Old 10-02-2012, 08:09 PM   #1
DaveFTW
DaveFTW's Avatar
Drives: 2013 86
Smoke from new USA TRD exhaust
I just got the exhaust installed from my local stealership and after leaving the dealership someone else on the road told me there was alot of smoke coming from the exhaust.
I immediately pulled over called the dealership back and asked if this was normal or should I come back.. they told me dont worry its normal you just need to run the engine...
my question is, is it really normal for new exhausts to smoke like I dont have oil, AND it smelled like burning plastic...
My thoughts are an idiot mechanic didn't take out some of the bubble wrapping.. help.
I'd change the world if I could change my mind
DaveFTW is offline   Reply With Quote
Old 10-02-2012, 08:11 PM   #2
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Sounds like you said... packaging wrap. If you can confirm it, get a new one at their cost.
Sent from my PC36100 using Tapatalk 2
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 10-02-2012, 08:12 PM   #3
RedRocket
RedRocket's Avatar
Drives: Firestorm Red FR-S
I would imagine there is a lot of oil's on the metal from the bending process.. I wouldn't worry about it unless it doesn't go away in about 60 miles.
RedRocket is offline   Reply With Quote
The Following 3 Users Say Thank You to RedRocket For This Useful Post:
20valvewynn83 (10-03-2012), DaveFTW (10-02-2012), Guff (10-03-2012)
Old 10-02-2012, 08:14 PM   #4
CBR600RR
Drives: Raven Black
Yes it is normal for new exhausts to smoke a bit.
The packing in the muffler is causing the smoke. After a bunch of miles it will stop smoking.
The Following 7 Users Say Thank You to CBR600RR For This Useful Post:
20valvewynn83 (10-03-2012), DaveFTW (10-02-2012), Guff (10-03-2012), Jeff Lange (10-02-2012), JoeBoxer (10-02-2012), raz0rbladez909 (10-03-2012), Tim_Asphalt_FRS (10-03-2012)
Old 10-02-2012, 08:14 PM   #5
fl_speed001
Drives: Whiteout FR-S
Maybe the tips were wrapped in plastic to protect them and they forgot to take to off? If that was the case should be pretty obvious, melted plastic stands out pretty well against stainless steel...
And every aftermarket exhaust I have ever installed has smoked a little bit initially, oils from manufacturing process burning off.
fl_speed001 is offline   Reply With Quote
The Following User Says Thank You to fl_speed001 For This Useful Post:
Old 10-02-2012, 08:14 PM   #6
DaveFTW
DaveFTW's Avatar
Drives: 2013 86
I literally thought my car was on fire, other than that it sounds amazing...
Old 10-02-2012, 09:01 PM   #7
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
This.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 10-02-2012, 09:38 PM   #8
SF-FRS
Drives: 2013 Scion FRS
you've got the TRD exhaust already???????
SF-FRS is offline   Reply With Quote
Old 10-03-2012, 01:31 AM   #9
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
Normal, my Perrin exhaust smelled and smoked something awful for the first 100 miles. I know for a fact that I did not leave any packing materials inside it ether. There is a lot of machining oils and residue left over inside a new exhaust from the manufacturing process, it's normal. The first 100 miles will consist of burning off and removing all those contaminants using the heat of the exhaust, it is a perfectly normal occurrence. It will also smell terrible for those first 100 miles too.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
The Following User Says Thank You to Sony For This Useful Post:
Guff (10-03-2012)
Old 10-03-2012, 01:40 AM   #10
Furtive
Furtive's Avatar
Drives: 13' SSM BRZ
Mine smelled and smoked for a few miles, its pretty normal
Furtive is offline   Reply With Quote
Old 10-03-2012, 01:54 AM   #11
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
sound clip!
Tylub is offline   Reply With Quote
Old 10-03-2012, 02:02 AM   #12
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
it's normal.
seven is offline   Reply With Quote
Old 10-03-2012, 03:40 AM   #13
CyberFormula
CyberFormula's Avatar
Drives: gti, nsx, integra type r,porsche911
new exhaust smell is normal.
Smells like burning oil
Once broken in, no more or very little smell.
CyberFormula is offline   Reply With Quote
Old 10-03-2012, 07:39 AM   #14
travace
travace's Avatar
Drives: Scion FR-S
thats what im saying... WTF my dealer didn't even have it in the system last week.
travace is offline   Reply With Quote
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 09:30 PM
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 09:47 PM
Socal shops that offer tail light smoke out mod? bcmakesiteasy Cosmetic Modification (Interior/Exterior/Lighting) 12 10-18-2012 03:22 PM
Plastidip Smoke Sutty Cosmetic Modification (Interior/Exterior/Lighting) 1 09-29-2012 05:04 PM
Are you going to smoke out your tail lights? Liquidsnake Cosmetic Modification (Interior/Exterior/Lighting) 8 06-06-2012 09:02 AM
