about it the TRD muffler might very well not have packing inside. but the oils from manufacturing will make smoke too, but I would think that the smoke from oils would burn off very quickly (like 5-10 minutes of being at operating temp) as opposed to the smoke caused by packing.
The Following User Says Thank You to CBR600RR For This Useful Post:
Old 10-03-2012, 11:12 AM   #18
jadewbj
jadewbj's Avatar
Yeah, this is totally normal. It is the filling inside the muffler that smokes.
jadewbj is offline   Reply With Quote
Old 10-03-2012, 12:36 PM   #19
Verge
Verge's Avatar
Drives: 2013 Scion FRS
Originally Posted by DaveFTW View Post
I just got the exhaust installed from my local stealership and after leaving the dealership someone else on the road told me there was alot of smoke coming from the exhaust.
I immediately pulled over called the dealership back and asked if this was normal or should I come back.. they told me dont worry its normal you just need to run the engine...
my question is, is it really normal for new exhausts to smoke like I dont have oil, AND it smelled like burning plastic...
My thoughts are an idiot mechanic didn't take out some of the bubble wrapping.. help.
Vids please. Still deciding if i should wait fir this or get the evo3
Verge is offline   Reply With Quote
Old 10-03-2012, 03:33 PM   #20
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
Completely normal.
Touge Factory is offline   Reply With Quote
Old 10-03-2012, 03:37 PM   #21
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Some smoke is normal. Clouds of smoke is not.
Old 10-03-2012, 03:59 PM   #22
MarkRacerX
MarkRacerX's Avatar
Drives: 12' Evo X , prior 1st 86 FR-S
Same thing Freaked me out buying my 11' STi w/ SPT catback installed leaving dealership taking it home, white smoke , smelled bad, but was briefly within 20miles or so.
Now, Lets Hear it Roar !!!
Autocross & Drift = my Anti Drug!!
I have Car A.D.D prior few:
12' Evo GSR, 13' FR-S, 11' STi, 08' 135i, 07' 335Xi,
08' STi, 04' 350Z, 04' STi, 02' WRX. 96' GSR, 04' SE-R/SpecV
MarkRacerX is offline   Reply With Quote
Old 10-03-2012, 04:03 PM   #23
FRSnCLN
Drives: 2013 ultramarine scion fr-s
im putting my trd on tonight. ill try and get a sound clip up.
FRSnCLN is offline   Reply With Quote
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 09:30 PM
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 09:47 PM
Socal shops that offer tail light smoke out mod? bcmakesiteasy Cosmetic Modification (Interior/Exterior/Lighting) 12 10-18-2012 03:22 PM
Plastidip Smoke Sutty Cosmetic Modification (Interior/Exterior/Lighting) 1 09-29-2012 05:04 PM
Are you going to smoke out your tail lights? Liquidsnake Cosmetic Modification (Interior/Exterior/Lighting) 8 06-06-2012 09:02 AM
