Old 09-21-2012, 05:49 PM   #127
Liquidsnake
Drives: "I drives like a Porsche"
Every time, every day.
Liquidsnake is offline   Reply With Quote
Old 09-24-2012, 11:30 PM   #128
charger
Drives: frs
I can open/close the passenger window with the passenger side window button, but I can't open/close the passenger window with the driver side button. The passenger button "auto" light also blinks. Sometimes I can get it to open/close from the driver side, but it is broken for sure. I'll need to take it in unfortunately.
charger is offline   Reply With Quote
Old 09-24-2012, 11:35 PM   #129
koteman
koteman's Avatar
Drives: Scion frs
Sounds like the Tc where u disconnect the switch or battery u have to reset it. From the passenger side try rolling the window halfway down then roll it all the way up and hold the button up for 10 seconds after. It should stop the blinking and make it work again. Don't have my frs yet so I can't test. Just a guess like my Tc was
koteman is offline   Reply With Quote
Old 09-24-2012, 11:51 PM   #130
charger
Drives: frs
It's a temporary solution if it works, but I'll give it a try and update the post with results.
Edit: It worked, thanks! I didn't disconnect any switches though, but at least I know how I can get it to work properly. I just searched through the thread and saw that other people were holding the switch up to get it to work, but I'll need to bring it to the attention of a dealership the next time I have to come in.
Old 09-24-2012, 11:58 PM   #131
soconfoozed
Drives: 2013 BRZ Limited 6MT WR Blue Pearl
Originally Posted by was385 View Post
Just got a call from my dealer that SOA has a service bulletin on this issue saying they're aware of the complaints, but that it works how it's supposed to and they should not fix it. I'm going to go in and read this bulletin, because that's garbage. One auto button should not work differently than the other.
Oh boy...
I'm going in for this one tomorrow. Sounds like I'm going to have a fun day of yelling at Subaru. If this is indeed true, I'm going to be even MORE upset for my CSR even letting me go to the dealer for this in the first place. Yet another effing waste of my time. Thanks, SoA!!
Groan.
soconfoozed is offline   Reply With Quote
Old 09-25-2012, 08:40 AM   #132
jazztennor
jazztennor's Avatar
Drives: Scion FR-s
Ya same problem here it works like 50% of the time and only the passenger side.
jazztennor is offline   Reply With Quote
Old 09-25-2012, 08:54 AM   #133
Justin.b
Drives: 13 Hot Lava, 01 Miata, 09 Outback
Originally Posted by BMWDavid View Post
Mine works fine...100%
I have never had the issue. It's always worked for me. My wife in the same car says it usually doesn't work for her. I was convinced it was the way she operates the switch.
-Justin
Justin.b is offline   Reply With Quote
Old 09-25-2012, 09:27 AM   #134
danthemann5
Yep, every fkn time.
danthemann5 is offline   Reply With Quote
Old 09-25-2012, 10:23 AM   #135
jadewbj
jadewbj's Avatar
I thought It was me not hitting it hard enough. I hope a TSB comes out soon.
jadewbj is offline   Reply With Quote
The Following User Says Thank You to jadewbj For This Useful Post:
Godzilla35 (09-29-2012)
Old 09-25-2012, 12:57 PM   #136
slaxx
Drives: '13BRZl, '14FiestaST2, '10Insight2
Subaru replaced the drivers-door window switch module but that didn't fix the problem.
Took them a day to replace the switch: needed software updates to correctly program the replacement for the car via a Subaru support escalation
slaxx is offline   Reply With Quote
Old 09-27-2012, 01:32 PM   #137
FRiSson
Drives: FR-S MT
I fiddled with it for quite a while and found that if I press it for a half second it goes up or down uninterrupted. Anything longer or shorter than that did not trigger auto open/close. So maybe they just made the frequency interval too narrow.
FRiSson is offline   Reply With Quote
The Following User Says Thank You to FRiSson For This Useful Post:
ftc~brz (09-28-2012)
Old 09-28-2012, 12:58 PM   #138
Maz
Drives: scion Fr-s
Same
Maz is offline   Reply With Quote
Old 09-28-2012, 07:14 PM   #139
slizoth
slizoth's Avatar
Drives: 2013 WRB Subaru BRZ
Definitely noticed this on my car as well.
slizoth is offline   Reply With Quote
Old 09-28-2012, 07:20 PM   #140
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
I have problems with this on my passenger window. I figured it was probably something to do with the switch sensitivity. I have to press it a little harder than the drivers door to get it to work. I figure I'll mention it when I go in for my 5k appointment in november/december.
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Window Tint IceCreamMan Cosmetic Modification (Interior/Exterior/Lighting) 46 09-22-2012 02:43 PM
Window Tint in South Florida lordtakuban Southeast 9 06-30-2012 07:46 PM
Charlotte NC window tinting Thongpocket BRZ First-Gen (2012+) — General Topics 1 06-28-2012 12:38 PM
Window Tint Before and After Suiris FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-24-2012 10:37 PM
Window tint in MI eikond Great Lakes 4 06-01-2012 01:59 AM
