Old 09-22-2012, 06:46 PM   #1
FRiSson
Drives: FR-S MT
Anyone having throttle issues?
My FR-S after 6,000 miles started losing power at times. Particularly at low revs, I'll be driving along and the engine starts to lose power a little, forcing me to press harder on the accelerator to compensate. Also, when I press the gas, when the car is at idle speed 650 rpm, the engine shivers a bit before picking up. I don't know it the two issues are related. I can rule out bad gas, since I have been using Shell 93. It is a stock motor.
FRiSson is offline   Reply With Quote
Old 09-22-2012, 07:05 PM   #2
Yruyur
Yruyur's Avatar
Sounds like the cel issue cropping up
Old 09-22-2012, 08:47 PM   #3
eclipsed
Drives: Firestorm Fr-S
Mine is starting to have the same sort of issue, only 800 miles though.
eclipsed is offline   Reply With Quote
Old 09-22-2012, 09:04 PM   #4
FRiSson
Drives: FR-S MT
Can you describe what you are experiencing?
Old 09-22-2012, 10:38 PM   #5
brianbot5000
brianbot5000's Avatar
Drives: White WRX Hatchback, Toyota Pickup
Sounds similar to this: http://www.ft86club.com/forums/showthread.php?t=16997
I've experienced this too, intermittently, only when accelerating from a stop (coming off of idle). RPM's dip slightly, feels rough. Not very noticeable, but it does happen from time to time. 1200 miles on my car. My 1968 Datsun 2000 would so this too - didn't expect it from my brand new BRZ.
2013 Subaru BRZ, SSM Limited
vin: 6007xx
build: 3/2012
brianbot5000 is offline   Reply With Quote
Old 09-23-2012, 03:29 PM   #6
Nick Graves
Drives: GT Blue Hachi Roku, Pile of Hondas
Ours does it too sometimes - almost like a very sticky throttle cable might feel, if it had one.
Also, S2000 do it worse and it's due to heat soak due to their poor intake design.
I think it's jammy cams in his case, but it might easily be something else.
Nick Graves is offline   Reply With Quote
Old 09-23-2012, 05:23 PM   #7
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Sounds like this problem...
http://www.ft86club.com/forums/showthread.php?t=15651
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 09-23-2012, 09:14 PM   #8
FRiSson
Drives: FR-S MT
Originally Posted by @Art_Mighty View Post
No, that sounds somewhat different. The problem in my car happens at neutral throttle. Most noticeably at rpm's under 2,000, the engine bogs down, feels like the brake is being applied. When I compensate by pushing on the throttle it gets worse, then in about 1/2 a second the engine finally starts to rev up again. Very disturbing. I'm pissed.
Old 09-23-2012, 11:52 PM   #9
DSTL
Drives: 2013 BRZ Limited 6MT
Any cel? You have any mods or all stock?
Edit: you open up your intake and look for any obstructions @ filter? Reason I ask is I had a rubber glove left in mine from factory. Leaf or anything it sucked in could cause probs too and easy thing to check off of your list. Mouse nest thread was the best so far. Ugh.
DSTL is offline   Reply With Quote
Old 09-24-2012, 06:11 AM   #10
Nick Graves
The cure seems to be to take it out for a good ragging down a back road.
It's sweet as a nut again now.
I wonder if it's the DI making it a bit cokey in heavy traffic?
Old 09-24-2012, 11:13 AM   #11
FRiSson
Drives: FR-S MT
No Mods on the car. Checked the filter - it is clear. Ran the car at high RPM's too. Did not change the problem.
"Cokey" is a new one to me.
Old 09-24-2012, 12:21 PM   #12
DSTL
Figured that wouldn't be it, but also figured there wouldn't be a rubber glove in the intake on mine, ha. I will say that I got a bad tank of gas from a reputable place that I get gas from often and had some issues. Knock correction was spitting out high numbers (over -4) and had bogging. Was worst going from off throttle to 1/4 or 1/2 throttle suddenly at lower rpms. Feathering the throttle and full throttle wasnt as bad and disappeared over 3k rpms. Wouldn't automatically check that off of your list because it's shell gas. All fixed with a new tank. Good luck!
Old 09-24-2012, 01:11 PM   #13
FRiSson
Drives: FR-S MT
I wish it were bad gas, but I am into my third tank since the problem began, with no improvement.
Old 09-25-2012, 06:35 PM   #14
choi0706
Drives: t
my throttle is very laggy.. not sure if it was related to my cel/sl problem but it was like this from day one.. I had a cel come up pretty quick, under 300 miles.
choi0706 is offline   Reply With Quote
Dirty throttle body AVOturboworld Engine, Exhaust, Transmission 11 05-11-2016 11:58 AM
Cusco 'Large Throttle' ultra Engine, Exhaust, Transmission 3 09-05-2012 03:47 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 08:44 PM
Throttle Controllers harajukukei Engine, Exhaust, Transmission 31 07-28-2012 01:40 AM
