Old 08-15-2012, 04:51 AM   #1
taiguochin
Drives: 2013 Subaru BRZ Limited WRB
Keyless Entry and Start-up issues
Hey guys,
I just picked up my BRZ the past Saturday and I've ran into this problem. When I am on the drivers side trying to get into the car, I get issues with the sensor picking up my key.
Also after getting into the car, the car will be slow to recognize the key so I will have to try a couple of times in order to start the car.
But it seems to work fine when i try to unlock and lock through the passenger side of the door. Any help or suggestions?
Thanks!
taiguochin is offline   Reply With Quote
Old 08-15-2012, 05:24 AM   #2
Enemies
Drives: '13 SWP Sport-Tech (Limited)
Do you have anything else in your pocket? Do you keep the key in the same pocket as your cell phone? I'd try keeping the key in a pocket with nothing else and do some tests. If it still acts up I'd drive by the dealership and see if they can replicate it.
Also, lastly, does it do it with both keys?
Enemies is offline   Reply With Quote
Old 08-15-2012, 06:55 AM   #3
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
+1. Also, maybe you have a bad battery in the key fob. Anyways, bring it back to the dealership unless the problem is a cell phone in your pocket.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 08-15-2012, 11:10 AM   #4
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
This happens with my wife's Prius sometimes. I think sometimes she tries to start the car too fast.
Get in, shut the door, pause, then try to start the car.
86'd is offline   Reply With Quote
Old 08-15-2012, 01:22 PM   #5
taiguochin
thanks for the response guys!
It does happen with both keys. My cellphone is in the other pocket so I don't think that will effect it.
I guess I will have to bring it back to the dealership to have them take a look. It seems like no one else is effected by this.
Old 08-15-2012, 11:11 PM   #6
ngabdala
Good call. You shouldn't be changing the way you start the car just to remove the problem. It should just work.
Old 08-15-2012, 11:47 PM   #7
DeepHunta
Drives: '05 Outback Wgn, '05 Lotus Elise
Never happened to me. I agree with everyone. Bring back to dealership.
Proud ex-owner of GBS 6MT BRZ Limited. Pre-ordered on Feb-29-2012, got VIN on 5/19 with ETA 6/6, arrived early on 6/2, but still didn't pick it up until Jun-6-2012. Recently sold the Buuurz as of 4/21/2014
DeepHunta is offline   Reply With Quote
Old 08-15-2012, 11:57 PM   #8
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Only issue I have had is that if I put it in the same pocket as my phone it won't pick it up. Otherwise it's worked fine. I have noticed in general key fobs don't have as much range when I'm in the city, so maybe that could be part of it? Only thing I can think of is to switch which pocket you put the key in, maybe that will make it closer to the antenna.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 08-17-2012, 09:52 PM   #9
BRaZinDave
BRaZinDave's Avatar
Drives: WRB Limited AT, 1965 COBRA,
At night when I walk up to my locked car at about 5-8 feet away the interior light comes on!
BRaZinDave is offline   Reply With Quote
Old 10-03-2012, 06:12 AM   #10
Margovincent_22x
Margovincent_22x's Avatar
Drives: Lightning Red BRZ MT Limited
I have the same problem. I live in PHILIPPINES and this problem also bothers me. There is no dealer for BRZ in the area at least not until December this year. I tried replacing the batteries. Tried separating the keys and my phone. tries to shake the keys and tried to do other stupid stuff but the problem still persist. Can anyone provide me some tips or help.
Margovincent_22x is offline   Reply With Quote
Old 10-03-2012, 06:24 AM   #11
cmspooner
cmspooner's Avatar
Drives: 2013 SWP Limited BRZ - Manual
Is your key in your right pocket or left? The key needs to be near the center of the car for the sensor to read it. As a test drop you keys into the cup holder area and see if it starts properly, then see how far you can move the key left in the car before it fails to start.
cmspooner is offline   Reply With Quote
Old 10-03-2012, 07:06 AM   #12
Nardi330
Nardi330's Avatar
Drives: 86
I always have my key in the pocket near the door and never have problem starting....
Nardi330 is offline   Reply With Quote
Old 10-03-2012, 10:42 AM   #13
Umbie
Umbie's Avatar
Same here. I was having a few issues when I first bought the car, but then I realized you need to push the clutch down slightly further to start the car than you do to shift gears.
If you're having issues repeatedly and are SURE its not your fault, take it to the dealer.
Umbie is offline   Reply With Quote
Old 10-03-2012, 10:45 AM   #14
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
^ This...
2023 GR Cup Car
Opie is offline   Reply With Quote
Keyless remote replacement sesmls BRZ First-Gen (2012+) — General Topics 25 06-05-2014 10:23 PM
BRZ keyless entry/ignition and auto climte control system how-to video ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 26 11-21-2013 01:58 AM
How secure is the Keyless Entry and Start system? SeattleJeremy BRZ First-Gen (2012+) — General Topics 31 09-22-2013 11:23 PM
BRZ Keyless entry? Motopythons CANADA 7 06-03-2012 05:56 PM
Keyless access option on limited brzninja BRZ First-Gen (2012+) — General Topics 25 04-12-2012 06:49 AM
