Old 09-28-2012, 08:59 PM   #1
msile
msile's Avatar
Drives: ISF
Another AVO/Perrin Install
Mods (Performance) so far....
Rays 17” Seibon Edition - 15.5 Pounds. Wheel and Tire two pounds less than stock. http://www.ft86club.com/forums/showthread.php?t=16843
Perrin Pulley
HKS Cat-Back Exhaust
Nameless Down&Over Pipe with High Flow Cat
AVO Intake
Perrin Filter
PTF CF Drive Shaft - http://www.ft86club.com/forums/showthread.php?t=18364
FA20 Club Flash - http://www.ft86club.com/forums/showthread.php?t=17974
The install was very simple. The fit and finish was excellent and everything lined up perfectly. Initial observation was very good. Good throttle response, no bogging and smooth acceleration to redline. With some of my other mods, the tach spins to redline like a rocket already. This was just icing on the cake.
1993 MR2 Turbo - Red
1996 Supra Turbo - White
2011 ISF - Mercury Metallic / Black Suede
2013 Scion FR-S - Firestorm Red
2014 Lexus GS F-Sport - White / 2015 Lexus RCF - Blue (Nov Delivery)
msile is offline   Reply With Quote
Old 09-29-2012, 06:30 PM   #2
fl_speed001
Drives: Whiteout FR-S
I am considering this combo as well, already have the Perrin filter. Did AVO include the plug for the sound generator or did you add that on your own? If you added it care to share the plug size?
fl_speed001 is offline   Reply With Quote
Old 09-29-2012, 08:11 PM   #3
msile
msile's Avatar
Drives: ISF
Got the plug from Dustin@Dynosty. He is a vendor here.
Old 10-01-2012, 03:31 PM   #4
Dustin@Dynosty
very clean!
Dustin@Dynosty is offline   Reply With Quote
Old 01-07-2013, 06:51 AM   #5
garf
Great Member
garf's Avatar
Drives: raven, baught 8-29-12, manual
any changes on your impression on the intake? still running good? and do you think its worth the money? Oh and either way im buying that plug asap!
garf is offline   Reply With Quote
Old 01-07-2013, 08:58 AM   #6
gmookher
nice build ...
where is a thread on your HKS setup?
Old 01-07-2013, 09:07 AM   #7
karne
Drives: frs
How many miles did you do on that setup so far?
karne is offline   Reply With Quote
Old 01-07-2013, 10:03 PM   #8
bigjake
Drives: 2013 Scion FR-S, Firestorm
perrins own silicone tube is much better
bigjake is offline   Reply With Quote
Old 01-08-2013, 03:01 AM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
How did you come to that conclusion?
Msile, any reason you went for the AVO and plugged it rather than one that deletes the noise pipe and resonator? I've just fitted mine but I got it because I wanted to keep my noise generator.
Old 01-08-2013, 07:29 PM   #10
bigjake
The overall design incorporates a less gradual bend, which means better flow, as well as no openings for a resonator or sound generator, which he wound up plugging.
Old 01-08-2013, 07:42 PM   #11
Hawk77FT
Drives: GTS 86
The sound generator does not affect the perfomance of the tube at all. It does not suck air and does not affect the airflow. And let's say, even if it does the difference is so insignificant that you wont be able to notice.
Also, if you look careful, the "less gradual bend" in Perrin's design, actually has two bends rather than one - less bends the better. The only thing that could make a diference in the Perrin's tube is the slightly larger tube diameter on one of the tube bends. that part however could get quite hot from the engine so it might not be a beneficial. Look at the design of the FA20 club intake. that is what I would call "much better".
The differences in the AVO/Perrin/Zeta perfomance is so small that you wont feel the difference. I guess the price is the deciding factor here. And yes, maybe the look under the bonnet.
Hawk77FT is offline   Reply With Quote
Old 01-08-2013, 08:12 PM   #12
bigjake
I didn't mention the sound generator delete making less power, I'd have to agree with you on that, but since he plugged it anyways, it was worth noting.
Old 01-09-2013, 03:03 AM   #13
Kodename47
Kodename47's Avatar
Drives: UK GT86
Exactly. These silicone pipes all do the same thing so you can't really say one is much if any better than another. The differences are all so tiny that they probably all perform identically. After all the Perrin has smoothed bends but the AVO is oversized. For me, I wanted to keep the noise pipe. If I hadn't I wouldn't have got the AVO but not because it's not as good as another.
So Hawk has it in a nutshell (but I'll add in Samco too):
The differences in the AVO/Perrin/Zeta perfomance/Samco is so small that you wont feel the difference. I guess the price is the deciding factor here. And yes, maybe the look under the bonnet.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-09-2013, 03:16 AM   #14
Hawk77FT
Drives: GTS 86
In terms of quality they all look quite good (4 ply reinforced silicone, etc) so I can't find anthing wrong with that. Now I am thinking to take one silicone tube and wrap it in CF leaving the end uncovered. That might help with the heating problems (if any) and bring MORE bling under the hood.
I can see the Perrin having the edges slightly smooter but what difference would that make in terms of performance? I am guessing close to zero.
Why did you want to keep the tube? I am quite tempted to keep mine too.
Camshaft Bolt Coming Loose After Perrin Pulley Install WhiteBRZ Engine, Exhaust, Transmission 25 09-20-2012 08:07 AM
How do you install the mud guards? Moshpit37 Scion FR-S / Toyota 86 GT86 General Forum 11 07-27-2012 11:13 PM
oem headunit install encity5 Electronics | Audio | NAV | Infotainment 4 07-22-2012 10:27 PM
How to install mudguards? FRiSson Cosmetic Modification (Interior/Exterior/Lighting) 2 07-13-2012 07:34 PM
Spoiler Install CharlieChaos Cosmetic Modification (Interior/Exterior/Lighting) 1 07-07-2012 10:43 AM
