Old 09-05-2012, 04:51 PM   #29
gmookher
lets get a list of vendors and flywheels weights going...
Old 09-24-2012, 12:08 PM   #30
Esoteric
Esoteric's Avatar
Drives: FR-S|(2)AE86|TA22|E30M3|E36M3|BPLeg
I think this car could use a lightweight flywheel... The response is nice, but a little less crisp than it could/ perhaps SHOULD be for most peoples tastes.
One of the things we have been waiting for has been and ECU tuning partner so that we can tackle the idle issues that some people have reported.
I have personally seen several of our customers cars idle fluctuate with stock pulley and flywheel when the RPMs drop... I think Toyota/Subaru will rectify this on the OEM level as production goes on but a tune could have a positive effect on this annoying little hiccup.
Wu... What weight is your Flywheel? Is it a "made by Perrin" product, or one they are simply reselling?
Esoteric is offline   Reply With Quote
Old 09-24-2012, 12:19 PM   #31
BlueLeader
Drives: Ultramarine Blue Scion FRS
Originally Posted by wu_dot_com View Post
Btw I am not noticing a gain in fuel effiency. Do far I've seen a 2 mpg improvement with the combo
So to clarify you ARE seeing a gain in mpg. Because 2mpg gain is much more efficient.
Sent from my ADR6400L using Tapatalk 2
BlueLeader is offline   Reply With Quote
The Following User Says Thank You to BlueLeader For This Useful Post:
20valvewynn83 (09-24-2012)
Old 09-24-2012, 12:29 PM   #32
Opposed
Drives: 2013 Asphalt FR-S
Have you contacted Visconti yet? His tune has drastically helped the idle on this car. Its raised a tad, and much smoother. I also did not notice any dips when running the A/C like I did before the tune. I do however feel it "kick" on now with my lightweight pulley installed.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 09-24-2012, 12:37 PM   #33
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
I got the lightweight pulley installed on sat and i love the response..i actually did a dyno with it and it gained 2hp but it gained 1-2hp from about 4000 rpm to about 6800rpm. im waiting for the dyno sheet to be emailed to me..its a cheap mod that changes the feel of the car for the better. This was a on a mustang dyno..i believe i did 154 and then 157 after pulley install
brichard0625 is offline   Reply With Quote
The Following 4 Users Say Thank You to brichard0625 For This Useful Post:
Bluecille (11-05-2012), Esoteric (10-21-2012), ShoNUFF (03-18-2013), SkAsphalt (09-24-2012)
Old 10-30-2012, 07:10 PM   #34
Turdinator
Señor Member
Turdinator's Avatar
@wu_dot_com Did the CEL ever come back? Or did the initial ECU reset fix this permanently?
Is anyone selling lightweight flywheels yet?
1974 TA22 Celica
2013 86 GT
Old 10-31-2012, 05:26 PM   #35
wu_dot_com
Drives: accord
Hi Guys sorry for the late response, i've been out of a Job for a while so i went MIA. but now im Back
Originally Posted by wootwoot View Post
Anyone else have any experience with a light weight flywheel? Updates on anyone making a light weight flywheel option?
mine was the prototype from ACT. they are fantastic.
I have the prolite ACT flywheel, i think they are about 12lb.
yes i am seeing a gain in MPG. now i have been driving 3K past the initial insallation, i've been seeing a 3-4MPG gain for the same driving condition.
note: the 3-4 MPG gain is from adding both light flywheel and crank pully. the gain was from the avg MPG readout from the car. during each fillup, i reset the avg MPG. the initial MGP was 30-31 avg MGP. my current is 33-34 avg MPG per tank.
the CEL never came back after the ECU reset. I believe ACT is selling theirs Monster clutch is going to be on sale soon.
However, i do still have idel dip from time to time.
wu_dot_com is offline   Reply With Quote
Old 10-31-2012, 05:41 PM   #36
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
do you mean streetlite? pro-lite would be less than 10lbs if you look at similar cars. rsx, s2k etc
FreshFRS is offline   Reply With Quote
Old 10-31-2012, 06:43 PM   #37
wu_dot_com
Drives: accord
i just check the prolite is 10.5 lbs. i thought i was 12 lbs for some reason.
BTW i have the prolite.
Old 10-31-2012, 07:37 PM   #38
Turdinator
Señor Member
Turdinator's Avatar
Is the flywheel steel or aluminium?
1974 TA22 Celica
2013 86 GT
Old 10-31-2012, 07:54 PM   #39
wu_dot_com
Drives: accord
i think it have to be steel, i just dont see how aluminum can withstand the beating.
The Following User Says Thank You to wu_dot_com For This Useful Post:
Turdinator (10-31-2012)
Old 10-31-2012, 09:47 PM   #40
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
thanks for the info and review! i thought they would go less than 10lbs but 10.5 should be decent for all around performance.
and XACT Pro-lite/street light are made of Steel
Old 10-31-2012, 11:42 PM   #41
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
This car is screaming for lightweight flywheel/pulley/CF driveshaft.
It's nice to know that the lightweight pulley/flywheel combo isn't causing misfire CELs.
Old 10-31-2012, 11:52 PM   #42
wu_dot_com
Drives: accord
During the development, the ACT engineer have told me that the oem flywheel and clutch plate is heavy which absorbs all the secondary vibration from the engine. Which is why we get no gears chatters from the gear box. However my current clutch setup is lighter which do increase the gear chatter. So if the flywheel is even lighter, the NVH would get even worst
FreshFRS (11-01-2012)
Aftermarket Crank Pulley Install Enigmus DIY (Do-It-Yourself) Guides 305 02-04-2019 11:37 PM
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Agency Power Crank Pulley / Clutch Masters Flywheel vividracing Engine, Exhaust, Transmission 67 11-07-2012 02:35 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
