Old 09-08-2012, 03:38 AM   #113
gdi2290
Web Designer/Programmer
gdi2290's Avatar
Drives: WRB BRZ Limited (Lemon)
Yup same same. This results in that awkward moment where you have to turn the car back on just to roll up the window
gdi2290 is offline   Reply With Quote
The Following 2 Users Say Thank You to gdi2290 For This Useful Post:
ftc~brz (09-28-2012), StarsGarrador (09-09-2012)
Old 09-08-2012, 04:34 PM   #114
Fun@55
Drives: SCION FRS
I have the same issue. Sometimes auto up works, sometimes it doesnt. Its frustrating
Fun@55 is offline   Reply With Quote
Old 09-09-2012, 03:51 AM   #115
alrashwa
alrashwa's Avatar
Drives: '12 370Z Monterey Blue
Mine has been working fine since the Cam gear replacement. Not sure if the frequent battery disconnects may have solved it, but works every time now.
alrashwa is offline   Reply With Quote
Old 09-09-2012, 04:37 PM   #116
StarsGarrador
Gangnam Style Guru
StarsGarrador's Avatar
Drives: Suzuki GSXF650, WRB BRZ
Mine does as well :/ my buddies frs too
StarsGarrador is offline   Reply With Quote
Old 09-10-2012, 04:05 AM   #117
Eyesacky
Eyesacky's Avatar
Drives: DGM BRZ Limited "Freyja" +2 Miatas
Same problem -- left me second-guessing if my index finger wasn't working correctly. Glad to know it's the button that might need replacing and not my finger :P
Eyesacky is offline   Reply With Quote
Old 09-12-2012, 09:17 AM   #118
miodculae
FRS Adept
miodculae's Avatar
Drives: Firestorm FRS
Mine too. Passenger side died about two weeks ago. Have not found the time to see dealer yet. Not too bad now that the weather has begun to cool, but still annoying to experience on such a new ride.
miodculae is offline   Reply With Quote
Old 09-12-2012, 03:30 PM   #119
xjohnx
Grip>Slip
xjohnx's Avatar
i found that mine has gotten better the more i use it.
Old 09-12-2012, 04:33 PM   #120
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Yea, mine only acted up once in the past two weeks. Maybe its just me getting used to pressing the button a 1/2 second longer
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 09-12-2012, 04:48 PM   #121
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
And I thought it was just my BRZ. Yup, I have the same issue. I have to find that 'magic spot' for it to work right
Eurasianman is offline   Reply With Quote
Old 09-12-2012, 05:37 PM   #122
enzeruvs
The guy with the hair
enzeruvs's Avatar
Drives: 2013 FR-S (AT) - aka: Quicksilver
Being a former tC driver, I thought that it was just me still getting used to the slight angle of the buttons/switches, and my muscle memory needing to be adjusted. I tried to develop the habit of double tapping the passenger window switch just to get it to go, with little success.
Glad to know that isn't me, though. But it's still kinda frustrating to have to glance over and realize I have to hit the damn switch again, when I jump on the freeway and try to roll up my windows once I hit the 50~55 mph range.
Hope someone finds a reliable fix for this soon...
2005 Scion tC | AT | Flint Mica | Darkblaze | Traded
2012 Scion FR-S | AT | Argento | Quicksilver | Current
Speed means nothing without control.
enzeruvs is offline   Reply With Quote
Old 09-12-2012, 11:50 PM   #123
xjohnx
Grip>Slip
xjohnx's Avatar
i've found that it helps if you press the switch just in front of the crescent shaped indentation (the indentation i'm referring to is located in the middle on the switch.)
Old 09-14-2012, 04:00 PM   #124
ftc~brz
Done
Drives: WRB BRZ
mine too...
ftc~brz is offline   Reply With Quote
Old 09-14-2012, 04:07 PM   #125
Yruyur
Yruyur's Avatar
Is this a switch issue. Can you swap the driver side and passenger side to see if it follows the switch. Or is this something that the ecu detects then tells the window to go all the way.
Old 09-21-2012, 06:34 PM   #126
was385
Drives: MT WRB BRZ Limited, 2007 911s
Just got a call from my dealer that SOA has a service bulletin on this issue saying they're aware of the complaints, but that it works how it's supposed to and they should not fix it. I'm going to go in and read this bulletin, because that's garbage. One auto button should not work differently than the other.
was385 is offline   Reply With Quote
The Following User Says Thank You to was385 For This Useful Post:
Window Tint IceCreamMan Cosmetic Modification (Interior/Exterior/Lighting) 46 09-22-2012 03:43 PM
Window Tint in South Florida lordtakuban Southeast 9 06-30-2012 08:46 PM
Charlotte NC window tinting Thongpocket BRZ First-Gen (2012+) — General Topics 1 06-28-2012 01:38 PM
Window Tint Before and After Suiris FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-24-2012 11:37 PM
Window tint in MI eikond Great Lakes 4 06-01-2012 02:59 AM
